Question about Norelco Micro 4417 LC Electric Shaver
Trying to put shaver head back on to razor , cant seem to fit the blades back on the body properly there only 3 parts a spring a washer? and the screw cap what am i dooing wrong?? thanks u
  • Norelco Master
  • 1,623 Answers
You will find an instructional video that may help at shaveroutlet.com. See link below and scroll down for video
http://shaveroutlet.com/specials/norelco-philips-hq4-plus-replacement-heads-also-fits-eltron-p-248.html
Posted on Sep 29, 2010
Putting a wahl 9307 back together
You will notice there is a little hook that the spring thing fits into on the device. You want the smaller part of the spring facing upwards and it should tuck in smoothly.
This is the smaller part of the spring facing upwards:
Then it gets tucked in as such:
Take note from the above photo that the square edges on the plastic piece go at the top of the blade piece and the rounded edges are at the bottom.
Then the bottom blade piece rests on top with the curvature facing upwards: putting-wahl-9307-back-together-g0fa4lo4hxabacpjggd4qk4j-2-5.jpg
The rest should be straightforward!
Jul 10, 2014 | Wahl 9307
What is an electric shaver?
Not like shaving razors, electric shavers work by shearing the whiskers, the hair enters the perforated metal heads of the shaver and is cut by the moving blade inside.
Feb 06, 2013 | Health & Beauty
I have a Philips Norelco 7310XL razor and I have a problem. I recently moved, and in the process, something happened, and my razor isn't working. When I turn the razor on, the blades turn slightly and then...
It sounds like maybe one of the blades is damaged and it is jamming the whole thing. Try taking apart the head assembly and then insert each head one by one turning the shaver on in between each one. This should identify if one is damaged and causing the problem
If you require new heads, you will find them at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
Sep 18, 2010 | Philips Norelco 7310XL Electric Shaver
I have a Norelco model 7315 razor that I purchased in October 2009. In the last five weeks, in spite of being cleaned regularly, it developed a very unpleasant must odor that seems to emanate from the body...
It is very unlikely that the smell is coming from the body of the shaver. Have you completely removed the heads and thoroughly cleaned them individually with alcohol or shaver cleaner? If you are simply rinsing the blades under the faucet and have not removed them and thoroughly cleaned them, this is almost certainly the problem. The smell is decomposing hair and oils from your skin.
You may want to consider using a shaver cleaning product like the ones linked below from shaveroutlet.com
http://shaveroutlet.com/norelco-al80-razor-lubricant-spray-p-255.html
http://shaveroutlet.com/shaver-accessories/eltron/eltron-parks-shaver-cleaner-p-737.html
Jun 29, 2010 | Norelco Rechargeable Cordless Men's Razor...
New head
Hello Brian, You can give the folks at www.electricshaver.com a try. They typically stock all the replacement and repair parts for most brands of electric shavers.
Here's a link to their site where you'll find part #5646768 for about $38 for a new set of the cutter head and foil (screen). It's always best to replace BOTH the foil and cutter block (head) at the same time, as any mircro burrs or nicks in the cutter blades will quickly ruin any new foil screen.
http://www.electricshaverstore.com/get_item_5646768_braun-foil-cutter-kit-360-complete-8000-series.htm
As you know, this is the simplest and easiest way to get an electric shaver back to a "like-new" shaving experience.
I hope you find this Very Helpful and best regards!
Nov 11, 2009 | Health & Beauty
I dropped the razor and the 3 heads fell off, nothing is broken, but I can't figure out how to put it back together Help!
all you have to do is put them back in there place you should have two legs that spring out from the blades align them with the 2 holes on the shaver and push them in
Oct 21, 2009 | Philips Philishave HQ8150 Electric Shaver
Plastic retainer for the shaving blades is broken
You can buy a replacement shaver head and screens from an Oklahoma shaver business, electric shaver company.
Here's a link to their site and the page for the Norelco shaver you're looking to get parts for. The 3rd item down is the shaver head and screens, blades, etc.
I don't think you can get just the plastic retainer all by itself, as the manufacturer makes a complete head and blade as a replacement set, however, you can call them to see if they have just the retainer part you need. But frankly, it's likely a good idea to change shaver heads every so often to get the best shave, etc., so you might just want to spring for the complete replacement assembly part #HQ9 on this site for under $40.00.
http://www.electricshaverstore.com/get_list_143.htm
Hope you find this Very Helpful and best regards!
Sep 22, 2009 | Norelco Replacement Razor Heads for ...
The razor head comes loose from the two arms.
The one piece motor drive which also contains the shaver head in the Braun wear out. They can be replaced by yourself or a shaver tech. A good place for parts, http://shaveroutlet.com/.
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
May 27, 2009 | Braun Syncro 7526 Electric Shaver
Fell apart..help please!!!
The larger white pieice that has holes in it should be connected between both the spring and the smaller razor, The bottom of the larger white peice has to be able to fit in the peice of medal that moves in a circular motion inside the top part.
First, Try to make the hooks of the spring go in pretty securly inside the small holes. The flat side of the white peice has to be connected to the flat side of the smaller razor. They should kinda snap together on the top hole. I had to gently place the parts together and push the larger white peice in the medal by placeing the larger razor peice right on top and pressing down really hard. You might hear some snapping but the peices should all connect together and the large medal peice should connect to the black groves and press hard. Hold in place while putting the screws back in.
Jun 21, 2008 | Conair GMT182CS
Norelco Micro 4417 LC Electric Shaver Logo
69 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
