Question about Weiser Lock POWERBOLT ELEC DEADBOLT
A beeping sound that lasts about 10-15 seconds every 30 seconds to minute.
  • 963 Answers
Http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Posted on Nov 10, 2011
What is the procedure to stop the beeping when wash is done. Not only does it beep it keeps on beeping every 30 sec.?
My one beeped every 30 seconds to tell me that the cycle was finished.It should stop itself after about 15 minutes,or just turn the machine off.
Jun 08, 2014 | Bosch Classixx WFL 2066 Front Load Washer
Had customer with CO detector sounding quick double chirp about every five minutes. What is this?
This is not a beeping smoke detector. It is probably a CO detector that was installed by your alarm company. GE model 240-COE will give a double beep every 5.5 minutes when the device reaches end of life. Call your alarm company to have it replaced.
Jun 07, 2014 | Kidde DC Voice-Alert CO and Smoke Alarm
Nuvico nvjv 4000 beeps and shuts off
sometimes these will go into an automatic sleep mode and will restart once you power it down and restart..
Jan 19, 2014 | Nuvico NVJV-4000N Video Recorder
The main unit beeps every 30 seconds
This is battery related. On top of your unit is a battery pack with three colored led lights. You can tell what is going on by looking at these. This information is in your manual or here it is.
GREEN LED: All systems are normal. A solid LED light indicates the batteries are fully charged. A flashing LED indicates the batteries are being charged. NOTE: Batteries do not have to be fully charged to operate the motor unit. YELLOW LED: The motor unit has lost power and is operating off of the BBU. A solid LED with beep, sounding approximately every 2 seconds, indicates the motor unit is activating the door and is operating off of the BBU. A flashing LED with beep, sounding every 30 seconds, indicates batteries are low. Once the power is restored the BBU will recharge. This is indicated by a flashing green LED. RED LED: An error has been detected and the BBU will automatically shut off. The BBU will attempt to restart by reconnecting to the batteries. If the error is still present it will shut itself off again. This process will repeat every 5 minutes or until the error has been resolved. This is used to prevent further draining of the batteries. If a red LED remains on when the power is restored, and is accompanied by a beep sounding every 30 seconds, please call for service.
Jan 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
There is a beeping sound that I cant diagnos. It
Someone may have lost a digital watch in the vehicle. Or you may have an alarm feature for a destination timer. See if the clock has a setting for repeat alert.
If you have an owners manual see what features you have for the trip computer or navigation unit. On the menu for the Command Control you have controls for the Horn to blow for setting the alarm, Park Assist, and Autolock for the doors. It may be on that menu for a clock alert.
Mar 27, 2010 | 2002 Mercury Mountaineer
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
77 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
