Question about Kenmore Ovens
E1-F2 code after 2 min. of turning on oven then reset it and the same thing again
    President:
  • 1,430 Answers
This indicates a failure in the keypad or main control.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
http://appliancehelponline.com/ovenerc.html
Posted on Sep 28, 2010
I replaced circuit board in whirlpool combo microwave / oven, shows fault code F2, error code E1.
Did you get the circuit board from a trustworthy place?
It is a circuit board error. Did you install it correctly - right wires to right connections?
Control displaying F2 E1:
There may be a problem with the User Interface (Touchpad), or the associated wire connectors.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation
Have to go the long way to bring up the link by first:
e1 f2 whirlpool oven Google Search
and then click on https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjprvf2_7nJAhXKVRoKHe7zAmMQFggdMAA&url=http%3A%2F%2Fwww.whirlpool.com%2Fproduct-help%2Ferror-code-oven-f2-error-code-f2-e1%2FPH7389%2F&usg=AFQjCNFoDK8E-zgNHF3Kp4EoihGu1tbyEw
Dec 01, 2015 | Whirlpool Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
E1 F2 error code
Check the ribbon cable for connection
Mar 27, 2013 | Whirlpool RBS245PDS Electric Single Oven
Audible alarm sounded--"F2 "appeared on
Your model is actually a 911. Roper (Whirlpool)
The F2 error code is
E0 - Shorted keypad (also called touch pad)
E1 - Keypad cable unplugged
E5 - Cancel key drive line open
E6 - Cancel key drive line open
Solutions:
Jul 30, 2011 | Ovens
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Error code of E1 F2 on a kitchenaid double wall oven. What does that mean?
F2 - E1
1.
board).
Feb 15, 2011 | KitchenAid KEBC207 Electric Double Oven
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
Thanks
May 26, 2010 | Ovens
Oven door is locked after trying to clean and getting error code E1 F5
E1 F5 means your unit is having a problem with the door latch and lock assemble turn the power off for 10 min. and after turning the power back on wait another 10 min. before opening
Apr 05, 2010 | Whirlpool GMC305PD Electric Single Oven
I have a Whirlpool double oven (model RBD275PDS14). The control panel goes blank about every 2-3 months, and the oven won't heat. Although, the light inside the oven will still work. When the panel lights...
Your error code is for a stuck keypad. You can try pressing every button at random several times each to unstick.'
When the control board is changed on these ovens the keypad assembly is supposed to be changed also.
Nov 21, 2009 | Whirlpool Ovens
Kebc207 oven error code E1 F2
This is information from the Tech Sheet.
Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
Ovens Logo
48 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
