Question about Hotpoint WMA46 Front Load Washer
Noisy machine? What could be the problem - Hotpoint WMA46 Front Load Washer
    Passionate:
    Visited the website for 10 consecutive days.
  • 114 Answers
  1. machine not level
  2. bearings hammered
  3. broken shaft
  4. loose counter weights
  5. noisy pump
  6. something stuck between inner and outter drum
Posted on Sep 28, 2010
Why is that machine so noisy, can you suggest another model less noisy?
Annette, your machine may not be leveled correctly, causing excess vibration and noise, have it checked before getting new. below are links to advertised quieter models.
to show your appreciation press the helpful button and follow me on fixya for more tips and info.
Washers Dryers Washers
Matching washers and dryers quiet enough for the main floor
6 Best Washing Machines in 2016 Buying Guide
Washing Machines
Feb 15, 2016 | Washing Machines
Washing machine noisy during wash cycle
all washing machine are noisy it depend on brand but it is on all specially in small room or space
Mar 31, 2014 | managemylife.com
Its very noisy when its spinning
if it is very noisy there are things to check. 1 if the transit blots at the back have been removed. 2 that the machine is secure on the floor and level. 3 that the machine is not overloaded. this should solve most noisy hotpoint washers. if it is still noisy after checking all this the motor is on the way out or the drum. but most of time it is just the transit bolts and that the machine is not level. hope this helps.
Sep 19, 2010 | Hotpoint BWM12 Front Load Washer
Hotpoint aquarius wf620 washing machine,machine very noisy when in high spin working ok when golng through program
While spinning every washing machine is very noisy as it rotates in very high speed.This is normal and no need to worry.
Thank You
Sep 08, 2010 | Hotpoint Washing Machines
My machine gets very noisy shen sewing. But if the bobbin plug is up, its normal. Not sure what happen to it.
Try changing the needle - a dull one will cause noisy sewing and will make your machine work very hard. if you have tried that - sorry!
Feb 12, 2010 | Sewing Machines
It makes a loud whining noise when it is on the spin cycle. Functions ok, but sounds like it is a jet engine...
Hello there: Here is a extensive list of things to look at and hopefully this will be very helpful for you Washing machine is noisy It's very difficult to advise on a noisy washing machine because you often can't describe noises accurately enough. People can describe the same noises quite differently. Please visit the following link for a detailed list of ways to help with your noisy washing machine. http://www.washerhelp.co.uk/diy-repair-help_2.html#cl_q4
Dec 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine really noisy on spin!
Probably main drum bearings worn
If you turn the drum by hand and it feels rough or noisy ,then definately bearings worn and noisy.
Nov 19, 2008 | Washing Machines
LG direct drive washing machine is getting increasingly noisy when at the spin stage
generally when a machine gets noisy in spin cycle it is due to bearings being worn open the door with the machine empty and try lifting the the drum upwards if it moves then it will be the bearings
Jul 12, 2008 | Washing Machines
VERY NOISY WASHING MACHINE
The bearings are going, repair cost aroung the 100 pound mark
Oct 19, 2007 | Hotpoint WMA50 Front Load Washer
Wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Sep 25, 2007 | LG WD-16110FD Front Load Washer
Hotpoint WMA46 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
