Question about Sport & Outdoor - Others
Poolpower Salt Chlorinator RP30HD Instruction Manual
SOURCE: I have an intex salt water chlorinator and I have
Here is the website for all manuals! http://www.intexstore.com/default.aspx
All are dowloadable. Good luck!
Posted on Jun 23, 2009
  • 297 Answers
SOURCE: I have misplaced my manual for the intex 8110 salt
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=9536
Posted on Jun 27, 2010
Testimonial: "a copy of the manual is just what I needed, I am back in business and the children are happy."
  • 297 Answers
SOURCE: Intex salt water chlorinator I added a higher flow
your pump has nothing to do with chlorine generation.
You need to get a salt test kit that reads in #'s not colors.
Now get your salt to 3000ppm or as close to it as you can.
The amount of salt reccomended in the manual is just a starting point
any lower than 2800 and you will not produce enough sanitizer and over 3600 and your pool can go cloudy, taste bad, and rust metal parts
Posted on Jul 14, 2010
  • 297 Answers
SOURCE: We have a 15' by
First of all green water can arrise from a lot of different situation.
Low chlorine is one of them coupled with the crappy filter that comes with the intex pools it does not filter enough.
Start with getting your salt level to 3000ppm
any lower than 2700 and you will not generate enough chlorine and any higher than 3500 and you could go cloudy or trigger high salt alarms
you need to get the salt test kit that reads in #'s not color the color ones has to much of a variance
once your salt is at 3000 clean your cell then filter filter filter
I run my filter 24/7 if it is not generating chlorine I am filtering.
Clean your cartridge every few days
I have had the same 2 cartridges for this being my 4th season and have never been green or replaced the filters.
Also I reccomend a non foaming algecide
Just follow directions on bottle
Posted on Aug 31, 2010
Cloudkicker
  • 18 Answers
SOURCE: my low salt light on
A low salt level warning is indicated on your VX Chlorinator if the salt level drops. If Low Salt is indicated, check again in 24 hours and then if it is still indicated, add two 25kg bags of salt to the shallow end of your pool. Run the filtration system for approx. 6 hours to help mix the salt in the pool. It can take up to a day for the salt to fully dissolve.
If the low salt light is still on, then you should get your pool water tested. If the Salinity is above 4000ppm then you may need to have your Chlorinator checked.
Warning: Some people recommend that you put salt directly in the skimmer box. This is a very bad practice as it allows very high concentrations of salt to be passed through your filtration and other pool equipment.
Hope this helps.
Posted on Jul 06, 2011
Why does my salt level get low
You can get a false low salt reading if your chlorinator cell is very dirty. Before adding more salt clean the chlorinator cell as per your maintenance manual.
Sep 01, 2012 | Intex Automatic Salt Water System for ...
We have a 18x48 ultra frame intex pool. It at first gave us a lot of problems saying low salt so we cleaned the cell with vinegar and it began working no probs for the past 3 weeks. On the weekend I went...
I can't explain all of this but to get the rid of the green and reduce the salt level you need to drain half the water and refill. At this you need to shock it so the chlorine is up to about 10 ppm. You need some way of testing to tell this. If your chlorinator is ok then when you start the pump and chlorinator it should continue cleaning it out. The dead algae will be filtered out with the filter. If the flow slows down you will need to clean the filter with a water sprayer on a hose. I hope this helps.
Aug 09, 2011 | Intex Automatic Salt Water System for ...
Hi, last month we bought an intex round pool (18' x 54") with sand pump and salt sanitizer. Within the last 2 days the water started turning green. It turns out my husband accidently set the pump...
You don't want to swim in water that has algae... 1st ...Make sure you have the correct amount of salt. See you manual for amount needed. Must set you pump timer first and sync your chlorinator between that time, if pump turns off before chlorinator cycle ends, you will get an "Low flow" alarm. Set you pump timer to run 12 hours and the chlorinator for 10 to 11 of those hours and should see results within 3 days or so. After that, If you live in an area that is hot, 10 hours pump and 8 to 9 chlorinator... Hope this helps...
Jul 13, 2011 | Intex Automatic Salt Water System for ...
My low salt light on my Hurlcon vx7t salt chlorinator keeps comming on.How do i adjust it?
Hope this helps.
Jul 06, 2011 | Grilling
I need a Poolrite Mirrakel Gen 3 salt chlorinator instruction manual as I need to change the timer
Changing the timer is easy, press clock and keep it pressed, then press the hours and minutes to the required time, searched the net, cant find a manual for it, as Poolrite went bust
Nov 22, 2010 | Garden
Intex 9 x 18 ultra pool with salt water system. Came home and low salt light on added up to 40lbs and continues to be on. Don't want to add anymore please advise.
IF YOUR CHLORINATOR IS DIRTY IT WILL GIVE YOU THIS READING. USE HOUSEHOLD VINEGAR TO CLEAN THE CHLORINATOR PLUG 1 END AND FILL ABOVE THE PLATES AND THE COPPER IONIZATION ELEMENT. LET SOAK I HOUR AND BACKFLUSH WITH POOL WATER . HOOK IT BACK IN THE SYSTEM AND THAT SHOULD FIX THE PROBLEM. IF NOT CHECK THE POOLS SALT CONTENT. IT SHOULD BE .003 PPM. IF NOT ADD SALT ACCORDING TO THE MANUAL ON YOUR SIZE POOL.
Jul 29, 2010 | Intex Pool & Spa
Intex salt water chlorinator I added a higher flow pump and chlorine levels seem low no matter how many hours I run the chlorinator
Jun 28, 2010 | Intex Automatic Salt Water System for ...
Sport & Outdoor - Others Logo
669 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
