Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
I bought a new dishwasher from comet and installed it i tried it out but it doesn't seem to drain completely
    President:
  • 1,430 Answers
Check that you have the correct high loop http://mediasuite.multicastmedia.com/player.php?v=z3q491n5
If that checks good start here Dishwasher not draining
Posted on Sep 28, 2010
  • marka19
    marka19 Sep 28, 2010
    Obviously with that quick of a response you did not check any of the suggestions. Good Luck
Doesn't drain out all the way water stays in
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Maytag Dishwasher
The second led is flashing. Water did nit drain at first. Then drained. Cannot press the start/reset button, nothing happens. Sounds like the pump was working, now doesn't seem to be. Help!!!
Hi
Daniel
Aug 27, 2011 | Dishwashers
The dishwasher is not completing it's cycle and doesn't seem to drain at the end.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 15, 2011 | Smeg 18 in. DWD409SS Built-in Dishwasher
Dishwasher will not drain. Can hear it making a sound but water will not empty. Tried some liquid plumer but that does not seem to be working. When we try to drain there is a funny sound.
Hi
This draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 13, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Water doesn't drain
Hi
Daniel
Aug 03, 2011 | Maytag MDB8851 Built-in Dishwasher
Dishwasher will not drain out. Is it a clogged drain, bad pump or something else. Model # DU1015XTXS2, Serial # F05301668 and the Type # 575-1. Where is the drain plug located? I have not used this...
Hi
Daniel
Jul 05, 2011 | Whirlpool Dishwashers
Water does not completely drain after a wash cycle. Everything else seems to work just fine.
Hi
Daniel
Jun 16, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
Whirlpool dishwasher is not fully draining after cycle complete
THE PROBLEM SOUNDS TO BE WITH THE INSTALLATION OF THE DISHWASHER ITSELF. YOU NEED TO MAKE SURE YOUR DRAIN HOSE IS NOT KINKED AND ALSO THAT THE DRAIN HOSE FORMS A LOOP. IN OTHER WORDS IT SHOULD GO STRAIGHT UP BEHIND THE UNIT AND THEN DOWN INTO THE SINK OR DISPOSAL.THIS SHOULD TAKE CARE OF YOUR PROBLEM.
Apr 07, 2009 | Dishwashers
Dishwasher not washing
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
trew
Feb 10, 2009 | Whirlpool GU3600XTS Dishwasher
Bosch NOT completing cycle NOR draining water
This may or may not be the issue: I have friends that bought a new dishwasher - I'm not certain, but I think it was a Bosch. They did have similar draining issues.
With their dishwasher, the installer did not follow directions properly. Yes, he'd "installed a million dishwashers", but was too self-confident to check the directions for something particular to this machine. There was something about the way one of the drain or supply hoses was supposed to loop around that was unique to installing this brand, and that ended up being the problem.
Make sure that your machine was installed properly in this regard, even if your installer says they know what they were doing. Call Bosch's customer service dept. if you have further questions.
Sep 11, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
