Question about Masterbuilt 20070106 Electric Smoker
Controller works fine but no heat - Masterbuilt 20070106 Electric Smoker
Heating element is probably bad. Either that or wiring to the element is broken or disconnected.
Posted on Oct 01, 2010
How come i dont get no heat?
The heater core may be plugged with rust. Good way to test it is with the engine warmed up put the controls in heat mode and then go under the hood and locate both water hoses going t the heater core. Hold on to both hoses to see if the temperature of both hoses are the same. If not, no water is getting into the core. . If the temp is the same, then control vacuum is not working. There is a check valve in the line to the control head that prevents vacuum fluctuations from moving the blend door when accelerating. Check it.
Sep 25, 2016 | 2001 Chevrolet S-10
2009 Lincoln MKS heated seats do not work
there is a heat /cool control module under the drivers seat.
Jan 25, 2013 | 2009 Lincoln MKS
Why my heat only works on defrost
heat exchanger not working properly check for unhooked linkage or bad vacuum or faulty climate control,not sure what type of controls
Jan 14, 2013 | 1989 Dodge Ram D-Series Pickups
Lost power to ac/heat control.
prob. a bad a/c control head
Jun 15, 2012 | 1993 Chevrolet Suburban
I have a Bosch HBN7053GB /05 oven which worked fine apart from the bottom oven does not heat up, the light and fan are both working just no heat. I have replaced the element but still no heat, so now im...
You changed the element does everything else work fine, stovetop elements,broiler etc.if so check your wiring going to the new element and to the switch if they are fine it may just be the temp/control switch
Mar 12, 2011 | Bosch HBN 7052 GB Stainless Steel Electric...
Dryer seems to work (runs, tumbler turns, timer works, air flows) except there is no heat. I see that there could be several reasons for this, how do I isolate the problem and fix it?
First look for reasons why safety components would trip and remedy them thangsthemobilian_1642.jpgthemobilian_1643.jpgthemobilian_1644.jpgthemobilian_1645.jpg
So once we have that ironed out we now have an idea where to look first. If the dryer is clean and the vent is clear and you still have no heat then one of your heating components have failed. The heating components are the element, coils, sensors, ignitors and controls.
So if the element is bad simply replace it and you now have heat but what if the element is ok?
themobilian_1648.jpgthemobilian_1649.jpgthemobilian_1650.jpgthemobilian_1651.jpgthemobilian_1652.jpgthemobilian_1653.jpgIf your ignitor and flame detector is fine you may have the very common problem of weak coils themobilian_1654.jpg
If it turns out thet your safetys are fine and your heating components are fine then you could have a bad controlthemobilian_1655.jpg
If your control is fine you could have a bad circuit breaker.The motor on American machines is 120 volt of alternating current but the 5000 watt heating element requires 240 volts.themobilian_1656.jpg
I have include a dozen or so Dryer service manuals and more HERE
Let Me Know.
Mar 03, 2011 | Dryers
JKP86-27 neither heating element (broil or bake) is working. Other controls and microwave work fine.
having the same problem, microwave works however oven does not heat up. The controls work, I can set the temp and bake, the fan turns on but the oven does not heat.
Nov 25, 2010 | GE JKP86 Electric Double Oven
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven won't heat up
The problem is most likely the control board. If the oven control looks like it is working fine, but there is no heat, then one or more of the relays on the control board is blown. These relays are undersized for the current passing through them and they fail prematurely. You can replace the control board for about $170 online or just the relays for about $50 if you can solder on a PCB or know someone who can. If you replace just the relays, go with larger/higher current parts so this problem doesn't happen again.
Jan 21, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Masterbuilt 20070106 Electric Smoker Logo
147 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
