Question about Schiller Cardiovit At 2 Light Ecg Machine
One of my stylus seem out of contact with the paper and printing lightly . If I place a finger on the unit above the stylus with light pressure It will record well. Is there a way to adjust the stylus or do we have to replace the stylus?
  • Schiller Master
  • 6,694 Answers
there is a pressur adusting facility inside for the thermal printing head. u can adjust it for quality printing. for adjusting the same i will prefer use the help of a qualified person.
ok
Posted on Dec 23, 2010
Red paper and ink lights blinking
red paper light is blinked as it is indication that plz insert paper in your printer, and ink light blinks because your printer is low on ink, kindly get your printer cartage refilled.
Mar 19, 2010 | Epson Stylus 1400 InkJet Photo Printer
It is printing but no image is visible; no lights
The print head nozzle may be out of ink. Do an ink charge or 3 consecutive head cleaning! Good luck!
Jan 14, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Schiller machine is not printing
If the unit print lightly or not printing anything at all?
The most common causes for not printing ECGs is one of those:
1- Too little heat on the stylus
2- Insufficient stylus pressure on the paper
Solutions:
1- Using an insulated probe, such as a screwdriver, gently press the stylus onto the paper.
2- If a dark line appears on the paper, the problem is too little pressure, but if no dark line appears, the problem is not enough heat.
Jun 19, 2009 | RTO Schiller CARDIOVIT AT-1...
Green light flashing Red light on
with regards to the status of the lights., its either the cartridges that you installed is not recognized by the printer's print head or cartridges are defective.
try these steps:
if all the inks are new take them out and get an eraser and rub the small chip gently so as to clean the contacts of the chip ( don't touch it with your finger ) reinsert the cartridges in the printer and allow it to charge.
Apr 07, 2009 | Epson Stylus C60 InkJet Printer
I have brought a replacement cartridge (black) for the Epson D92 stylus printer I folowed the usuel steps and sucsesfully printed 4 or 5 b&w pages now the printer does not seem to except the cartridge...
This may or may not work on your model
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
The Protection Counter referred to above prevents you from printing once the printed pages counter reaches a predetermined threshold.
If this doesn't work, let me know.
Regards,
Worldvet
Nov 11, 2008 | Office Equipment & Supplies
EPSON STYLUS PHOTO R 200
THE ROLLERS THAT PULL THE PAPER THROUGH SEEMS TO BE MESSED UP. WE HAVE TO REPEATEDLY RE-ADJUST THE PAPER, THE RED LIGHT FLASHES, OVER AND OVER AGAIN BEFORE IT FINALLY PULLS THE PAPER IN TO PRINT. ARE THE ROLLERS SHOT? DO WE NEED A NEW PRINTER?
Jun 30, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus R230 Light Magenta Not working
I would recommend cleaning the contacts (brass colored connections) with an eraser if might resolve the issue. It that does not resolve the issue it might be one of two other things. Either the printhead is cloged or the cable to the printerhead is damaged.
Good luck
Mar 03, 2008 | Epson Stylus Photo R220 InkJet Printer
R1800 printer problem
I fixed the problem, the PW and Ink Mark sensors needed cleaning. I was able to access and remove both sensors after removing the printer housing, and moving the print head to the far left. There's enough space to unscrew the cover for the sensors, and unplug them with needle nose pliers and a couple fingers, clean them both, dry them, re-install, etc.. all is well now after some re-alignment procedures with the epson factory service program.
Oct 22, 2007 | Epson Stylus Photo R1800 InkJet Printer
Online/error light
Pull out the toner cartridge. Carefully put your fingers into the opening just beyond the chrome roller. A little to the left of center you will fell/see a small black plastic finger which sticks up. It should be loose - push it forward and it springs forward, release it and it returns to the original position. If your paper jam catches this finger it can become jammed and will feel rigid. Put light pressure on it either pushing to the back or pulling forward until it becomes free again. Replace the toner cartridge, close the cover and your red light should go out.
It worked for me - hope it helps someone else.
Mary Lou
Aug 31, 2007 | Samsung ML 1610 Laser Printer
Hp psc 2175 all in one making knocking noise when i turn it on then gives me a error message on the machine display "scanner error, turn machine off then on" . i called hp and they told me it was a...
