Question about Acer Aspire 5610-4648 Notebook
When I switch on the laptop it will not run on mains power ,only battery power, however when i shut down the laptop the battery is being charged correctly,
    Guru:
  • 417 Answers
The power options have been changed,when it's on hover over the battary icon down next to the clock,it should say plugged in & charging if not right click on the icon & select power options & then select an option from the menu on the right,go through them all & change them to suit you or create a power plan of your own.
if this doesn't work then it's because the enpowering tech is controling the system so press the green "e" symbol at the top of your keyboard or on your desktop & select the battary icon the settings will be in their or in the settings tab,just have a look around you'll find it.
Posted on Sep 28, 2010
My wrless is not going to b turn on on windows 7 nd xp plz give me the sedation nd support for it
Critical battery switches off the wireless network card to preserve power. Motherboard seems to log this status but when re-connecting to mains power the card does not receive power again. Uninstalling the driver and getting Windows to re-install automatically upon re-boot does not work.
Charge up the battery whilst the computer is running. You can charge it to a substantial level, say, above 25%. Disconnect mains power so that your laptop is running on battery only. Set your wireless switch to OFF (this is usually to the left position, away from the orange indicator). Now run your computer down to the critical battery level again (perhaps overnight). In the morning when you press the power button, the 'CHARGE' indicator (looks like a lightning bolt) on the front of the laptop should flash quickly, indicating that there is no charge in the battery. Remove the battery from the laptop's underside. Wait a couple of seconds, then press and hold the power button for 30 seconds. Keeping the battery off the laptop, reconnect mains power. Boot up your PC. When at the Windows desktop and all your startup programs have finished loading, switch your wireless on (to the right position). You should now have a blue light, and wireless should once again be working. You can now re-insert your battery. You might have to setup your wireless network connection again as mine seemed to be 'lost', but at least hopefully the main problem is now fixed
Feb 08, 2011 | Computers & Internet
Laptop wont charge battery
its a comment fualt with laptops the micro switch that switches between charge and main power goes faulty on them, you could be acutally onto some thing here because ther eis alot of people with laptops that wont charge at all, and if they knew ur little sequence you got going on there maybe you could save their laptops been door stoppers.
Dec 01, 2009 | Dell Latitude D410 Notebook
Hello sir,my laptop is acer aspire 7520 no charging,no run on main,run on battry only,laptop power adaptor led is damage,
this could be due to the fault in the ac adapter,please try swapping another adapter if it works then you need to replace your adapter.
Jun 20, 2009 | Acer (ACERMOTHERBOARD)
BATTERY NOT CHARGING
Try replacing the battery, i think the battery is defective.
May 09, 2009 | Acer Aspire One PC Notebook
Wont charge while powered on or run on ac power
Sounds like a lose or burnt charge terminal.  Fixing would require disassembling the laptop and resoldering the loose or broken connections.  You might want to try a different AC adapter first.
Apr 21, 2009 | Toshiba Satellite A75-S211 Notebook
Power issues on HP DV1000
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Dec 03, 2008 | HP Pavilion dv1000 Notebook
I have a Packard Bell Easynote M5263. I turned it on yesterday and noticed it was running of the battery rather than the mains. when the battery ran out the cumputer shut down. The mains adapter seems to...
possible cause.... check to see if there is a voltage on the connector of the power connector to the laptop.
try disconnecting the battery from the laptop, and connect the power connector, if the laptop works then you know there is a problem with the charging circuits or the battery itself.
Oct 13, 2008 | Computers & Internet
Laptop compaq presario f500,running vista.Wireless is not working,Windows cannot load the drivers required for this device. (Code 31)
Matt Sydney Aug 4, 2008 00:28:44 GMT 10 pts
I experienced this problem last night, and seemed to have fixed it this morning.
SYMPTOMS: HP Pavilion dv9000, Win Vista x64 Ultimate. Running on battery, battery level became critical; windows went into 'Hibernate' mode. Upon plugging in to mains power, and resuming the Windows session, the Wireless is still disabled, no matter what position the switch is in.
POSSIBLE CAUSE: Critical battery switches off the wireless network card to preserve power. Motherboard seems to log this status but when re-connecting to mains power the card does not receive power again. Uninstalling the driver and getting Windows to re-install automatically upon re-boot does not work.
SOLUTION: Charge up the battery whilst the computer is running. You can charge it to a substantial level, say, above 25%. Disconnect mains power so that your laptop is running on battery only. Set your wireless switch to OFF (this is usually to the left position, away from the orange indicator). Now run your computer down to the critical battery level again (perhaps overnight). In the morning when you press the power button, the 'CHARGE' indicator (looks like a lightning bolt) on the front of the laptop should flash quickly, indicating that there is no charge in the battery. Remove the battery from the laptop's underside. Wait a couple of seconds, then press and hold the power button for 30 seconds. Keeping the battery off the laptop, reconnect mains power. Boot up your PC. When at the Windows desktop and all your startup programs have finished loading, switch your wireless on (to the right position). You should now have a blue light, and wireless should once again be working. You can now re-insert your battery. You might have to setup your wireless network connection again as mine seemed to be 'lost', but at least hopefully the main problem is now fixed.
Jamie Madriz Aug 8, 2008 01:58:15 GMT N/A: Question Author
Matt, i did what u said, and i'm happy because my wireless switch is WORKING! :) Hopefully it stays this way.
Sep 23, 2008 | Computers & Internet
Switching on the laptop
Try holding the power button down for about 10 seconds. Then try turning it on.
Next remove the battery and try to start with just mains power.
Next replace the battery in the computer and let it charge.
If this does not work you will probably have to contact Dell
Nov 15, 2007 | Dell Inspiron 6400 Notebook
Shuts down
Is this laptop brand new? Because normally, when you plug in the power adapter, the battery charges up to 100% and stays there UNTIL the power adapter is unplugged. Then it will start to run down its power. It's not supposed to run down with the power adapter plugged in. Also, if you take out the battery and only plug in the power adapter, it should work fine. If it doesn't, then there's a problem with the adapter.
Apr 02, 2007 | Toshiba Satellite P30 Notebook
Acer Aspire 5610-4648 Notebook Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
