Question about Nintendo Wii Fit - Balance Board + Game Console
Haven't used my balance board for a while now and the power will not stay on. Have carried out all the instructions in manual to remedt it but no luck.
  • 4 Answers
I STEP ON MY WII FIT AND IT CRACKED WHAT SHOULD I DO AND I THOUGHT THEY SHOULDNT CRACK
Posted on Sep 28, 2010
After we switch from the auto to another manual mixing board the volume on one of the mics is decreased dramatically. all other mics are not effected. both boards are linked and we have a toggle switch to...
Check the cables. If one lead of an XLR-XLR cable is shorted to ground, 6 DB gain is lost. You haven't really supplied enough information regarding cables and model of the manual mixer for us to help much. Do check that ALL of your audio interconnections are BALANCED lines either XLR to XLR or TRS cables. Grounding one side of a balanced line reduces gain 6 DB. Try swapping mic cables and channels to test where the problem is in the system.
Aug 31, 2011 | Shure Distribution Shure SCM810 8 Channel...
I JUST FOUND MY JABRABT350, I HAVEN'T SED IT FOR OVER 3 YEARS. I CANT FIND THE MANUAL AND OR INSTRUCTIONS. I DONT KNOW IF IT CARRIES A BATTERY OR WHAT CAN YOU HELP ME
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Jul 06, 2011 | Jabra BT350 Bluetooth Headset Headset
My New Balance 1400 treadmill recently stopped working. There is power going to the motor. The lights are on but there is no power to the display. nothing lights up and none of eh controls work. The...
It sound like either the wire harness that goes to upper console is bad or the Motor Control Board that has the 5v or 12v is missing. Here is the bad news New Balance is out of the Treadmill business and do not carry these items anymore. Their might be one other thing you might try is that if this unit was not maintain as owner's manual suggests, then the fuse may have open up. You must open the motor shroud locate motor control board find the fuse, if you have a multi meter check continuity of the fuse if open replace it with the same value ( maybe 15amps). Plug unit in if the display returns then proceed to do the prescribe maintenance in owner's hopefully that the belt and deck was not damaged when it went dead.
Good Luck!!
Max
May 09, 2011 | New Balance 1400 Treadmill
When i click the button on the wiifit board to connect to the wii, it connects at a second. then loses connection and wii says it is lost. the button on the board just keeps flashing or goes off
If you haven't already tried to replace the batteries, do this (if you have, this is useful information to include in your problem description :D). If that hasn't worked, you may need to re-sync the board with your Wii.
1. Power on your Wii console (there is no need to power on your balance board at this time).
2. Open the SD card slot cover on the front face of your Wii to reveal the red Sync button on the Wii.
3. On the bottom of your balance board, remove the battery cover to reveal the red Sync button on the balance board.
4. Press the Sync button on the balance board (there is no need to keep it depressed; simply press and release). You will notice the power LED on the power button on the balance board blinking.
5. Now press (and release) the Sync button on the Wii console. After the LED stops blinking, the Sync is complete.
If this does not fix your balance board, it may need to be repaired or replaced. Contact Nintendo and provide warranty information if applicable.
May 04, 2011 | Video Game Consoles & Games
How do you sync the wii fit board and wii console
  • Put four AA batteries into the battery housing located on the underside of the Wii Balance Board.
  • Insert a Wii Balance Board compatible game into the Wii system.
  • Select the "Disc Channel" on the screen with the Wii remote, and choose "Start."
  • Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons.
  • Turn the Wii Balance Board upside down.
  • Remove the battery cover under the balance board to reveal another sync button.
  • Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady
  • Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
  • Mar 03, 2011 | Nintendo Wii Console
    My wii fit balance board keeps blinking but will not stay on. batteries are good. cant find my instruction book. what could be my problem????
    follow this
    1. Insert a Wii Balance Board compatible game disc in the Wii console.
    2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
    3. Open the small SD Card slot cover on the front of the Wii console.
    4. Remove the Battery Cover on the bottom of the Wii Balance Board.
    5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
    6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
    7. The blue light will stop blinking and stay on steady once the syncronization is complete.
    Jul 20, 2010 | Nintendo Video Game Consoles & Games
    My wii balance board wont stay on
    First thing to do is install fresh batteries.If the Wii Balance Board is still experiencing power problems after trying new batteries and ensuring that they are inserted correctly, please call 1-800-255-3700 for assistance
    http://www.nintendo.com/consumer/systems/wii/en_na/ts/balanceBoard.jsp
    Apr 07, 2010 | Nintendo Wii Fit - Balance Board + Game...
    Balance board on wii fit doesn't turn on? power light flashes
    All i had to do was SYNCHRO the board by pressing the synchro button on the wii balance board were the battries go, the power LED will blink (note once the power LED has started blinking, stop pressing the synchro button)
    THen you need to press the synchro button on the wii console, while the wii balance board's power LED is blinking
    Oct 17, 2009 | Nintendo Video Game Consoles & Games
    Please step off press A - constantly repeated - why???????????
    If the Wii Balance Board fails to operate, or operates incorrectly, follow the steps below before seeking
    assistance.
    A. Check the batteries.
    B. Check to be sure there is nothing pressing against the bottom.
    C. If you are using it on soft carpet, put the foot extensions on.
    1. The Wii Balance Board does not respond.
    • Make sure the power is turned on. The blue Power LED should be lit if the Power Button has been
    pressed. (The Power Button faces away from the TV.)
    • Make sure the board has been placed correctly (see page 6).
    • Make sure the batteries have been inserted correctly and are not been depleted.
    • Make sure the game you are playing is compatible with the Wii Balance Board.
    • Review the synchronization procedure on pages 7-8 and make sure this has been done correctly.
    This procedure must be done for each Wii Balance Board compatible game.
    • If, after verifying the steps above, the Wii Balance Board does not work, try the following:
    1. Turn off the power of the Wii console with the POWER Button on the front of the console.
    2. Unplug the power cord from the wall outlet for a few seconds, then plug it back in again.
    3. Turn on the power of the Wii console.
    4. Repeat the steps in this Operations Manual for setting up the board.
    If the Wii Balance Board still does not work, follow the information at the bottom of this page.
    2. Control of the Wii Balance Board is inconsistent or seems incorrect.
    • Review the Instruction booklet for the game you are playing to make sure you are performing the
    correct actions for that game.
    • Try using the Wii Balance Board foot extensions if you are using the board on carpet (see page 10).
    • Make sure there are no people or other objects between you and the Sensor Bar.
    • Avoid interference from other devices. If communication seems to be affected by other devices
    (wireless LAN, microwave ovens, cordless devices, computers) move to another location if possible,
    or turn off the interfering device.
    If the Wii Balance Board still does not work, follow the information below.
    If the Wii Balance Board still does not work, an operational check procedure is available
    in the Options Menu of the game you are playing. See the Instruction booklet included
    with the Game Disc for more information. If your Wii Balance Board does not operate
    correctly after all of the above steps, visit support.nintendo.com for assistance and
    additional troubleshooting and repair options or call 1-800-255-3700.
    Jul 19, 2009 | Nintendo Wii Fit for Wii
    Power led light
    If there is no reason for the Wii Balance Board to be on, it will automatically turn off. Start up a game that uses the Balance (Wii Fit) and it will tell you when to turn on the Wii Balance Board. If you still have problems, try to sync the Balance Board again.
    Aug 29, 2008 | Nintendo Wii Console
    Nintendo Wii Fit - Balance Board + Game Console Logo
    180 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
