Question about Sony KDS-55A3000 55" HDTV
Where is the lamp located on the sony kds55a3000 for changing
  • 10,594 Answers
Lamp is located on left side if you see tv from rear side.
Click Sony Support and download user manual free copy and check page-44 for more details along with exploded views for better idea about how to replace lamp.
Posted on Sep 28, 2010
How do I fix?
Probably the replacement lamp is not correctly aligned. HOWEVER, if the band is not on the bottom, but is surrounded (above and below) with good picture, the cause is in the RED color circuitry usually the 'convergence' section. This type of failure is often due to a failing electrolytic capacitor. Repair is problematic and may be in the integrated circuitry.
Jul 23, 2014 | Sylvania Osram Replacement Lamp & Housing...
I am trying to figure out how to replace my replacement lamp, but do not know where it is located.
Lamp Access door for Sony KF50WE610 is below the screen on the front of the TV. This page shows location of Lamp access door and DIY bulb change instructions for most SONY LCD TVs:
DIY Bulb Installation Guide
XL-2000 XL-2100 XL-2200
XL-2400 XL-2500 XL-5000
XL-5100 XL-5200 XL-5300
This page shows Lamps and bulbs for all Sony LCD Projection TVs
Sony Lamp Gallery
Look at Optical Engine Faults before buying a lamp or bulb. Replacement bulb will not repair these problems.
Feb 05, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
How do i change my lamp on a sony xbr kf60xbr800 , where is it located on the tv
Sony lamps are usually found on the rear cover of the TV.If you are standing behind it its on your left side,it is on the side corner with a screwable head(either Philips or single slot)with a coin or treaded or by hand.Once you get the cover removed,lamp assembly is now accessible.There are two screws mounting the lamp assembly.The replacement lamp comes with the housing assembly.edmisch_0.png
Nov 25, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
Changed lamp and now the power is not turning on with the power light flashing three times
Three times light blinking shows that lamp cover has not been fixed on its location after lamp replacement.
Lamp cover is first thing that you removed to replace lamp, make sure it is fixed securely back in its place then turn tv On.
Aug 13, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Changing lamp
Lamp replacement is not difficult in Sony KDF-E60A20 TV and procedure is written in user manual.
Unscrew two thumb screws at lower corner at back of TV and take off lower front panel, in approx center of lower front of TV, lamp cover is located, unscrew it, remove it and lamp is there, unscrew lamp with hex key (supplied in new lamp box) and take out old lamp, put new lamp and put things back in reverse order.
Click Sony Support if you want to download user manual copy of TV.
Thanks.
Sep 30, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony kds-60a2020 lamp problem
I would change the whole LAMP ASSEMBLY because if you touch the lamp while changing it out of the housing the oils on your hands will cause premature failure.Most of the time the lamp assembly's come with replacement instructions but yours is not too bad it is located on the left hand side if looking from behind set.
Sep 10, 2009 | Sony KDS-60A2020 60" HDTV
How To change Sony XL-5100 Projector Lamp with housing
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your TV from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover (Usually located at the rear of the television)
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your TV unit Caution: Do NOT touch the bulb directly with your fingers.
  • Jun 15, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
    Changing the lamp in a Sony Wega KDF46E2000
    Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
    Click Sony Support to download instruction manual of KDF-55WF655
    that has detailed procedure of lamp replacement.
    lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
    May 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
    Lamp Replacement on Sony Wega TV
    Please explain the location of the lamp for a sony kf-50we610 50 inch tv. Note same problem as above.
    Apr 07, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
    Open Questions:
    Sony KDS-55A3000 55" HDTV Logo
    130 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
