Question about Minolta DiALTA Di250 All-In-One Laser Printer
Minolta di250 error code c0070 this error code
Minolta di250 error code c0070 this error code comes out whenever i am printing.
  • 1,110 Answers
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the toner door and remove the toner cartridge/bottle from the machine. Close the toner door and turn the machine off then on to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
If the code comes back after the cartridge is re-installed then there is either a priblem with the cartridge or with the toner bottle drive.
Most of the time though the problem will be resolved by the outlined procedure.
Good Luck and Thank You for using Fixya.
Posted on Sep 29, 2010
Minolta Di250 copier malfunction C0070; please help me my boss wont buy a new and i need it to make my application; please help me
Re: Error Code c0070
If the machine is throwing the C0070 code without the bottle being inserted than likely the worm gear of the little drive motor of the toner bottle holder is damaged.
If C0070 is only coming up with the bottle inserted, than the bottle may be wrong or damaged from previous attempts.
To reach the toner bottle holder ("hopper") mechanism you have to remove the rear cover.
Apr 02, 2014 | Minolta Office Equipment & Supplies
C1300 error code Minolta Di250F
Print Head failure. The print head is what has the copier LASER inside of it. Check the connection between the print head and Master board. Replace the print head fist then board, if you can find either one. The Di250F is a legacy Minolta machine now konicaminolta.
Jan 07, 2014 | Minolta DiALTA Di250 All-In-One Laser...
Error code c0070
Power off the machine and gentlly take out the toner bottle. Then with the bottle out turn on the machine let the machine go thur its normal routine when the indicator comes on for toner install toner bottle. If the code comes back you have a problem with the Toner Bottle motor, gear, or Main Board.
Apr 17, 2010 | Konica Minolta DiALTA Di183F Copier
Code 0510
This is a Fuser Temperature error, You will need to have the printer serviced by a qualified technician or have the fuser unit replaced.
Aug 05, 2009 | Minolta DiALTA Di250 All-In-One Laser...
C1300 error code
· These malfunctions are concerned with faulty symptoms as they relate to software, hardware, and communications. For remedial actions, change the board, check for cable connections, and turn the Power Switch OFF and ON. (6) C10]] to C13]] C1300 1. Reset the malfunction and turn OFF and ON the Power Switch. 2. If the same malfunction persists, check the harnesses and PJs between PH Unit and PWB-A and, if they are intact, change PH Unit or PWB-A, in that order.
Dec 27, 2008 | Minolta DiALTA Di250 All-In-One Laser...
Cannot change toner bottle
Usually if you turn the machine off then back on and let the
toner stop cycling it will be in the correct position to remove the bottle
Apr 30, 2008 | Minolta DiALTA Di250 All-In-One Laser...
Hi eerror c0070
Toner moter drive fault. Bottle been put in wrong position. now jammed up machine. remove and turn machine off/on may work. If not have to reset error code in trouble mode. not a problem but engineer needed to do it.
Jan 25, 2008 | Minolta DiALTA Di250 All-In-One Laser...
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
That malfunction is a toner motor drive problem. It has most likely died, or the motor has jammed. Check for any sort of jam inside the printer near the toner motor. Otherwise, you will need it professionally repaired. There is no quick and cheap fix for this problem, unfortunately.
Sep 06, 2007 | Minolta DiALTA Di250 All-In-One Laser...
Minolta DiALTA Di250 All-In-One Laser Printer Logo
1,111 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
