Question about Kenmore 75620 / 75621 / 75622 / 75624 Gas Kitchen Range
My oven doesnt seem to be getting as hot as its suppose to?? Took me an extra hour to bake a cake. What could it be?
    President:
  • 1,430 Answers
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
If the igniter checks out good the problem would be the temperature probe. Here is a link that will walk you thru checking and replacing an oven Temperature Sensor
Posted on Sep 28, 2010
Why does the bottom of my cakes burn before the center is done?
Because your oven gets too hot on the bottom part. Use a rack to position your cake in the centre of the oven or - if the bottom of the cake still burns - insert a baking tray between the bottom of the oven and the rack on which you bake the cake on.
Sep 19, 2014 | Baking
Why does my cake shrink before taking from the oven
That is completely natural. The cake raises due to air expanding in the heat and contracting when cooling down. The shrinking can be partly compensated by turning off the heat of the oven 5 to 10 min before it's done and let the cake cool in the oven for 10 to 15 min before taking it out. Avoids also cracking of cheese cakes.
Jun 02, 2014 | Baking
Why do cakes sometimes collapse while baking?
helllo dis.... There are many things that can cause cakes to fall in the middle.... Jumping, etc., around the baking area is unlikely to be a problem except with very delicate sponge or angel food cakes. More likely, cakes fall when the crust appears to be done, but the batter is not baked through the middle. An uneven baking temperature is a frequent culprit; check the temperature of your oven with a separate baking thermometer, and be certain that your oven holds a steady heat through the entire baking period. Some older ovens preheat properly, then cycle off and drop the temperature after 15 or 20 minutes, which causes the uncooked portion of the cake to fall.
Less likely but possible problems could be inaccurate proportions of baking powder or baking soda if the cake is made from scratch. This could occur with cake mixes if sour milk or buttermilk is used instead of regular milk; the additional acid in sour milk requires additional baking soda to rise properly. Eggs that are not beaten properly, or perhaps beaten too much for the type of cake being made, might also cause problems. Joe
Mar 12, 2011 | Tecnik Ovens
Best setting for baking cakes
good day,
hope this link below will solve your problem.
baking.
The best bread machine we've found for gluten-free bread baking. Programmable feature puts you in charge. Bakes a delicious 1.5 to 2 pound loaf every time. It has a viewing window, automatic settings for breads, cakes and jam, sourdough starter and programmable cycle that makes gluten-free bread in under two hours!
Aug 01, 2009 | Smeg SE250XUK Stainless Steel Electric...
79079383400 oven does not put out any heat
Your oven control module is gone. Replace.
Mar 31, 2009 | Kenmore Kitchen Ranges
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven not heating
Your ignitor is weak. Change it.It should be very bright ,if it is dim it is weak.
Jan 19, 2009 | GE JBP24 QuickClean Electric Kitchen Range
Kenmore 75620 / 75621 / 75622 / 75624 Gas Kitchen Range Logo
112 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
