Question about Radio Shack Pro-82 Scanner
Pro -90 300 Channel TrunkTracker Scanner Will not scan Anymore.
sir fixalot
  • 146 Answers
SOURCE: Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Posted on Jan 04, 2008
Mechanic688
  • 204 Answers
SOURCE: desk top radioscanner want scan can u help me
po66, first off this is a nontrunking scanner. Do you know the freq. coverage style for your area? Some are still the old standard, some are trunktracking, there is different versions of trunktracking and most are not compatable. I have very limited info to work with, so I'm going to take a best guess. Here is a basic guide for your scanner.
http://support.radioshack.com/support_tutorials/communications/20-424.htm
If your needing freqs for your location, go here.
http://www.radioreference.com/apps/db/
I hope this helps clear up your problem, and if not, reply back here and I'll try to walk you thru further.
Mechanic
Posted on Jan 26, 2008
  • 514 Answers
SOURCE: pro 95 dual trunk tracking scanner just stays on
the manual at "http://support.radioshack.com/manuals/ome20-525.pdf" (if you don't have it)
says that you may be in manual mode OR that the channel at 3 might be a "trunk guide", that means that the channel is used to send out digital permissions to the system for each radio in the unit(s) to use a certain freq. when they transmit. good luck!
Posted on Mar 09, 2009
  • 43 Answers
SOURCE: want to scan cell band?
This non-trunking scanner made by Uniden can store 200 channels, and has a frequency range of 25-512mhz with some gaps in the broadcast bands. so cell phone is not possable
Posted on Oct 25, 2009
TOLhamRadio
  • 509 Answers
SOURCE: I have a pro 23
You will need to program in your local channels - ANALOG ONLY will work, not Digital. I suggest you go to "Radio Refererence DOT com" and go to their database; select your state, then your county, and it will list many frequencies for you to program to your radio. Also, SOME, not many, but SOME, Radio Shacks actually have a ham radio guy working there that can help you program your radio or help you 'CLONE' it from another identical radio. Good luck, and let me know how it goes. Happy New Year my friend.
Posted on Dec 31, 2010
The scanner appears to scan but there is no sound or appearance of locking on a channel
Check the antenna to make sure it is securly connected. This may also be an issue where the crystal is removed or dead.
Aug 27, 2011 | Uniden TRUNKTRACKER III
MY RADIOSHACK NASCAR PRO-84 SCANS THREW CHANNELS BUT STAYS STUCK ON ONE CERTAIN WEATHER CHANNEL AND WONT CONTINUE SCANNING AND I NEED TO NO HOW TO DELETE THAT CHANNEL COMPLETELY.
The NOAA weather frequencies have constant broadcasts, so your scanner "locks" onto them. The only ways to prevent this are to either delete the weather frequency or lock it out. To delete, just program the frequency "0.0" (zero point zero) into the channel. To lock it out, press the L/O key while on the weather freq.
Bill B
Aug 06, 2010 | Radio Shack Pro-84 Handheld Scanner
How do clear the scanner to re program it
Programming a frequency into a channel clears the previous channel entry, so there's really no need to "clear" the scanner for reprogramming. To eliminate an unwanted frequency, you can either press the LOCKOUT key to prevent the scanner from stopping on a specific channel, or you can "zero" a channel:
1. Press SCAN/MAN to stop
scanning.
2. Use the number keys to enter
the channel number (1-200)
you want to clear.
3. Press PGM. F=C appears.
4. Press 0 then ENT. The
frequency number changes to
000.0000 to indicate the
channel is cleared.
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
Nov 05, 2009 | Radio Shack Pro-82 Scanner
Pro 82 Scanner from Radio Shack problem!!
While its in scan mode press the # of the channel to select.. you will see the bar go under the # Then it will scan the channel
Jun 04, 2009 | Radio Shack Pro-82 Scanner
My pro-2018 won't scan anymore.
you may need to re program it and get a external antenna.i recommend that you get a scanner pc programming kit.
Jan 31, 2008 | Radio Shack Pro-2018 Scanner
Jan 02, 2008 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-82 Scanner Logo
144 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
