Question about Sta Rite 333 Btu Natural Gas Heater Maxetherm Sr333na
Heater won't turn on display says 104, but you can't adjust temp.
  • 44 Answers
By law heaters are not allowed to heat above 104. If your water is at 104 the heater will not fire. If the touch pad won't let you go down in degrees, you have a bad touch pad.
Posted on Sep 28, 2010
2 Suggested Answers
SOURCE: when I turn heater on
you need to check your thermostat for improper exposure to the sun or damage
Posted on May 21, 2011
South seas spas
need more info. will temp lower? if temp lowers try setting up to 104 if desired temp will not increase sounds like you need temp adjustment switch if desired temp goes up to 104 but water doesnt
sounds like temp sensor if temp sensor is good heater element
Feb 16, 2014 | Pool & Spa
Jamdy RS Shuts off heater too soon
when using the aqualink make sure heater is in tstat mode if not for your heater then turn heater all the way up make sure the wires are connected to pool and com then make sure the wires 5and 6 are connected to the heater then the aqualink will command heat if the red light is lit on controller
Feb 10, 2014 | Jandy 7953 AquaLink RS One Touch Control...
Jacuzzi j210 heater
bad temp sensor replace
Feb 01, 2014 | Qca Spas Pool & Spa
I have an Aqualink system, spa set to 104, it will heat to 94 and stay there, temp sensor is working, took water sensor out of line, plugged line, assumed heater would just keep heating, it did heat a
The heater may be wired just fine. The aqualink uses its water temp sensor to call for heat based on what you've set the thermostat to on the aqualink. However, most heaters have built in thermostats that over-ride the aqualink. Those thermostats come factory defaulted not to go over 94. Check your heaters manual on how to adjust the thermostat on the heater. Your heater should have its thermostats set to 104 and the aqualink will control the actual temp of the water by calling for heat based on what you've set the thermostat on the aqualink for. Hope this helps.
Oct 16, 2012 | Jandy Aqualink Rs4 One Touch Control...
I have Marquis hot tub, Leisure Series, The Spirit, Model ESLS30X, serial # 0890608. My in-laws gave it to us. It's about ten years old but still works reasonably well. The one issue is water...
If you found a solution to this problem, can you tell me what it was? I have the same thing. Its a Marquis Spririt and it just doesn't get hot enough. There must be a way to "trick" the thermostat into letting the heater run longer
Dec 10, 2010 | Heating & Cooling
Heater reads spa water 15 degrees higher than it is
if a 3 wire system put pool at temp desired and spa at 104 if 2 wire to firemans switch run heater all the way up to 104 the system will control the temp
Feb 22, 2010 | Jandy AquaLink RS2/6 All Button Dual...
Sta Rite 333 Btu Natural Gas Heater Maxetherm Sr333na Logo
265 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
