Question about GE WSXH208A Front Load Washer
I have a GE front loading washing machine. it will not drain model is wsxh208
  • GE Master
  • 3,051 Answers
Hello there:
This is due to the drain pump being clogged
The drain plug is on the front of this washer - you can see it without removing anything - there is a small 5"x3" panel on the front bottom that you pull out and then the plug twists free - have a large pan ready and unsrew slowly - water will come gushing out - have towels at the ready!
There are 2 screws on the bottom of the larger bottom front panel - remove these and you can see inside
you will see the drain plug housing is connected to the water pump and there are two hoses connected to the housing and the pump one coming from the washer to the drain plug and one going from the pump to your drain.
Remove the hoses carefully - I used plyers to pinch the clamps together.
the hardest part of this is removing the drain plug housing and pump - because it seems like you should be able to just remove the pump - but you can not!!
There are two screws holding in the housing and pump - remove them and the whole thing pulls clear.
Once out you can make sure there is not more coins or **** in the thing. Three screws hold the housing to the pump - mark these with a sharpie before you remove them - because once it is off there are multiple ways to re attach it.
Once free of the drain plug housing spin the pump a few times and put it all back together -
Hope this is very helpful for you
Best regards Mike
Posted on Sep 28, 2010
GE Washer will wash but won't drain?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 24, 2011 | GE Washing Machines
I have a GE top load washer Model WJRR417G1WW did not spin out after rinse cycle.. any idea? Jen
heatman101
Apr 14, 2011 | GE Washing Machines
GE model wwse5240G washer suddenly stopped working full of water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 19, 2011 | GE WWSE5240G
Water does not drain from te washing machine. Can I do anything to addrfess the problem. I don't have the exact model. It is a GE top load.
heatman101
Oct 25, 2010 | GE Washing Machines
My GE Washer Model # S2100 will not spin dry every thing els works
heatman101
Oct 22, 2010 | GE Washing Machines
GE top load Profile washer. Spin cycle not
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
The rubber seal has come away from the inner seal drum after one of the shocks broke. I have replaced the shocks but the seal is off. How do I reattach the seal to the drum? model#WSXH208
You would need a special adhesive glue made to withstand the heat! But I wouldn't try. Not even Red Green's Duct tape notion could bail this issue. You would have to replace the complete seal. And that...you're probably looking...around $30-50.
Dec 17, 2009 | GE WSXH208A Front Load Washer
Does not advance from wash to rinse to spin
The washer is new and under warranty so I have asked for warranty service.
May 23, 2009 | General Electric WSXH208H Front Load...
GE Model WSXH208-How do you know if PUMP motor is not working?
Found out the motor usually don't burn out that easy...therefore, I put it all back....let it run and felt the motor warming up....then it works....guess I was just a little antsy... ;=))
Dec 31, 2008 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
903 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
