Question about Cisco WAP200 802.11b/g Wireless Access Point
Cannot access the config menu. I've tried the default IP both connected and wireless. I've reset the unit still nothing. I can get on the net so it works in that aspect but I can adjust anything. Help!
    Brigadier General:
  • 10,406 Answers
> I've reset the unit.
After doing so, make a "wired" connection from the network-port on your computer to one of the LAN ports on the router.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like:
Default Gateway....192.168.123.456
Note: use your values, not '123.456', in the next line.
Open Internet Explorer, and enter: http://192.168.123.456
Login as 'admin'
You should now see the "config" menu.
Posted on Sep 28, 2010
  • stephanou Sep 28, 2010
    I don't get a default gateway for either. My wired reads:
    the default IP with a subnet 255.255.255.0
    The wireless reads
    169.254.200.205 subnet 255.255.0.0
  • ikkenom Sep 28, 2010
    The '169.254.xxx.yyy' IP-address is a "place-holder" that Windows generates.
    After the hitting ENTER following the 'CMD', type IFCONFIG /RENEW
    to get a _valid_ IP-address from the router.
    Again, look for that "default gateway" output.
    If you're using any "firewall" software (like Norton Internet Security), disable it
    before trying that '/RENEW' command.
    Or, try restarting the computer, which also should do a '/RENEW';
    maybe, N.I.S. will "allow" the response from the router, during start-up of your PC.
Need security key for linksys router
If it is your router your trying to access try these https (only necessary to try second one if first doesn't work)
these are the network/password config for linksys
http://192.168.1.1
http://192.168.0.1
May 06, 2011 | Linksys WRT54G2 Wireless Router
I want to factory reset my nortel AP 7220, how do I reset? What would be default IP after reset?
There is probably a reset button somewhere on the device, it is probably a small pinhole that you put a paper-clip into the reset.
If it has its own http web page, there is likely a reset to factory defualts option.
The ip of the computer connecting to it should not change.
On a computer connected to it, open cmd start>run then type in cmd, and type 'ipconfig'.
It will display details about your connection. Where it says 'default gateway' is the ip of the device.
You could try to put the ip in your browser and see if the device has a web page.
May 02, 2011 | Nortel Networks 7220 (NTE350BG) 802.11...
I want to reset using RS323 port , i forgot its ip adress
Hi
You can reset the device through RS232 port then please follow the below steps.
You need a laptop with Console port and a console cable for EOC-8610 EXT, You really dont need the IP address if you want to do it via console (RS232) interface.
1. Connect the console cable one end to EOC-8610 EXT RS232 port and other end to Laptop serial port.
2. Open Hyper terminal and select com-port option and then provide the username and password for the device management.
3. Go inside the system menu and select Reset Factory default.
Remember if u set to load the factory default settings, the device will loose its config and will boot up with factory default configuration.
Nov 03, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
Netgear access point cant open configuration page
Typically you should be using configuration software until a real IP can be setup and you either address it statically or turn on DHCP. As for the gateway and other information, on a wireless gateway, it should all be routed through the network. Also, I think you have to be wired to the WAP to access the config page, I don't believe it can be seen over the wireless connection as a security feature.
Aug 02, 2010 | NetGear WG602 54Mbps Wireless G Access...
D-Link G700AP partially reset, won't return to Factory Default.
TRY THE RESET AGAIN .... UNPLUG EVERYTHING .....HOLD RESET BUTTON IN FOR A GOOD 10 SECONDS ....PLUG UNIT BACK IN AND OPEN YOUR IE EXPLORER SITE ...AS IF YOU WERE GOING TO GO ON THE INTERNET ....IN THE ADDRESS BAR ...TYPE IN ...192.168.1.....THIS SHOULD GET YOU TO THE SET-UP PAGE .....GOOD LUCK
Jun 02, 2009 | D-Link AirPlus G DWL-G700AP Wireless...
Can't connect to configure password through web address 192.168.0.50
When you reset the AP, how long did you press the reset button? To reset the AP to factory defaults, the reset button should be pressed and held for at least 15 seconds. Also, once reset, the AP should have the following settings:
IP address: 192.168.0.50
Subnet Mask: 255.255.255.0
Default admin username: admin
Default admin password: <blank>
When connecting your PC, either set an IP address within the same subnet (192.168.0.51 255.255.255.0) or choose "Obtain address automatically".
I hope this helps.
Dave Grannas
Jan 25, 2009 | D-Link AirPremier DWL-8200AP 802.11a,...
Problem to connect to my wireless after formatting
check ur ip address using ip config.../release the ip address once..and type ip config /renew in cmd prompt...after reseting ur router..check whether ur led in the router,DSL or uplink is buring continously..if not it blinks slowly or a sec of interval..it may ve some problem with the ISP..if i come 2 know ur IPS provider it ll b more helpful for me 2 help u...
Jan 16, 2009 | D-Link AirPlus G DWL-G510 802.11g/b...
Please help! d-link airplus xg dwl 2100AP
Once reset right click on the connection in the task bar ( icon with two computers) click status, click properties, scroll down and select Internet Protocol (TCP/IP), click properties, click use the following IP address:, and add the following:
IP: 192.168.0.66
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
Click OK, OK, and Close, Now Enter 192.168.0.50 in internet explorer and it will work.
Hope this Helps
Tech
CCNA, CCSP, MCSA
Mar 23, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
DWL-2100 AP will not reset to factory defaults with reset push. Ideas?
IP: 192.168.0.66
Click OK, OK, and Close, Now Enter 192.168.0.50 in internet explorer and it will work. You can now change all the settings you wish to.
Hope this Helps
Admin
CCNA, CCSP, MCSA
Dec 28, 2007 | D-Link AirPlus Xtreme G DWL-2100AP...
Cisco WAP200 802.11b/g Wireless Access Point Logo
517 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
