Question about GE Zoneline AZ25E12D3B Air Conditioner
Zoneline AZ28E15DABM1 indoor fan works on heat hi ,low ,air hi,low and fan ,hi ,low , when on heat or a\c the compressor or heating element comes on for a few seconds then goes off , fan kepts running . I think its a switch on the main circut board but not sure ?
Joe_Rex
  • 114 Answers
SOURCE: Short Cycling
COMPRESSORS HAVE AN INTERNAL T-STAT TO PROTECT THE WINDINGS ... SOME THING IS CAUSING YOUR COMPRESSOR TO RUN "HOT" THIS WILL KICK "IN & OUT" THE COMPRESSOR DURING COLLING OPERATION AND HEAT MODE (IF IT IS A HEAT-PUMP). 1ST THING TO EASILY CHECK IS THE CONDENSOR "OUT-SIDE" COIL. (CLEN BOTH WHILE YOU ARE AT IT). THESE FANS PULL THE AIR IN AND A BLOW OUT THE COIL .... ALL THE DIRT WILL BE ON THE INSIDE. 2ND THING IS THE FAN ITSEL OVER HEATING AN TURNING "OFF" ON ITS OWN "BUILT-IN POTECTION T-STAT". THIS WILL GIVE YOU THE IRRATIC OPERATION YOU ARE DESCRIBEING. I TEND TO THINK IT IS YOUR FAN MOTOR ... EASY TEST. TURN "OFF" EVERYTHING BUT THE FAN. SET IT FOR MANUAL "RUN ALL THE TIME" POSITION. THE FAN SHOULD NOT KICK OFF !!! IF IT DOES YOU FOUND THE PROBLEM. IF IT DOES TURN OFF IT CAN BE A WEAK CAPACITOR. UNITS VARY ON WETHER THE CAPACITOR IS FOR COMPRESSOR/FAN OR HAS A SEPERATE CAPACITOR FOR EACH. CAPACITORS ARE NOT EXPENSIVE. HOPE THAT CAN NARROW YOUR PROBLEM DOWN
Posted on May 07, 2007
  • 18 Answers
SOURCE: ge ptac
Hello Tom ,   I'm sure i can help you with this.... I work on these units everyday. unfortuneately im not there to put my hands on it but i will explain as clearly as possible.    The most common problem I tend to find with these units is that the control board  and indoor fan motor tends to go bad in these quite often.  If you put the unit in A/C MODE  and/or Fan mode and set it to high if it will not speed up from low , then your problem could be in a couple different places.   1st.  The bearings in the fan motor could be wearing down ,  2nd  The Control board could be bad  in that its not telling the fan motor to speed up.
And when you tell me that the compressor doesnt run in that mode at any given time..... which the electric heat and heat pump itself works together so that when the load is really tough  that the heat pump doesnt over work and in general saves life on your compressor.
Solution is this.
Take your indoor fan motor off and and drill out the rivits  and it pulls apart easy, and replace the bearings and grease them.
ALIGNMENT OF THE FAN IS A MUST.   doesnt cost much at all the fix this. Just a little time and bearings
Replace the Board in the control box
This my friend will definetly solve your problem.    These problems i see everyday with these same units.
Posted on Oct 14, 2007
edgz
  • 26 Answers
SOURCE: motel style heat and air
HI,
Meaning not function of heating,pls apply this the following 1) Possible loose connection to reversing valve pls check this wiring connection.
2) Pls check the sensor to thermostat if this a loose connection.
3) Check the Compressor if this not function or loose compression.( Function but not heating )
4) Check if have a Leakage.
Pls go to the nearest repair shop if not solve,
Thanks & best regards,
Edgz
Posted on Jan 19, 2008
  • 54 Answers
SOURCE: Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Posted on Jun 08, 2008
SOURCE: Remote Thermostat Control hookup for AZ28E15DABM1
I called out an electrician and he wired it for me. Even told me they sold me one not designed for my model, but he retrofited it and it works fine. Been about a year now.
Posted on Jun 18, 2008
Indoor fan barely turning
the three post capacitor has c for line voltage in, the f or fan is for the outdoor motor,and com or comp goes to start winding compressor.youll have to follow wires from indoor motor to find capacitor. to find wires to outdoor motor to capacitor you have line voltage and capacitor wires .look for schematic it would help or send colors of wires from both motors and compressor common,start .run.
Jun 07, 2013 | GE Zoneline AZ55H07D Air Conditioner
I have a fairly new GE Zoneline heating unit, and live in New England. This past winter, the unit has become VERY noisy, with loud vibrations, crackling noises and a fan that sounds as if it is on its...
This unit only has a warranty for 1 year. Have you followed the use and car instructions? If your looking to get the unit fixed follow the support link below and use the contact number for ge located on the right side of that page:
http://www.geappliances.com/service_and_support/contact/
Thank you,
Lee
Feb 28, 2011 | GE Zoneline AZ38H12DAD Split System Air...
AZ28E15DABM1 trips at the plug when on heater mode
Hi, this will happen because you have a problem with the heat side over amping for what ever reason. If it kills power to the plug and you have to go to the breaker to reset it, first take a look at the breaker.Remove the panel cover, look it over for signs of over heating, cracking and so on. Shut it off and take a screw driver to tighten wiring. You will not get shocked as long as the breaker is off. Wiring tends to loosen up and over heat over time and will cause a breaker to trip. They get weak. This may be you're only problem. After doing this, try it out and see. If it looked good, and the heater works fine, you should be good. The heater more then likely, draws more amps.You may have a dead short if it trips as soon as it is turned on, or does it run for awhile before it goes down? Let me know the outcome so we can go from there. Sincerely,
Shastalaker7
Dec 11, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Knocking Noise?
Might be the compressor. It would be a good idea to shoot it with some compressor oil.
Apr 20, 2009 | GE Zoneline AZ55H07D Air Conditioner
GE zoneline - about 23 years old
theres a heat relay and also the wire used for heat.either could be bad.
Nov 05, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Ge zoneline hvac
Pls check following......
1) If the Fan run and the Blower not function its min loose the hub or screw of the blower ,fix the hub or screw .
2) May be the the shafting of fan motor not rotate, repair the shafting or bushing of fan motor.
3) Check the Capacitor if this low capacitance or open (not function) using Multi-tester to check the parts.
4) Check the Fan motor wire if this loose connection.
if does not working,go to the nearest repairman to help the problem.
Thank you & have a nice day
Edgz
Jan 24, 2008 | GE Built-In Room Air Heat Cool Air...
Motel style heat and air
HI,
Edgz
Jan 17, 2008 | GE Zoneline AZ55H07D Air Conditioner
Ge ptac
Solution is this.
Oct 10, 2007 | GE Zoneline Deluxe Series Cooling &...
GE Zoneline AZ25E12D3B Air Conditioner Logo
109 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
