Question about Dell Inspiron 710M 24X CDRW/DVD Combo Drive FC634 Burner
DOES THIS COME WITH AN IDE OR SATA CONNECTION?TKS
    Brigadier General:
  • 10,406 Answers
Access the manufacturer's web-site:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=DB7N531&SystemID=INS_PNT_CEL_1100&os=WW1&osl=en&catid=&impid=
and enter the Dell "Service Tag" (on a sticker on the bottom of the laptop) to get the "as-factory-shipped' specficiations for your specific laptop. Read the specifications, to see which model of CD/DVD you have.
Posted on Sep 28, 2010
Change my gx620 motherboard with ide connector for dvd rom to a 745 motherboard which has sata connection for dvd rom so i purchased a sata dvd rom and sata cable plugged everything in but the dvd rom wont...
With sata there are two cables, just like ide. One is the power and the other is for data. The data cable goes from the device to the motherboard. The power comes from the power supply. If your power supply does not have a sata connection you can purchase an adapter that will turn an available 4pin Molex into a sata connection.
http://www.ebay.com/sch/i.html?_nkw=ide+to+sata+adapter&_sacat=3667&_odkw=ide+to+sata+adapter&_osacat=42017&_trksid=p3286.c0.m270.l1313
Sep 11, 2011 | DELL 8X Serial ATA Slimline DVD-ROM Drive...
Tip
How to connect your hard drive to your motherboard The first thing you have to...
The first thing you have to figure out is what type of hard drive you have, a PATA or a SATA drive.
PATA = Parallel ATA
This type of drive uses the older IDE connections. Most of your current motherboards still have aleast one IDE connection to support the ROM drives on the market that have not moved over to SATA connections but you can still connect a hard drive to this connection if needed. The thing to keep in mind is that you can only connect 2 IDE devices to one IDE connection on the motherboard.
Here is an example of an IDE cable. If you can see there are tabs on the cable to make sure you line up the pins properly.
SATA = Serial Advanced Technology Attachment
This type is now the standard that most hard drives are. Also note that alot of your ROM drives are switching over to this format as well.
Here is an example of a SATA cable.
In regards to power connectors If you are using a PATA drive then you will use the Molex power connector. Note some of the early SATA drives use this power connector as well.
For the SATA drives you would use the SATA power connector. Note if your power supply does not have this connection you can get an adapter that goes from a Molex connection to the SATA connector.
Next you will need to find the connectors for the hard drive on your motherboard. Below if pictures of the 2 connection types.
IDE/PATA motherboard connectors
SATA motherboard connectors
on Sep 01, 2010 | Computers & Internet
I want to install a CD/DVD RW drive. This is in addition to the installed CD/DVD already in place. The new drive has a SATA connection on the back, and the only available connector is an IDE connector....
There are IDE to SATA adapters and cables, such as this one linked below. IDE to SATA Adapter
You would simply plug this adapter into the available IDE connection on your motherboard, then use the SATA data and power cable to connect from the adapter to the CD/DVD drive. You can look around online for similar products, but they should get the job done!
Mar 05, 2011 | HP (REFURB) HP XW4200 XPP P4 3.4GHZ 80GB...
How Do I exactly make a 500gb sata hdd work with this p4m266a ndmx motherboard? It doesn't appear to have a sata port and using the sata compatible cable did not help. Thanks
if your motherboard does not have SATA, purchase a SATA - PCI card, they cost something to the direction of 10 to 20 $ and give you 2 to 4 or more SATA ports.
Feb 12, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Must replace my harddrive but I don't know the connection that I must use.
If it is a wide connector that goes in to the hard drive it is called IDE and if it is narrow it is SATA connection. On the following picture left one is IDE and right one is SATA. Hope this helps.
http://www.computer-hardware-explained.com/sata-vs-ide.html
Nov 06, 2010 | Sony VAIO VGC-V517G PC Desktop
Sata power supply with ide only mother board?
Unlike IDE drive cables, which allow you to connect at least 2 drives to the same cable, SATA cables only allow one connection from motherboard to drive per cable. You can connect as many SATA drives to your motherboard as you have SATA connections.
Mar 25, 2010 | Computers & Internet
External IDE enclosure problem
here's what a sata hdd connection looks like
here's what a IDE hdd connection looks like
here's a page that shows them side by side
Hopefully that should help with what you have there.
Jan 21, 2010 | Toshiba Satellite 2455-S305 Notebook
Ide to usb connector sata cable attachment
The connection should be simple where you match the connections. The long connection is for the power and the short is for data. You can't really mess up the connection but be carefull when trying to connect and not to force the connections.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Adapters.com Serial ATA IDE Converter and...
Dll gx280 case
first off does the motherboard have both sata and ide connections or just sata or just ide? (sata are small about maybe 1/2 inches in length and 1 mm wide and a ide connection is approx 5 inches long with about 4 inches long with over 100 pins and about 1/2 inches wide) i know that the opliplex 520 are nothing but sata so if it uses the same mobo as the 520 and you have ide then its imposible to install on your computer unless it either has a ide connection or you get a ide pci or pci-e controller card and install that onto the computer. but for the most part a ide connection needs a ide cable and a sata connection needs a sata cable.
Jan 23, 2009 | Dell (2336V) Motherboard
I have 3in1 USB 2.0 to IDE & SATA Cable but nothing to show me how to use this kit
SATA 3.5" 2.5" IDE 3 IN 1 TO USB 2.0 CABLE ADAPTOR KIT
1 external connection kit
1 internal connection kit
The internal connect kit consists of 1 red USB connector cable
and 1 internal white male molex connector to SATA female power connector
( 1 yellow wire , 2 black wires , 1 red wire )
the external connect kit
consists of a 3 pin power adaptor (with a tiny plug to save space) feeding a power supply which powers either IDE thru a Molex connector or SATA through a supplied adaptor. Supplied also are data connectors to link the IDE or SATA hard drive with a USB port. Use this adaptor set to retrieve data from a hard drive when it is not mounted in a computer.
Selah :-)
Sep 14, 2008 | Computers & Internet
Dell Inspiron 710M 24X CDRW/DVD Combo Drive FC634 Burner Logo
22 people viewed this question
Alun Cox
