Question about Brother Sewing Machines
I don't know how to install bobbin and casing into Brother XV 1250
    Genius:
  • 1,788 Answers
I do not see your model number listed on www.brother-usa.com to even look up your manual. I would call Brother at 1-877-276-8437 and ask for assistance.
Posted on Sep 29, 2010
I have a XL3030 and it will not pick up the lower bobbin thread. Needle doesn't seem to go down deep enough. All other things look normal.
Posted on Oct 22, 2010
I need a schematic for a Brother 6700 embroidery machine. I cleaned the bobbin case and around it and now the machine is making lots of noise.
It is probably one of two things,
1st..always put the needle plate on before you install the bobbin case. You can lock the bobbin case down by putting the needle plate on after putting the bobbin case in. Take off the plate and remove the bobbin case, install the needle plate, then install the bobbin case.
2nd...your bobbin case may be damaged now, if it is scratatched or chipped get a new case.
Good Luck
Jun 30, 2017 | Brother Sewing Machines
My janome wll not pick up bobbin thread
Did it pick up the thread before you removed the bobbin case?
May 07, 2014 | Brother CS-8150 Computerized Sewing...
My machine is not sewing
Hai, Please check the bobbin tension or bobbin winding.
Apr 16, 2014 | Brother PS-1250 Pacesetter
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
I just loaded the bobbin and when I sew the bobbin thread is wavy Is it a tension problem or did the bobbine not load properly or do I have the bobbin in wrong?
Do you mean that the thread on the underside of the stitching is wavy? if so, yes it sounds as if the bobbin thread is not under tension.
Take the bobbin out of the bobbin case and reload, make sure that the bobbin is in the right way and then hold the bobbin still and press the thread tail into the tension spring until you hear it click in. Usually the thread will come off the bobbin, through the tension then reverse direction in a "v" shape.
tally_girl_43.jpgI think this is your bobbin case. So bobbin would go in and rotate anticlockwise, and thread would go into the tension spring south, then reverse direction north so rotary hook catches the thread.
Just make sure thread is fully into the tension spring, pull backwards on it and it should stay in the tension device if its in properly. If not, it will come out.
If you can't get a resolution then the tension spring may have failed, you can buy replacment bobbin cases from Brother, a local dealer or
http://www.sewingpartsonline.com/bobbin-case-babylock-bernina-brother-riccar-x59802101.aspx
I trust this helps you resolve the issue, often its just threading up and a bit of a break away for five mins, then fresh eyes, rethread carefully, checking the manual directions, and issue will resolve.
Jul 05, 2011 | Brother PS-1250 Pacesetter
Need to order bobbins for Pace Setter 1250
sewingpartsonline.com has parts for the ps 1250
just go to the home page & find the brother parts & on the next page look for the ps1250-- it's
towards the middle on the left
Dec 01, 2010 | Brother PS-1250 Pacesetter
Brother VX 1250. The needle can't pick up the bottom thread from the bobbin.
Check the needle to be sure it is installed with the flat side facing the back of the machine.
Check the needle to be sure it is not bent.
Mar 02, 2010 | Sewing Machines
Bobbin case on brother sewing machine
Well, from the picture I see that your bobbin is a front load as opposed to a top load.. if you tilt the front panel down, you will see where the bobbin and casing goes. Put the bobbin in the casing with the thread pulling from the right hand side of the casing making sure the thread in guided into the small **** on the top edge of the casing.. On the back of the casing the will be a small tab. Pull that away from the casing and enter the casing in to the opening for the bobbin. It should snap into place when you release the little tab.
May 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
212 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
