Question about Toshiba EStudio 170f Fax 170f
My toshiba e studio 190f says paper jam j43 remove misfed paper but there is no jam anywhere! help!
SOURCE: e studio 16
More than likely you have bad feed tires in the tray you're pulling from or if the drum unit is stuck there probably is paper jammed up in the unit.  Replace you feed tires and check your drum separation claws when you are able to get the drum unit out.
Posted on Oct 20, 2007
  • 8 Answers
SOURCE: toshiba e studio 161
already paper jam in feeding assembly so please check any paper jam.or lubricate all drive gears
Posted on Jul 25, 2008
  • 87 Answers
SOURCE: misfed document feeder
just check properly all document feeder may bi there is a piece of paper in feeder if not just check all sensors and levers .may bi some sensor is dirty clean all sensors in paper path and check all sensor levers .may bi some lever is jammed.mian jee
Posted on Jan 21, 2009
  • 117 Answers
SOURCE: toshiba 2060 jams (accordion/fans the
sounds like a broken fuser drive gear.The fuser operates a nearly 400 degrees Fahrenheit and the drive gear cracks and falls off.Lots of trouble for a 50 cent gear.They are mad of fiber or plastic.take a few of the covers off near the fuser and disconnect the cables and the fuser slides out
Posted on Mar 24, 2009
  • 132 Answers
SOURCE: Power Failure in viewer.
double press the fc button the machine cannot be switvhed off at the power switch it must be shut down press energy save button and shut down what paper jam error codes does the machine give
Posted on Feb 17, 2011
I have toshiba e studio 163 spanner key is on, the mashine is not working . How cat I reset the spanner key.
I think the paper has moved half- way and may get jammed. Switch off the printer and try again. Remove if the paper is jammed. Sometimes, the frequent electrical power fluctuations also is a reason for it. I do have this problem in toshiba e studio 166 printer. After sometime, it gets alright by itself. The reason is not exactly known to me. Mostly the problem is coupled with paper jam.
Sep 03, 2013 | Toshiba e-Studio 350 Copier
My Toshiba E-Studio 650 is displaying a paper jam in the copier. I have removed all paper jam and I have replaced sensor. What am I missing?
There are other sensors to check or verify that there is continuity in the wires of the sensor that you've removed
good luck
Apr 24, 2012 | Toshiba E-STUDIO 650 Copier
REMOVED PAPER JAM
There should be 2 switch actuators sticking up underneath of the toner cartridge, maybe one got knocked off?
Mar 30, 2010 | Panasonic PanaFax UF-8000 Laser Fax
Paper Jam J43
One of the switches under the toner cart is knocked off.
Aug 09, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Misfed document feeder
Jan 20, 2009 | Toshiba e-Studio 205 Copier
Panasonic UF7100 J43 misfed paper error code
Did you pull out the toner cartridge and look?
Pull out the paper casstte, above that is a pull down access plate with a green handle.
Jan 08, 2009 | Office Equipment & Supplies
Toshiba fax #DP 125F
Open the top cover.
Remove the toner and drum cartridge. Where the paper comes out you'll see a cover for the fuser held by two screws. Remove the screws, pull straight up to remove that cover. The fuser is there.
Check the eject switch actuator. mounted on top of the fuser, it might be broken.
Sep 26, 2008 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
UF-8000 J43 Jam (Not There)
turn it around and have a look in the back panel that opens, open all other covers and check that any of the small black sensor levers are not stuck down they shoul all spring back
Apr 17, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Paper Jam
hi im jules_09.have you reassemble the fuser correctly?check again the inside of the machine for small pieces of paper its just there the machine wont flash the misfed if there is nothing stock in the machine.although sometimes the drum can cause the misfed,try to full out the drum.it cant be stock just see if the drum is rotating try to rotate it 360 then slowly full it out,also check if there are srews where the drum process unit is at
Oct 12, 2007 | Toshiba E-STUDIO 650 Copier
E studio 16
Oct 11, 2007 | Toshiba e-STUDIO 16 Printer
Toshiba EStudio 170f Fax 170f Logo
231 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
