Question about Whirlpool GEW9250P Electric Dryer
Put shoes in dryer. it ran for a few min and the shoes hit the door and opened it. shut door back but it will not restart. all lightss are on but when i hit the restart button it beeps and the sencing light comes on but will not start
  • 16 more comments
  • triplecmaste Sep 29, 2010
    the end of cycle button did not work. you said flashing sensing mine is on but not flashing.
    fuse cks out ok belt fine too. any other ideas
    well the vent had some lint in it i vac the whole thing out and installed new vent pipe. still nothing
  • triplecmaste Sep 30, 2010
    THE VENT WAS FULL OF LINT AND I DID NOTICE THAT THE DRYER WAS REAL HOT THE LAST TIME I OPENED IT BEFORE IT WAS THRU SO I CLEAANED IT OUT AND INSTALLED A NEW VENT PIPE BUT STILL WONT START UP. DONT REALLY SEE HOW SHOES COULD HAVE DAMAGED THE CONTROL BOARD. THIS DRYER IS NOT VERY OLD AND IT DONT GET USED THAT MUCH
    I HAVE CON THRU THE FUSE. DOES IT OPERATE THE SAME WAY A CAR FUSE DOES. IT IF IS BAD NO CURRENT FLOWS THRU
    HOW DO I CK THE THERMOSTAT AND THE THERMISTOR
  • triplecmaste Oct 01, 2010
    ok everything test good then i done a self ck on it by pressing more time , less time like the book says. and it comes up with no error. when i push the start button i hear a click in side on the left side of the dryer near the top. if i open the door it clicks twice.
    if i try to start the dryer with the door open it beeps twice but when i close the door it only beeps once. if i hold the start button and open the door it beeps twice.
    well i guess i cked it i open and closed the door and it wont do any thing with the door open. what do i have to do to change the control and where do i get it. the other thing is i keep hearing that clicking sound in side the dryer kind of like a contact switch clicking on and off.
    i know i am worring you but i am trying to get it fixed. my wife is on my **** if you know what i mean
    ok i did the test on the door switch and it test good. it beeps when it should and displays the codes thet it is suppose to. i really dont know what to try next. unless i replace the control.
    yeah but 200 is alot for a dryer less than 2 yrs old and i cant figure out how putting a pair of shoes in it made that part go bad
  • triplecmaste Oct 10, 2010
    ON THE CONTROL BOARD THERE IS A RELAY SWITCH THAT SAYS MOTOR UNDER IT AND THE CLICKING IS COMING FROM THAT RELAY. STILL THINK THE BOARD COULD BE BAD
    WELL CAN IT BE REPLACED IS WHAT I AM ASKING. OR DO YOU THINK THERE MIGHT BE A MOTOR PROBLEM.
    COOL I AM GOING TO TRY TO FIND IT. WILL LET YOU KNOW IF IT WORKS
    thanks for all your help on this. i had a family emerg. and had to leave 4 a week that is why you didnt hear from me
  • triplecmaste Oct 15, 2010
    ok control board came in today and i put it in and nothing. same clicking sound and no starting. 175 wasted for nothing. anymore things to ck
  • triplecmaste Oct 20, 2010
    well turns out it is the motor after i hired someone to fix it
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Unfortunately Dryer is not made to wash shoes, to reset the control and solve this issue press and hold the END OF CYCLE SIGNAL button for 15-20 seconds. If still its not resolved then the flashing Sensing Light indicates that the Thermal fuse which is mounted to the exhaust duct inside the back cover panel has gone bad and should be replaced. Before replacing this fuse you can check continuity between its two pins, no continuity means bad fuse and if the fuse if fine then unfortunately the Belt is broken and should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 28, 2010
  • 16 more comments
  • Rylee Smith
    Rylee Smith Sep 29, 2010
    Flashing or on the solution is same.
    Thanks
    Rylee
  • Rylee Smith
    Sorry, I mean whether the light is flashing or is steady the solution remains the same. Let me know if you need further assistance.
  • Rylee Smith
    If the vent is clean then check the Thermostat, if thats also fine then the electronic control should be replaced. Please check this repair manual for your Dryer which will help you.
  • Rylee Smith
    The control panel is bad and should be replaced.
