Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Nylon shorts stuck under agitator
How to remove agitator or easier solution
  • Buck Whyte
    Buck Whyte May 11, 2010
    What model washing machine? typically the top cap is removed and you will find a nut/bolt there.  This will allow you to remove the agitator
Modle # lsq8543jq0
Posted on Oct 03, 2008
How to remove clothes stuck under agitator
the agitator should pull straight up, you may have to twist it back and forth as you pull upward. when you put it back on make sure its all the way down and in place, this may be the reason your clothes are getting stuck under it.
Aug 23, 2014 | GE WBSR3140DW Top Load Washer
Clothing stuck under the agitator
Hold the agitator steady and the very top end will screw off. If very old it will be stuck pretty tight, but do not break it. Then the agitator will lift straight up.
Aug 08, 2009 | Kenmore Washing Machines
Clothing stuck under agitator
The agitator pops off. You will need to use a flat head screw driver or something short enough to get in the tub and under the agitator and it will pop off. They are on there pretty good so it will take some work
Jun 01, 2009 | Fisher and Paykel WL26CW2 Top Load Washer
Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Apr 15, 2009 | Amana ALW480DA Top Load Washer
Clothes stuck under agitator pan
You'll need to remove the agitator.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 08, 2009 | Washing Machines
Several pieces of clothing stuck under agitator.
you can remove the agitator. there are 3 steps to this. 1.take off the top plastic part of the agitator. 2 remove secondary plastic piece from inside of agitator 3. there will be a 7/16 bolt inside and will be deep so you will need a long extension to reach it. hold the fins of the agitator and remove the bolt with a ratchet. once the bolt is out you will be able to lift the agitator up.
Jan 03, 2009 | Kenmore 22422 Top Load Washer
Sheet stuck under washer agitator.
remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
Dec 20, 2008 | Kenmore 23822 Top Load Washer
Remove the center plastic cover with a little flat scre driver,
then remove six screw size 10 around
lift the round plastic base for you to remove the bedsheet.
VERY important qhe putting back the six screw to tigh them not 1,2,3,4,5,6 clockwise, go 1,3,5,2,4,6. Hope this help
Jul 01, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
87 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
