Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis Electric Dyer wont start - I think is the thermal fuse
Can you let me know where I can buy the replacement thermal fuse and how I can install the new one.
I REALLY appreciate it.
  • 525 Answers
Www.repairclinic.com
It should come with instructions in the package.
Posted on Jun 02, 2008
The wire going into the bottom left side of heat element burnt out (looked charred and separated completely. Black Wire, not the Heater Thermal Fuse, and not the High Limit Thermostat, but the third t
ON THE ELEMENT U HAVE THE HI LIMIT, THE THERMAL CUTOFF, AND THE OTHER FUSE FOR THE LIFE OF ME AT THE MOMENT CANT RECALL WHATS ITS CALLED LOL BUT SOUNDS LIKE THE ONE THAT BURNED OUT AS THE OTHER 2 ARE HIGHER UP
Sep 11, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis MDE6400AY timer works but dryer doesn't come on
First thin I would try is to check your thermal fuse for continuity with a ohm meter with the wires removed from the fuse and the dryer unplugged. Its located on the tunnel that in cases the heating element.
Here is the part in case you find it bad.
Oct 31, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
No heat from dryer maytag atlantis mde7600ayw had heating element them fuse and thermostat checked ok check ciruit breaker turn on and off decided to replace fuse dyer still didn't heat check outlet...
most dryers have a thermal switch or breaker in the cavity somewhere, they can become worn over time and will stop heating, the item probably looks like a copper arm that touches a contact similar to a old morse code key by looks
Sep 18, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer does not heat
Perhaps the thermal fuse is open. All thermostats and thermal fuses should be closed for continuity at room temperature on this dryer.
Go here for more Maytag Atlantis Dryer repair help: http://www.repairclinic.com/0047_8.asp
www.RepairClinic.com
Feb 01, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer does not start - Thermal Fuse is ok.
Good to know, when the appliance does not start at all is always thermal fuse, wiring, door lock switch, or rarely the control assembly.
Have a nice day.
Jan 02, 2009 | Maytag PYE2300AY Electric Dryer
Start button only lights up, does not start dryer
I finally fixed it !!!! 1st I replaced both thermal fuses and it still didn't work. So the next day I replaced the timer (start button) and voila !!!! it worked
Dec 14, 2008 | Maytag Atlantis MDE7657BY Electric Dryer
Maytag dyer MDE9206AYW
moter bad
start switch wont ingage
Jun 04, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Thermal Fuse
do u mean that the drum wont go round if so then it could be your mains filter which is faulty this is situated next to your motor either a plastic/metal cyclinder with wording on it will only be about 4in in length
Aug 12, 2007 | Maytag MDE2600 Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
210 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
