Question about E-Mu 1820M Sound Card
E-mu 1820m Windows 7 = No sound. I run Windows
E-mu 1820m Windows 7 = No sound. I run Windows 7 Ultimate x64. I recently was sent the e-mu 1820m with sound dock. I installed all of the hardware/software updated the drivers to the the latest drivers from e-mu and creative. I am now using the beta driver for windows 7 released on june 10th 2010. I have searched forums and sites like this one. I have tried changing the default to 44.1khz in both the sound devices panel and the emu patch mix dsp. I have un installed, re-installed, tweeked and finally reset everything to defaults. I have checked that the power connected to the pci card it is fine and the dock lights up. The timing clock is locked and it keeps connection. I have the E-mu set as my default sound card. Nothing I can do makes a sound. When I boot the computer on and the emu turns on it get the power on pop. Windows says everything is enabled and working properly. I beg to disagree. If I switch back to my integrated sound everything is fine. Except of course that i cannot record anything near the quality i need for vocals and music. heeeeelp!
SOURCE: emu 1820m all audiodock lights stay on
replace the mlan cable provided with a short length cat5 cable - this sorted out my problem.
The noise damping rings on the mlan where too much - the cat 5 cale is fine just keep it away from sources of noise such as high voltage cables, fans etc.
Posted on Sep 18, 2010
SOURCE: I have big problem.I have Vista Home Premium 64
simple solution is that just set your laptop to previous back up date at which it operates better
Posted on May 15, 2009
DickCanFixIt
  • 948 Answers
SOURCE: E-MU 1616. Problem installing drivers
"I am running windows XP proffessional 5.1 on a HP (compaq) dc7600.
Could this be the problem?"
It could be. Bring up your system properties box (Windows key + Pause/Break key). Is that the version shown at the top right on the GENERAL tab?
Is there some reason you have not installed service pack 2 or 3? Of course if you're running an illegal copy of Windows you can't, but I mean any legitimate reason? If we can eliminate the problem with installing the latest service packs we can move forward.
Posted on Jun 17, 2009
SOURCE: No sound upon installing E-MU 0404 pci card and driver
Hey ya'll.
I had the same problem with everything installed,icons on the screen etc...I took my stuff to my computer wizard and he came with the following solution which is:
Make sure that you have a Windows XP "SP2 or GREATER" this is the kicker.Go to the requirements sheet if you need more info.
Anyway I did that upgrade from SP1 to SP2 and it works like a charm with pristine sound.
Good luck fellows.
monsieur M.
Posted on Jul 16, 2009
57 varieties
  • 1653 Answers
SOURCE: I've got the same damn problem
Download and install the latest V2.1 Patchmix DSP Application and also the V2.1 Audio System Driver from EMU at
http://www.emu.com/support/files/download2.asp?Centric=760&Platform=1
Have you been downloading and applying any updates from Microsoft recently? If you have downloaded and installed both of the above then you should check the function of the board via System manager and Device Manager to see if there are any errors or conflicts showing and if so resolve them.
As you say it takes a long time to load initially you may want to uninstall the application and driver then run a registry clean to make sure that there are not multiple instances of the EMU in the registry as this will cause contention issues that could exhibit the behaviour that you are seeing. Ashampoo at www.ashampoo.com will do an excellent job if you need one you can do it for free for 30 days.
You may also be experiencing a lack of memory in the system – you can never have enough, your hard disk may be nearing capacity and also may need defragmenting – again the Ashampoo will do an excellent job. Also take a look at how much swap space is allocated and increase its size and change it’s location to a quiet disk if you can – preferably not one being hammered with sound data.
Then reinstall the EMU driver and app.
Posted on Sep 11, 2009
E-MU 1820m recording isue
restore your machine,and do installation of ur E MU soundcar.d again
Sep 13, 2012 | E-Mu 1820M Sound Card
Acer extensa 4620 bluetooth peripherals drivers for windows 7 ultimate x64
You can only do it with a bluetooth dongle, it won't work otherwise.
Jul 06, 2012 | Acer Extensa 4620 Notebook
Can the EMU 1212m work with the EMU 1820m Audiodock?
If I remember correctly you'll have to choose between the 1212-board and the 1820m-dock. The internal 1212-board is not needed if you have an 1820 and, as the line inputs/outputs on the 1212 appears as DockA/B and line 1 R/L on the 1820.
Dec 18, 2010 | E-Mu EDI Cable Sound Card
I am trying to scan multiple documents and have them go into 1 file using Windows fax and scan with my HP3020 all in one printer scanner, this used to happen automatically when I was on XP but recently...
This is the latest version of HP's Universal Print Driver (UPD). The UPD, available in 32 and 64 bit packages, is a single driver that supports PCL5, PCL6, and HP PostScript; level 2 and 3 emulation.
Please review the Release Notes for information on issues resolved, performance improvements, and new behavior changes to the UPD.
Details and specifications File name: s.gif upd-5_1_1_8232-pcl5_win-xp-vista.exe [1/1, 14.6M] System requirements: s.gif Client and server operated systems supported for the most current release of the UPD:
Client operating systems supported:
  • Microsoft Windows 7 Starter, Home Premium, Professional, Enterprise, and Ultimate; x86 and x64
  • Microsoft Windows Vista Business, Enterprise, Home Basic, Home Premium, and Ultimate; x86 and x64
  • Microsoft Windows XP (SP2 and later) Home Edition, and Professional; x86 and x64
    *Note: Microsoft retired mainstream support for Windows XP in April 2009. HP will continue to provide best effort support for the current UPD and tools for the discontinued Windows XP operating system until 2011
thumbs back!
Oct 28, 2010 | HP LaserJet 3020 All-In-One Printer
Can't find drivers for win 7 ultimate x64
According to Sony, your Vaio isn't eligible for Windows 7 upgrade. You could look at your device list and search individually for the new drivers, but if Windows hasn't spotted what you have and been able to load something that is at least compatible if not correct, then chances are slim. Never hurts to look though.
Apr 16, 2010 | Sony Computers & Internet
Bought a new computer with PCIe slots without realizing they aren't compatible with PCI soundcards, so my E-mu 1820m sound card does not fit. Are there adapters that will solve my problem? If so, how much...
even if your motherboards does have PCI-e slots it will still have 3 standard pci slots. So have another look there will be a slot for your sound card as in my experience and knowledge i have nether seen a motherboard with out a pci slot.
Aug 19, 2009 | E-Mu 1820M (054651066717) Analog to...
Belkin FSD7050v4 driver for Windows 7
just installed my belkin wireless g usb adapter on windows 7 64 bit down loade driver from belkin right click run in compaterbilty mode windows vista service pack 2 and install
Apr 28, 2009 | Computers & Internet
E-MU 1820m
I used to see in Thailand.
Pinij
Aug 04, 2008 | E-Mu 1820M Sound Card
E-Mu 1820M Sound Card Logo
1,188 people viewed this question
Top E-Mu Computers & Internet Experts
David
David
Willem.
Willem.
Steve
Are you an E-Mu Computer and Internet Expert? Answer questions, earn points and help others
