Question about Elna 1010
How do you set tension most easily? my thread is bunching up and breaking under material, not bunching up in loops and there are very few stitches forming.
  • 3,053 Answers
Hello, wj
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about Sewing Machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/sewing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Posted on Oct 30, 2011
I have a 9020 singer sewing machine I bought without a manual. I can't seem to sew without looping the thread under it. Almost in knots.
Are you saying the upper thread is knotting under the fabric as it stitches? This is bird nesting or thread nesting and is generally caused by mis-threading, the thread not being seated in the tension disk, or the upper tension too loose.
When threading the upper thread, ALWAYS RAISE the presser foot. Verify that the machine is threaded correctly. If one guide is missed, the stitching will go haywire. Start out with the upper tension set around the midway point and then tweak it through test stitching.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 22, 2016 | Singer Sewing Machines
I've tried everything but cotton keeps on looping from under the material
Make sure you are using a brand-new needle and that is installed with the flat side facing the correct direction.
Remove the upper thread from the machine. ALWAYS RAISE the presser foot and rethread the upper thread. Verify the thread path is correct. Set the thread tension at the midway point between high & low number.
Lower the presser foot, retest the stitch quality on scrap fabric and adjust the upper thread tension until the upper thread and bobbin thread meet in the middle of the fabric.
Understanding Thread Tension Threads
Sep 19, 2016 | Sewing Machines
What am I doing wrong when the stitching on top of the material is ok and straight and the backside is knotting?
wrong bobbin tension , but amazingly its actually easier to adjust the top threads tension to compensate for it , use your tension knob to slowly adjust , try an inch , slowly adjust try an inch , and so on to get a top and bottom thread tension to match , this will need to be adjusted for each major change in fabric (aka , knits to woven )
Aug 17, 2016 | Sewing Machines
Top thread too tight. Bobbin thread too loose. Bobbin thread bunches up underneath material. The feeder teeth can not feed material through
first thing first - thread inside bobbin should be tightly wound in. Insert bobbin into bobbin case and thread through slot and under the spring. Spring has small screw which regulates the tension. Hold the thread like yo-yo and jerk a little down-up. It should drop just a little (not run down) - that is usually required bottom thread tension,
if not, regulate with the screw. Set top thread tension 3 and sew. If still looping under, increase the top tension higher till the looping disappears. .
Nov 03, 2015 | Sewing Machines
What is the factory tension setting for the Brother LS-2125i sewing machine?
you probably wont find it listed anywhere as it is from experience and changes with different material thickness and needle size
SO how to set tension
thread the machine and adjust the tension until you feel a drag on the thread
now thread the needle and sew a piece of scrap material
if the thread bunches up underneath then increase the thread tension until it sews properly
if the bottom thread is pulled to the top or the thread keeps breaking loosen ti off a bit
when the stitch is being properly formed , both bottom and top threads should meet at the center of the two materials being sewn
Oct 13, 2015 | Brother LS2125i Sewing Machine
Janome 6260 not stitching properly. skipping stiches on top and bunching on bottom
New needle, clean under bobbin case and look at this.......Looping thread underneath is a top thread tension issue...
I have written a 5 page illustrated Tutorial on overcoming this problem....HERE
Nov 23, 2011 | Janome 6260QC Computerized Sewing Machine
Can't set the tension on needle or bobbin to match
1. make sure your machine is threaded right.2. set the tension between 3 and 4 and play with the tension as you need it to adjust it.3. make sure the bobbin is threaded right.make sure to visit the site below; it has solutions to multiple problems and instructions how to thread the needle or bobbin. Good luck.htt://Fix Looping/Knotting Thread Fix Knotting/Bunching Thread Looping Bunching & Knotting Thread
Aug 03, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
The stitch on the bottom of the material is very loose and is bunching and looks terrible, the top thread keeps skipping and breaking, Ive fiddled with the tension and still having problems
Let me give you a general lesson on adjusting tension that will work for any machine. I suggest you thread the top of the machine with a different color thread than the bottom so that it's easier to see what adjustments you need to make.
Thread your machine with the presser foot UP. The disks that control the tension (threadgoes through them) are tightened up if the foot is down. Change the machine tension with the presser foot DOWN.Because the disks won't be engaged (see above) if the foot is up, the diskswon't move. Start at the middle setting, 3. Go up to tighten, decrease toloosen. Each machine is different, even 2 different machines of the same model.The best thing to do is start at 3 and use a different color in the top andbobbin thread so you can easily see what changes to the tension do to yourstitches. Now use a straight stitch a sew 3 or so inches. Take a lookat the top and bottom of the fabric. You don't want to see any (or at least notmuch) of the other color showing from the other side. Loops on the bottom of the fabric means you need to tighten(increase) your top tension. If you're stitches on the bottom are causingpuckering, then you need to loosen you're top tension. For the most part, youreally don't want to touch your bobbin tension-leave that to a repairtechnician. The factory setting shouldn't be touched except by someone whoreally knows what they're doing. Keep sewing a few inches at a time until you have the resultsyou want. Now you're tension is where you need it!
May 22, 2011 | Brother XL-5130 Mechanical Sewing Machine
The threads under the material being stitched forms loops - the thread can be easily slipped out and the work undone.
top thread tension is too loose try tightening the top thread tension until the loops disappear.
Good Luck!
Chris
glfi.com
Feb 10, 2011 | Sewing Machines
Sewing Machines Logo
35 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
