Question about Dell OptiPlex GX260 PC Desktop
GX260 Migration I am attempting to migrate the components in order to accept a Radeon HD3650 video card. However I note the case on/off switch connects via a specialized single plug. My case uses a tiny plug for a reset switch and an on/off switch. Question is: Can I obtain an adapter to allow migration. OR does anyone have a larger than desktop style case (Tower) for this model that has burned out?
    Sergeant:
  • 458 Answers
Best bet is to buy a tower and put everything in it.
Posted on May 29, 2008
ERROR Unable to open NSF file
Verify that the nsf file is present in the path specified. The TSV file row for that particular user can be edited to enter the correct path to the mail file, and then attempt the migration again.
In most cases, the mailserver name is incorrect, and changing this value to reflect the correct mailserver that contains the NSF file should resolve the issue. If it useless, there is a good program: Lotus Notes Fix Toolbox https://www.fixtoolbox.com/lotusnotesfix.html
Apr 18, 2016 | Computers & Internet
Tip
Novell GroupWise to Exchange Migration
Migration of Emails from Novell GroupWise to Exchange is done by very easily with the help of Kernel for GroupWise to Exchange Software. It is an excellent utility to perform easy and accurate migration of mailboxes data.
The tool also allow users to migrate single or batch file migration in single migration cycle. The tool will support all version of Novell GroupWise and MS Exchange Server. For more help on Email migration please visit http://www.groupwisetoexchange.net
on Feb 08, 2016 | Quest Software GroupWise Migrator for...
Lotus Notes to Outlook migration, want online solution?
Yes, you can convert Lotus Notes archive .nsf file to .pst file format through SysTools Export Notes software. It makes impossible conversion possible within few seconds. You just follow the instructions shown in Video and Screenshots, for more detail visit the link http://www.lotusnotestooutlook.net/
Apr 24, 2013 | Computers & Internet
Hello, I followed the directions to install the hd3650 and now I don't have any display at all! I uninstalled the Radeon 9200SE from the control panel as the instructions said to, turned off the...
Hello zip_smythie, did you try plug LCD monitor cable into video card DVi or VGA connection, if you did that means your video card could be defective you should return this video card back for full refund or exchange for same item replacement ?
Nov 24, 2010 | Power Color RADEON HD 3650 AGP Video Card
RADEON 7500 AGP Graphic Card: just reformatted my old dell optiplex gx260 and i ...
You can try reinstalling the firmware for the video card, but if that doesn't work your video card is probably dead and you'll need a new video card. The firmware is what controls the video card, so if the computer shut off while the firmware was in the process of being rewritten, there's a good chance some of the code needed to run the card got erased or scrambled.
May 17, 2010 | Dell RADEON 7500 AGP Graphic Card
I bought a 512MB PowerColor ATI Radeon HD3650 DDR2 AGP video card
hey your monitor is not support the resolution , try lower resolution
Jun 13, 2009 | ATI RADEON X1650 Graphic Card
Problem installing ATI Radeon X1300 256mb in Dell Optiplex GX260
Hi edward,
I'm looking at the specs of your dell and of the video adapter.
It appears the Power Supply in your dell may to under powered for the video card.
According to dell's website the largest psu that ships with that unit is 250 watts while the radeon x1300 needs a minimum of 250 watts to run and assuming you have the 250 watt version you need to take into consideration that the psu is also powering your CPU, memory,fans,hard drive/s and other components on in your system so 250watts just isn't enough.
You may want to contact dell and see if there is a larger psu that you can purchase. I would recommend one at least in the 400 watt range.
I hope you get it straightened out I certainly know how frustrating it can be to not be able to use new hardware.
Let me know how it works out.
Sean
Mar 16, 2009 | Computers & Internet
Can i run ati radeon HD3650 512mb on asus k8N motherboard
you can upgrade your processor to a 3200+ or a 3600+ but the problem is availability and it should be socket 754 pin compatible...
regarding the HD3650 card...as long as its aa AGP card you should not have any problems..
also check your SMPS (power supply) it should be atleast 350(V)..
Jan 28, 2009 | ATI RADEON HD 2400 PRO Graphic Card
firstly you need to make sure *********** board has a PCIe slot or a AGP... this is where your ATI HD3650 will go...see the graphic 512mb has nothing to with your main system RAM which is also 512mb.. so they wont be any problems as such and both will work together without any problems... but i suggest you to add another 512mb to your system RAM.. the difference between DDR and DDR2 is that... DDR2 is a bit newer and is faster in terms of memory read/write/access... do let me know if u have any futher problems....
Jan 27, 2009 | ATI RADEON X1650 Graphic Card
Dell OptiPlex GX260 PC Desktop Logo
Alun Cox
