Question about Epson Stylus CX3200 All-In-One InkJet Printer
Scanner we have installed the driver, and the printer works, it will copy, but when we try to scan anything, nothing happens, what can i do?
  • shephardess Jun 01, 2008
    Thanks for all the help, it's now working. Best wishes Lynne
    Guru:
  • 1,342 Answers
  • Georgia B
    Georgia B Jun 01, 2008
    Glad to hear you got it working.
    Thanks for voting.
Copy and Scanner not responding
Copier may require you use the scan feature to make copies either ise the feeder otr flatbed. Press start on machine for manual entry but still use scan to get things working.
Nov 15, 2013 | HP HEWLETT-PACKARD CN583A Officejet 6700...
The scanner function on my Canon D480 has not worked since the installation.
Go to the scanner company website and see if there are drivers available for download. Sounds as if you may not have the proper drivers installed.
Jan 07, 2013 | Canon imageCLASS D480 Black and White...
Canon mp550 will not scan
use a different scan mode,like the one that came with computer
Apr 28, 2017 | Canon PIXMA Office Equipment & Supplies
My Kodak ESP 3 Won't Scan
Did you install the full software driver for the all-in-one? The drivers are here: http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/12666/12667&product=EKN034524
Next try a new USB cable and plugging the unit into a different port. If you use a print server or USB hub, try connecting directly to the computer. Scanners need bi-directional communication with the computer and thus are likely to have issues even if the printer doesn't.
Can the scanning software on the computer initiate the scan? (That is in the full software package. Alternatively Vista came with Paint and File> Import from Camera or Scanner > New Scan.)
I hope this helps.
Apr 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
It will not scan, prints, copy, but not scan
hi... have some idea about your problem... maybe u should try this... try to install your twain driver of your printer first then next is the scanner driver... then you'll fing what will happen next... thank you very much...
Jul 21, 2009 | HP OfficeJet 6110 All-In-One InkJet...
MP 160 Cannon Printer Won't Scan
try checking if you have completely installed all the drivers for your printer. scanning and copying dont usually needs drivers because you can do that even without a computer. but scanning requires your scanner to be read by your pc. try checking for the scanner driver from the cd that came from your printer.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Scanner malfunction
JTuohey
I had the same problem and just successfully repaired. Uninstall driver and reinstall. Worked perfectly!! Good Luck!!
Jun 23, 2008 | Dell A960 All-In-One InkJet Printer
Lexmark x6150 wont scan
Sounds like your laptop isn't talking to your scanner. These scanners only work if it has access to a computer to store the scanned image. Check if your USB drivers are installed. Most times you can go to "Device Drivers" in Control Panel (Under the "System" icon) and right click USB to update drivers on the net. Depends how old your laptop is too. If that isn't the problem, try installing the drivers again, or search the net for newer versions.(Usually at the Lexmark site). But at the end of the day, you won't be able to scan till your laptop can recognize your Lexmark printer!!!!
Feb 14, 2008 | Lexmark X6150 All-In-One InkJet Printer
Hp 3380 scanner issue
I SUGGEST DELEATING SCANNER FROM YOUR SYSTEM AND RELOADING THE SCANNER DRIVER FROM THE INSTALL DISC THAT CAME WITH YOUR SCANNER
Feb 02, 2008 | HP LaserJet 3380 All-In-One Printer
HP F380 not scanning
This has happened to me on several occasions with a couple of different HP all-in-one scanner/printer's. The HP driver/program itself may be in a phase where it's attempting to complete a scan, which would prevent you from scanning anything else. You can confirm whether or not this is the problem by restarting your computer and attempting another scan. You'll get an error message saying the scanner is currently in use. You may want to try to completely remove the installation files for the scanner, and reinstall either from the disk or let windows install it for you via "plug and play". Then update the drivers from hp's website. See if that resolves your problem.
Oct 05, 2007 | HP DeskJet F380 All-In-One Printer
Epson Stylus CX3200 All-In-One InkJet Printer Logo
27 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