http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&cc=us&dlc=en&product=90809&lang=en Here is the HP site for any extra info you may need. ISSUE: Sometimes when printing out, the carriage makes an abnormal noise or its movement is erratic. SOLUTION: To solve this issue, follow the steps listed below: NOTE: The images and descriptions showed along the document might be slightly different depending on your HP All-in-One model. 1. Clean the unit front and back rollers. To do so, follow the steps listed below: 1. Disconnect the power cord or power supply from the rear of the unit. 2. Open the print carriage access door. 3. Remove the rear door and check it for damage. 4. Make sure that the paper rollers inside the rear access door rotate freely. Please clean them using a lightly moistened cloth. 5. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. 6. Allow the rollers to dry completely, and then close the rear access door. NOTE: Make sure the rear access door is correctly closed and placed. 7. Through the previously open cartridge access door, clean the front rollers with a lint-free cloth lightly moistened with distilled or bottled water. Please rotate the rollers with your fingers to clean all the way around. 2. Use a clean, dry cotton cloth to wipe the carriage rod. Move the carriage as needed to clean the full length of the rod. WARNING: Do not lubricate the rod. 3. If noise is located at the paper path, it may be caused by ink, dust or other residues stored over the pinch rollers. Please, clean the pinch rollers by using a cloth lightly moistened with alcohol. 4. The edge of the pitch rollers must be cleaned too. To do so, use a small drop of alcohol. This will remove the ink and will solve the issue. (see detail in the image below). 5. Clean the carriage contacts and the capping station. To do so: 1. Connect the power cord to your HP All-in-One product, and turn the unit on. 2. Lift the front of the HP All-in-One product just above the paper output tray as shown below. The print cartridge capping station will lower to allow access to the print cartridges. 1 - Print cartridge latch 2 - Capping station 3. Gently pull up the print cartridge latch front to release it. The latch is spring loaded and will spring upwards. Slowly raise the latch instead of letting it spring open. 4. 5. Remove each print cartridge by sliding it out of its socket, moving it toward the front of the HP All-in-One product. Do not try to pull it in an upwards direction. NOTE: If the print cartridge cannot be slid out, verify that the latch is raised, and the HP All-in-One product is on. If it is not possible to remove the cartridge, too much time may have passed since it was opened and the capping station may have raised again. Close the print carriage access door, wait five seconds, and then open it again to lower the capping station. 6. Extract the cartridges and clean the copper contacts with a watered lint-free cloth 1 - Copper-colored contacts 2 - Ink nozzles (do not clean) 7. Disconnect the power cord from the HP All-in-One product. 8. Clean the electric pins placed in the front of the print carriage using a lightly moistened cloth. 9. Using a dry cloth, clean the ink stored inside the capping station sponges (see the image below). 10. Mop up the electric pins completely, and connect the power cord again. 11. Turn on the unit, reinstall the cartridges, and close the print carriage access door. 12. If the noise issue remains unsolved, please perform a Power Cycle on the unit following the steps below: 1. Turn the unit off. 2. Unplug the power cord from the unit. 3. Wait 30 seconds, and then re-connect the power cord to the unit. 4. Turn the unit on. 13. If the issue persists, the unit may need to be reset. Please, consult the HP All-in-One Products - Performing a Partial Reset of the All-in-One document to learn how to do it. Additional steps (only for PSC 1100 & 1200 Series All-in-One products HP PSC 1100 & 1200 Series All-in-One products may be affected by this issue, due to the friction between the printing carriage and the paper. Please, print a couple of pages full of black text in Normal mode, and follow the steps listed below if the printed text looks like the image below: 1. Print a Self-Test Report and then, check the quality of either the text or the color bars. Follow these steps to print a self-test report: 1. Press and hold the Cancel and the Color buttons at the same time. 2. Release both buttons. 3. The Self Test Report will be printed. 2. If the media does not fit the weight specifications (see table below) or if paper is curled, then this may prompt the bottom of the ink cartridge to come in contact with the media. If this happens, the print will smear and the cartridge may become damaged. HP PSC 1100 & 1200 Series Type Paper Weight Plain paper 70 to 90 gr/m2 (20 to 24 lb.) Cards Up 200 gr. (110 lb.) Envelopes 75 to 90 gr. (20 to 24 lb. max.) Transparency Film N/A Labels N/A 4 x 6 Photo 236 gr/m2 (145 lb.) Custom Media 34 gr/m2 (9 lb.) 3. Make sure that the Paper Type is correctly set to either Plain or Photo. 4. Run an alignment of the print cartridges. To do so, follow the steps below: * HP PSC 1100 Series: 1. Turn on the HP PSC 1100 Series product. 2. Disconnect the USB cord from the unit rear. 3. Press the following sequence of front panel buttons to initiate the ink cartridge alignment: NOTE: The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds. 1. Press and hold the Cancel button. 2. While holding the Cancel button, press the On button. 3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons. 4. Press the Cancel button again. 5. Press the Resume button. 6. Press the Paper Type button. 7. Press Color Start Copy. The alignment page printing will begin. NOTE: If the alignment page printing does not start, please repeat the button-press sequence. 4. Once the alignment page is printed, place the page face down on the scanner glass and press the Scan button. The print cartridge alignment process is complete when the On light stops blinking. 5. Re-connect the USB cord to unit rear. * HP PSC 1200 Series 1. Turn on the unit. 2. Disconnect the USB cord from the unit. 3. Press the following sequence of front panel buttons to initiate the ink cartridge alignment: 1. Press and hold the Cancel button, and then press the On/Resume button. Then, release both buttons. 2. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons. 3. Press and release the Cancel button again. 4. Press and release the Copies button. 5. Press and release the Paper Type button. 6. Press and release the Start Color Copy button. The alignment page printing will begin. NOTE: If the alignment page printing does not start, please repeat the button-press sequence. 4. Once the alignment page is printed, place the page face down on the scanner glass and press the Scan button. The print cartridge alignment process is complete when the On/Resume light stops blinking. 5. Re-connect the USB cord to the unit. 5. Close the cover and press the Scan button. Wait until the alignment is finished. The On light stops blinking when the alignment is finished. Let me know what happens. Good Luck, Tim,
Mar 15, 2007 | HP PSC 2175 All-In-One InkJet Printer
Schiller Cardiovit At 2 Light Ecg Machine Logo
169 people viewed this question
Top Schiller Medical Experts
Electro Med Services...
Are you a Schiller Medical Expert? Answer questions, earn points and help others