  • Rylee Smith
    Rylee Smith Sep 30, 2010
    Thats the reason the first thing I said to check if the Thermal fuse is fine, if thats fine then check the thermostat and thermistor.
  • Rylee Smith
    Have you checked it for continuity, you can test continuity between its two pins, no continuity means bad fuse, moreover you can also check the repair manual that I gave you earlier.
  • Rylee Smith
    You can check the repair manual that I gave you earlier for the procedure and dont know if I told you to check the door switch but that should also be checked.
  • Rylee Smith
    Rylee Smith Oct 01, 2010
    The issue seems to be with the door switch.
  • Rylee Smith
    If you have already checked the door switch and thats fine then it is the control that is bad.
  • Rylee Smith
    That is the reason I am saying its the door switch, you can get the parts from this link.
  • Rylee Smith
    Thanks
    Rylee
  • Rylee Smith
    I understand everything ;) As I said clicking sound means the door switch is bad however, as you have the repair manual you can also check the place from where you hear that sound.
  • Rylee Smith
    It seems you have already checked everything else so you know replacing control is always recommended.
  • Rylee Smith
    First thing will be to contact Whirlpool and let them know about the issue, usually the control board and motor are covered under 5 yrs warranty. Please accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Oct 10, 2010
    I thought the issue was resolved and still you are back :) yes you are right that relay switch might be bad, please post a comment for further assistance.
  • Rylee Smith
    If you are able to get relay then yes it can be replaced dont think its motor issue. If it was the motor then you'll hear a humm sound.
  • Rylee Smith
    OK sure please post back for further assistance.
  • Rylee Smith
    Alright...take care
Samsung front load dryer
it sounds like the problem may be with the door lock. Having shoes bouncing around in the dryer they are bound to hit the door over and over possible causing damage to the lock. Try pushing on the door and holding it shut while you turn on the unit and see if it works.
May 16, 2014 | Dryers
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
My dryer keeps shutting off after about 10-15 mins. It starts make a noise likes it's slowing down just before it shuts off. If I try to push the knob back in to restart. It will make a buzzing noise. If I...
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Mar 13, 2011 | Dryers
Won't start
most of the time it is a weak motor going bad,to weak to turn the drum-mike
Feb 06, 2010 | Kenmore Dryers
My electric dryer runs for a few minutes then shuts off. You can restart it almose immediately.
Probably the door switch. Is it closing tightly? Open the door and look at the switch, is it loose or any signs of problems. Try putting some tape on the edge of the door where it makes contact with the switch and see if it makes better contact.
Jul 03, 2009 | Whirlpool LER4634J Electric Dryer
I have a Neptune model MDE9700AYW dryer that wont start
Check to see if the little tab in the door jam, which causes the dryer to turn off, is broken or bent. If its bent you may just need to bend it back.
May 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune dryer won't start/
I do not have that specific dryer but try these simple steps.
Maybe they will help you.
1. Shut the electric breaker off to the dryer for about 30 seconds and and back on.
2. Open the dryer door and inspect the switch that tells the dryer the door is closed. work it by hand just to make sure it is not stuck.
3. Spin the timer controls to another setting and see if the other setting will work.
That's all I've got for now...
May 20, 2009 | Maytag Neptune MDE6700A Electric Dryer
Dryer does'nt run. checked breaker, thermal fuse, starter relay, timer stops when door is opened, starts when closed?
2 more things could be wrong,check the blower box to see if you have a thermister thermostat on it,check that with your omns meter,the other thing is the motor is no longer strong enough to turn the drum and it heat up and tips off,let me know what you find-mike
Apr 21, 2009 | Dryers
Hunting boots no no!
If you have one of those fubuloso wrinkle guard whirlpools, they will buzz and start back up on their own in the cool down portion of the cycle the idea being the 2nd timer will keep the clothes from wrinkling by buzzing and then coming to life for a few minutes. Then it waits 10 minutes and if you aint got the clothes out or opened the door then it will repeat.
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
I need help
un plug your machine for an hour if you can open the door open it and then put the machine plug back in with the door open keep it open till the machine comes on then put the program to what you want and then shut the door it then should be ok its called a reset try it hope this solves your problem
Aug 26, 2007 | LG WM2077CW Laundry XL Front Load...
Whirlpool GEW9250P Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
