Question about Panasonic Lumix DMC-LZ7 Digital Camera
I have a DMC-LZ7, with some pictures on the built in memory. Can I transfer those pictures to a memory card? The pc cable doesn't talk to the camera.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Panasonic Master
  • 102,366 Answers
Yes. There's a "Copy" option in the playback menu. It can copy all pictures from internal memory to a card, or individual pictures from a card to internal memory.
Posted on Sep 28, 2010
How to delete pictures in built-in memory, dmc-LZ7
connect your camera to a compter
click start click on computer you should see your camera click to open you should see your pictures on the sd card select the ones you want to delece right click delete
hope it helps
Apr 03, 2012 | Kingston 1GB Secure Digital Memory Card
I have a Panasonic Lumix DMC-FS15 when I switch on it says "built in memory card full" even though I have a 4GB memory card in the camera which is not full. The camera doesn't seem to detect...
Hi, Move the internal pictures to your card and then switch it to record to the card...
Here is a tip that may help you with your problem.... I found out that with my cameraI needed to transfer the pictures within the camera to the card and them fromthe card to the computer...
The process for your camera may not be exactly the same, but should be similar.
How toTransfer Internal Camera Memory Pictures heatman101
Aug 26, 2011 | Panasonic Lumix DMC-FS15 Digital Camera
Copy pictures in built in memory to memory card
You have to connect to a pc, transfer the pictures to the computer, then you can transfer them from the computer to the memory card file on the camera.
Jul 30, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
I have a Panasonic Lumix DMC L27 camera. I have tried unsuccessfully to transfer my pictures from the camera via a USB cord (3 different ones) and have had no problems in the past. It usually goes right...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
May 29, 2011 | Panasonic Lumix DMC-LZ7 Digital Camera
My Panasonic DMC-LZ7 is not not recognized by computer when usb cable plugged in. It has always worked before and not is not.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Dec 17, 2010 | Panasonic Lumix DMC-LZ7 Digital Camera
I don't know how to get photos from my DMC-LZ7 camera to my computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Jul 28, 2010 | Panasonic Lumix DMC-LZ7 Digital Camera
I have a panasonic lumix DMC-LZ7 and never had this problem before but when i hooked the camera up to my computer to import the photos it always said connecting with an arrow on a wavy line and now it says...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
May 14, 2010 | Panasonic Lumix DMC-LZ7 Digital Camera
Turn off built-in memory panasonic dmc
Remove the memory card. Go into the menu and find "reset"...follow the on-screen instructions. Then, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then insert your card and all should be well.
Apr 27, 2010 | Panasonic Lumix DMC-LZ7 Digital Camera
I have lumix dmc-lz7. Tonight I put a 2 gig sd card into my built in card reader , Dell pc and it didn't work and did not even show the drive on computer. Then, to check it out, I connected camera to usb...
maybe the card reader is not SD/SD HC compatible, the same problem occurs wiith the Memory Stick Pro/Duo of sizes 2GB or above in my Desktop Computer (Compaq) and not in my Notebook (Compaq) the card reader and the machine are newest and are compatible
Jan 30, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Transfering pictures
I have a DMC-LZ7 that I purchased a year and a half ago. You can transfer pics from the built-in memory from the "copy" menu function when the camera is in play mode (10th option down in the menu). If you move the cursor down to this selection then hit the right arrow button, there should be options to both transfer from built-in memory to the SD card and vice versa.
Sep 19, 2008 | Panasonic Lumix DMC-FS5 Digital Camera
Panasonic Lumix DMC-LZ7 Digital Camera Logo
484 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
