I HAVE NOT LOOKED INSIDE MY COMPUTER, BUT THE FAN BEGAN MAKING A LOT OF NOISE A MONTH AGO. TODAY THERE WAS NO NOISE AND A MESSAGE CAME ON MY SCREEN SAYING "FAN FAILURE- PRESS F1 TO CONTINUE. MAY I USE THE COMPUTERE WITH THE FAN NOT WORKING? HOW DO I GET THIS FIXED? THANKS, MICHAEL CUNNINGHAM
  • 493 Answers
First, if the CPU fan is not spinning properly, you should NOT run the system. The fan needs to be replaced.
If the fan is running normally, you may boot by pressing F1.
Before replacing with a new fan, you can first try re-seating the plug for the fan in your computer. The fan's plug may have been bumped or loosed. Re-seat the plug located at J1F1 as shown in the picture below and be sure that it is properly connected.
Hope this helps.
Posted on Sep 28, 2010
    Brigadier General:
  • 10,406 Answers
> fan failure -- press F1 to continue
It would be best to *NOT* press F1 -- get the fan replaced, ASAP.
Running without the fan can cause your computer to overheat,
and the heat can damage your computer, turning a $20 repair into a $200 repair cost.
My desktop computer will display anything when turned on, and the fan and hardrive both make a loud constant noise.
Maybe you need a larger power supply depending on if you might have added more hardware such as a graphics card, or an extra monitor to your system. This sometimes results in an inefficient supply of power, making your fan to your power supply work harder, thus making noise.
Nov 19, 2012 | Gateway Computers & Internet
Hp 2509m screen flicker
Hi Kevin,
My daughter has the same problem with her laptop, do you find that when you move the screen slowly back and forth it either stops or gets worse ?
You will need to take your laptop in to an HP dealer and let them have a look at it.
Regards :)
Feb 06, 2012 | Computers & Internet
I have a Dell Inspiron 1521. 6 months ago the fan makes a really loud noise when the laptop has been running for a while. It went in June to be looked at because my computer messed up and they had to redo...
Yes, the fan can be definitely be replaced. You can actually get a replacement fan for your computer at The Laptop Fan Shop online for about $22. The process of changing a fan is quite simple, so you should be able to do it yourself to save on labor. Although, if your computer is still under warranty you should contact dell directly at 1-877-694-3591 to see if they can replace it for you for free.
Sep 16, 2011 | Dell Inspiron 1521 Notebook
My crankshaft is very wobbley and make a very high pitched squeak
You need a harmonic balance. Very common problem!
May 21, 2010 | 1995 Geo Prizm
I bought the fridge in 2006. In 2008 it began making a loud vibrating noise. Repairman replaced the fan motor blade.Took 30 days to get part! It was never quite right after that. Had problems with defrost...
Could all be in the fan motor. If it's bad again, I would change the motor and blade. Then fire it back up and test for correct cycling.
That may take a week of running until you get a true picture of whats happening, but they do have a lot of trouble with the motherboard./
Jan 17, 2010 | GE Refrigerators
My computer is becoming really hot and noisy. After turning on the computer, everything is good (no noise). Once around 15 minutes passes by or I open up a lot of programs together, my computer starts...
Sounds like the fan is wearing out, as it heats up the fan needs to spin faster and if the bearings are wearing out it will start getting louder and it will also get hotter because the fan cannot keep up the heat being produced. You can replace the fan, most computer shops will carry replacements, also get a can of compressed air and give the inside of the computer a good cleaning. This will help keep things cooler as well. Also make sure that the air vents on the outside of the case are clear as well.
Jan 07, 2010 | Vantec Fan Vibration Dampener Noise...
I have a Frigidaire Upright Freezer making strange noise.
Check the condenser fan,m sounds like the bearings are failing.
Good Luck,
Gilsh
Nov 28, 2009 | Refrigerators
Window unit is not draining, tray is filling with water
Remove the unit from the housing. Using a special cleaner, called coil cleaner which you can purchase at any AC shop clean the coils, this should eleminate the problem.
Sep 08, 2009 | Kenmore 75085 Air Conditioner
Oustide unit fan won't work
It sure sounds like the out side condenser fan has gone out.If you need to Fix a water hose to run on it like a spray fanning out over the out side coils(condenser)and try and see if it will cool.It will do the trick,until you get it fixed on week days.If I can help,let me know.>>>roniecon@gmail.com
Aug 16, 2009 | Goodman CLQ36AR49 Air Conditioner
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
