Question about Brother Office Equipment & Supplies
I have a Brother fax machine. When I dial a number to send a fax, there is a noise on the speaker in addition to the fax dialing and it defaults into a busy signal. What should I do?
  • 24 Answers
The number u are dialing is either busy or someting is wrong with the phone line thus not connecting to the other party. The fax set up may be confiqurated wronlgy.
Regards
Posted on Sep 28, 2010
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
I can't send faxes, the screen says telephone. It
You may need to dial a prefix prior to dialing the phone number you're trying to fax. It could be as simple as putting a number "1" prior to dialing the number.
Jun 26, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother Intellifax 4100 unable to send fax but can receive
Is the fax sensing the paper you put in to send out? Check the little black levers that poke into the document area. They should move freely when you touch them gently with a finger, and return quickly when you take your finger off. If it can't sense the paper it won't try to send a fax. If, when the paper is inserted, the display changes from whatever it said to anything else, the paper is being sensed.
Let's try dialing manually. Just left of the 1 key is a button labeled "Hook." Pressing that will take the telephone line "off-hook," like picking up the receiver of a phone. You should hear a dial tone -- if not, try adjusting the speaker volume with the buttons just right of the numbers. Once you get a dial tone, dial a number, whether it's another fax, or your own cell phone. As far as the phone company is concerned, your fax is just a phone, calling another phone. If you can make a call, and the phone at the other end rings, we're closing in on the problem. If you can dial another fax machine manually, you can still turn this into a fax call, assuming there's paper ready to fax. After the distant fax answers, touch the Start button, and your fax should take over. If you can't dial manually, try unplugging your fax from the phone line, and replacing it with a regular phone. Can you make calls with it? If not, the fax is no longer a suspect - you have a phone line problem.
Are you at a business where you need to dial 9 to get an outside line? It's easy to forget that detail when you're using a fax, but it has to dial out just like any other phone on the system.
If you can't get a dial tone at all with the fax, but it works with the phone alone, the main board in the fax is probably bad. If you can dial manually, using the Hook switch, but the same number doesn't work when you dial xxx-xxxx-Start, that sounds like a main board problem, too.
May 05, 2009 | Brother IntelliFax-4100e Fax
Faxing with a long distance code
after you dial the number you hit the pause button (usually 1-2 times) then dial additional numbers.
basically everytime you need the machine to wait for something to happen you need to hit pause
example: i have to dial five digit access code for my fax for LD calls it would be dialed on fax like this
1-234-567-8901 pause pause 12345 start
May 04, 2009 | Brother IntelliFAX 1170 Plain Paper...
Can not send out faxes
You have to get your phone line checked out .
Apr 28, 2009 | Brother IntelliFax-2820 Laser Fax
Cannot send fax with a proper working phone line hooked up
I have exactly the same problem! did you find a solution or reason???
Mar 19, 2009 | Brother MFC-9440CN Laser Printer
Programming Auto Dial Numbers
for what model is this? are you pertaining to numbers that you call or sending faxes? you can enter the numbers as a speed dial or 1-touch key on your brother machine.
Nov 17, 2008 | Brother IntelliFax-2820 Laser Fax
Fax machine stoped receiveing fax
First, check your fax's phone line. Put a regular phone on it and check for dial tone and line noise. If the line is dead or noisy, this will cause a problem.
You can also try dialing your fax number from another phone and see if the fax unit picks up the line and starts initiating communication. (sounds like modem noises)
Jul 30, 2008 | Brother MFC-7820N All-In-One Laser Printer
Press speaker can you hear dial tone?
Try ringing you mobile from fax does it ring?
After dialing correct number with (outside line prefix if required) press start
Oct 18, 2007 | Brother IntelliFAX 4100 Laser Fax
164 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
