Question about Frigidaire Refrigerators
I purchased a condo that is eequipped with model # FRT18HS6AB3 (serial # LA34116223) and it has a very annoying high pitch sound. What is the problem and what can I do to fix it?
  • 121 Answers
This is most likely the fan motor inside the freezer. Replace the motor and it should repair the problem. http://www.appliance-repair-it.com/Refrigerator-repair.html
Posted on Sep 28, 2010
Nosey new refrigerator has high pitch or low noise irritating
is it an inverter fridge which saves on energy. that makes a high pitch sound. i recently fell into the same trap. if it has a clock set the time so its more inclined to make those noises when you are asleep.
Sep 30, 2016 | Whirlpool Refrigerators
There is a high pitched sound coming from under my 2002 Jimmy. It seems to be originating in the vicinity of the fuel tank, catalytic converter, differential area. But I cannot isolate it. Possibles?
Fuel pump in the tank makes a high pitch sound which is normal. Turn your key in the ignition, but don't start, you should hear the high pitch sound with the pump priming the system. You will still hear it when started, it's annoying but normal. Different brands are quieter than other, I just replaced mine with a Delphi brand fuel pump which is a tad quieter than AC Delco stock pump.
Mar 16, 2014 | GMC Jimmy Cars & Trucks
Annoying noise
The noise is probably coming from the hard drive, remove it and see if that will solve the problem. That high pitched sound means the hardware is on it's way out.
Jun 12, 2012 | ASUS Computers & Internet
Philips Home Theater - Annoying high pitch sound while on standby
I have the same problem with the same model, so obviously it's not a single-unit problem. My only solution, since taking it back isn't feasible at this point, is to have a DVD on play-pause so that it's not on standby. Waste of energy, so I don't do it all the time, only when I'm sitting in the room late at night making the high-pitched noise hard to ignore.
Apr 17, 2010 | Philips HTS-3555 System
RCA D52W19B makes high pitched buzz when on
Sounds like a coil is vibrating or a component is bad causing the transformer to whine. Could possibly just need soldering.
Jul 08, 2009 | Televison & Video
RCA VCR makes high pitched whining noise when it's on...
The power supply is starting to fail. There are a number of capacitors in the power supply that need to be replaced. A local repair shop should be able to fix this easily. Figure on $10 max for parts.
Dan
May 05, 2009 | RCA VR508 VCR
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
Ringing sound with fan?
That high pitched ringing sound is a faulty colourwheel that will need replacement.
Apr 07, 2008 | BenQ PE8700 Multimedia Projector
An Annoying High Pitch Sound
Can be either noisey yoke or noisey flyback transformer........T.
Dec 12, 2007 | RCA F32450 32" TV
Refrigerators Logo
65 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
