Question about Sharp Office Equipment & Supplies
We have the Sharp FO-5700 and for some reason it has quit printing on legal size, everything is being cut off to letter. I have looked in the manual but find no answer, Please help.
  • 24 Answers
Please reset the paper type setting on the printer menu, and check teh tray setting
Posted on Sep 28, 2010
  • tina245 Sep 29, 2010
    These settings are not posted on my machine or in the manual:(
When in automatic tray select, printer will not
I would try reinstalling the Vista driver, then turn the printer off and on and reboot. No guarantees but it's worth a shot if you haven't already done it. Good luck!
Mar 08, 2010 | Brother HL 5150 Laser Printer
Printing duplex and legal size.
I don't have legal size paper to test this with so it's a theoretical point but it looks like the printer will not do duplex in anything other than:
  • A4
  • Letter
  • B5 (JIS)
  • Executive
You can always print in duplex manually which is always an option regardless of paper size.
Hope that helps.
Mar 02, 2009 | HP Officejet Pro L7680 All-In-One Printer
Scanned legal doc to email comes out landscape and prints on lett
select scan mode, then select legal on paper select. If you select paper before loading document into the ADF it should go with the size you enter.
Jan 07, 2009 | Sharp AR-M550N Copier
Sharp FO5700
I have never seen this error code on a sharp FO 5700 are you sure that is the right model # or error code. I even did a search in the FO5700 service manual(no luck). I believe I have seen this code before on a sharp copier.
Sep 05, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
CANON IR2000 CANT PRINT MORE THAN 1 COPY
You just stated the problem yourself!!!!!!!!!!!!!!!!!!!!!
Are you using Letter or Legal?? then the tray need to be set to that particular size.
If using Legal set to Legal, otherwise the machine will automatically know you are using the wrong size.
Aug 14, 2008 | Office Equipment & Supplies
How do i get my printer to print a legal size copy
In your printer settings as you hit print
select the printer setting prefferences
select paper size( change from letter to legal) and your problem is solved
When you copy through the software program from brother you can change this in there. Just redo the prefferences.
Apr 28, 2008 | Brother MFC 8500 All-In-One Laser Printer
37 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
