Question about Linksys Wireless-G WRT54G Router
Connection keeps going on and off
Well here's my problem I have a wireless router hooked up to 3 pc's in my house I can get onto the internet on the pc downstairs but not the 2 upstairs. they all shair the same network. I've tried restarting the router and that didn't do anything. I was browsing the internet upstairs when all a sudden the computer shutdown instantly. I log back on and can't get back onto the internet it says i'm connected tho and same with the other computer upstairs. When I look at the router it shows the three green lights all flashing when I try to start internet up. sometimes the lights are really dull sometimes they are bright. and the computers are shair the same network. I need help :(
  • 1 more comment
  • adambomb494 May 24, 2008
    Anyone know :(
    yes it's hot so just turn it off?
    yes its warm but i'm still connected downstairs.. i don't get it
    Problem Solver:
  • 8 Answers
Are you in Windows?
Click start then click RUN
Type cmd in the box and press Enter
Type ipconfig /all press Enter This should show your network settings.
Type ipconfig /release press enter you should see as address.
Type ipconfig /renew press enter this should force the computer to get a new ip address from your router.
Posted on Apr 02, 2009
  • 3 Answers
Check the ip addresses with the pc downstairs and see if all the pc's have the same default gateway. If not check your network card or network cable.
Posted on May 25, 2008
Keep getting kicked off
when sharing internet connection, it's all about sequence when turning it on... Sequence in regard to what's turned on first, second etc... Here's the solution:
1. Turn everything off... modem, router...computers etc..
2. Turn on the wireless router FIRST and let it boot up.
3. Then turn on the modem and let it cycle up...
This allows your modem to lock onto the wifi router.
4. Turn everything else back on...
You should be good to go without drop outs...
If the power goes out, simply follow this sequence...
It's all about the sequence!!
May 31, 2010 | Belkin N Wireless Router wireless router
The router is running fine all hook ups are fine changed the wireless card took that to a computer place and it was running fine at the shop when I got the pc home unable to access the internet even though...
The cable internet is not "seeing" the computer. The router is blocking it. That is why it works if you plug it into the modem directly. How to solve this is to turn everything off and unplug power to modems and routers for 3-5 minutes. Then replug in routers. Then restart computers.
That is why it worked at the computer store. Everything was shut down and restarted.
Also, sometimes it is necessary to call the ISP (for example Comcast) and have them re-send the signal. Also going to Control Panel Network Connections and choose "repair the connection" will reset the signal.
Be patient it will work.
Aug 15, 2009 | NetGear RangeMax WPN824 Wireless Router...
Linksys switch to new pc
Have you tried going to the Linksys Forums and asking this question, I had similar issues when we moved house and the guys over there were most helpful.
Jan 28, 2009 | Linksys Wireless-G WRT54G Router
3 netopia 2247 routers daisychained
How far are you running the CAT5 cables from house to house?   CAT5e only has a solid range of about 150ft, and anything near 100ft is pushing it.  You may also need to use CROSSOVER cables when plugging routers into other routers.
Also, who has the actual internet connection?  I'm assuming House 2 does.  One big problem is a router is your Gateway address.  And, if house 2 is the only one with a valid Internet connection (via DSL or Cable, etc), then the router in house 2 is the only "true gateway".  And, all 3 houses need to be in the same physical network (i.e. range or whatever), and all computers should have the same Gateway address...which would be the IP address of the router in House 2.
What you really need in this situation is 1 router and 2 switches.  Put the router in House 2 and put switches in House 1 and 3.  That would be the best way to handle this problem.  It would also end your connectivity problems.
Jul 11, 2008 | Netopia 2247NWG-VGx Wireless Router...
Wireless g wrt54g router
First of all, are you connecting with a PC or a Notebook?
If you have the Linksys router, you should replace the MS utility with the Linksys utility it figures your linksys wireless lan card
There are programs you can use to keep track of your router and connections...One such program is called Port Mapper...
Does your problem happen everday...or every 3 weeks...are you doing anything in particular when you are getting the inability to use the connection?
There is a new Vista patch out there I recommend downloading.
Feb 24, 2008 | Computers & Internet
Linksys wireless connection keeps getting dropped
From you DSL modem or broadband router, what is the next device connected?
Nov 27, 2007 | Linksys Wireless-G WRT54GS Router...
Connection Not Consistent
You shouldn't have to run the setup wizard to reconnect. It sounds like you just haven't configured it to auto-connect to that wireless connection. Right click on My Network Places and select Properties. Right click on your Wireless LAN connection, and tell it to connect. You should be able to go through those settings and tell it to auto-connect to your router as well.
Sep 09, 2007 | Linksys Wireless-N WRT150N Router
Blitzz BWA611 Router
a router shouldnt need to dial for a connection, go to open your internet browser and go to tools, then internet options, then click connections tab and select never dial a connection so as to stop internet explorer looking for a modem connection
Aug 30, 2007 | Blitzz Technology (BWA611) Router
Blitzz Router
Ah, you can no longer use the modem or the Blitzz screen to connect to your Internet connection. You'll need to patch another Ethernet cord from the router to your Ethernet port on your computer and it should automatically connect. If you still get prompted to dial, open up Internet Explorer and ignore any prompts to dial and then click Tools, then Internet Options, then click the Connections tab at the top, then click the selection to Never Dial a Connection. Confirm your choice by clicking OK and then try browsing the Internet like usual.
Aug 30, 2007 | Blitzz Technology BWA711 (B3WL000900)...
Linksys Wireless-G WRT54G Router Logo
223 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
