Question about Whirlpool Duet GHW9150P Front Load Washer
F-20 error? - Whirlpool Duet GHW9150P Front Load Washer
  • 2,382 Answers
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the "F20" error code.
"F20" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free.The pump is located directly under the wash tub in the front of the washer.Verify the electrical connections are good and that the pump is running.Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch - remove the three screws in the top panel along the back of the washer.With the screws removed, the panel should slide back, then, lift off.The pressure switch is located on the right-hand side of the washer in the rear.It is a round plastic device with electrical connections and a plastic air hose attached.Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) - with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub.There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls.Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU.In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Posted on Sep 28, 2010
Scanner error 20?
Here is a link to help with HP LaserJet Error Codes.
Go through them, follow the procedures and you may find this useful and helpful.
http://printertechs.com/tech/error-codes/error-codes-index.php
Also, this link below, however, explains what Error 20 is and how to fix it in a "little" more detail.
--Printer Not Activated - Error 20--
I hope these help you.Regards, Mike
Mar 24, 2015 | HP LaserJet M1005 Printer
Why magicjack shows error 20?
If your magicJack reads "Error 20", please follow the steps below.
If your magicJack reads "Error 20", please make sure that you have allowed exceptions on your Firewall/Antivirus for magicJack. The most common Firewall/Antivirus programs are listed
below. If your Firewall/Antivirus software is not listed, please refer to their web site or user manual.
You can download a document (pdf file) from MagicJack by going to What Is Voice Over IP Frequently Asked Questions magicJack
and putting error 20 in the search. This will then give you the 86kb long file with details on the most popular anti-virus software.
Nov 20, 2014 | magicjack.com Computers & Internet
Error code 20 yahoo
I'm getting an error code 20 when trying to search my email.
May 19, 2010 | Yahoo Mail
SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
Mar 10, 2010 | HP LaserJet M1120 MFP All-In-One Printer
Windows XP Error: category 102 event id 1003
look like a system crash.
try to go into save mode and do a scandisk
if not, remove any newly install hardware or software.
restart the laptop.
Nov 10, 2008 | Microsoft Windows XP Professional
Error code E:62:20 meaning
errorE:62:20 related to lens unit stuckup or gears problum repairable
Apr 14, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
PANASONIC UF-8000 ERROR CODE E03-20, copy function not working.
Error code E3-20 Main Motor Rotation.
Loud clicking sound fuser unit drive gears cracked not driving
Apr 01, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
Whirlpool Duet GHW9150P Front Load Washer Logo
105 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
