Question about Hotpoint HSS25GFP Side by Side Refrigerator
Clicking sound coming from the fridge and the on light flickers with it. The freezer cuts off and the water melts. It only does it at certain times and eventually stops. Also, the ice machine and the water dispenser is not working.
  • 121 Answers
The main board is bad. Read more here http://appliance-repair-it.com/GErefrigeratorrepair.html
Posted on Sep 28, 2010
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Warning light
Aug 04, 2013 | Bosch Classixx KGV28323 Bottom Freezer...
Freezer is not keeping food frozen and water is leaking between the freezer door and seal on the freezer door? The fan is blowing cool air.
is the compressor running?how long has the freezer been melting out?if you open the fridge door,turn the cold control up and listen to see if you hear the compressor start,if it doesn't try tapping on the control with a screw driver,if the control is bad it sticks inside and if you tap it sometimes it will free it and start but it will stop again,just doing this to check what's bad in the fridge,lso there's a timer in the fridge section,look around where the control is,you'll see a hole in the bottom of the console,you can stick a straight bladed screw driver up it and turn it slowly until it clicks,if the compressor starts when it clicks you have a bad timer and it was stuck in defrost,if the compressor is running and the freezer is still melting out you could have a leak in the sealed system a freon leak,you can check this by removing the back inside wall of the freezer,look at the evap coil,if there's just ice on the top instead of an even frost pattern over the whole coil then you have a freon leak,if the fridge has been running and you look at the coil it should have frost covering the whole coil,if ice is just on top it's new refigerator time,get back to me and let me know if the compressor is running,iis the door closing correctly and no rips in the gasket,if it has a light in the freezer push the light switch in and make sure the light is going out,if not the bulb is heating up the freezer,make sure the evap fan is blowing in the freezer and no ice on the back wall of the freezer,has any water been dripping into the fridge from the freezer,if so you have a blocked drain.do some checks and get back to me,if the freezer is melting out it sounds like you have a compressor problem
Mar 26, 2011 | Maytag MTB2156G Top Freezer Refrigerator
Our ge Profile fridge is making a clicking sound and the lights on the front are flickering slightly and the freezer/fridge temps are blacked out.
it sounds like the main board failing . board it in back / this controls the defrost and tempts and run times .. .. mm
Jul 01, 2010 | Refrigerators
Fridge is dripping directly onto top shelf. It is
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you have any other question. Mike
Oct 22, 2009 | Frigidaire FRT18FS6C Top Freezer...
Same thing
the flickering lights may be caused by a bad bulb
and/or socket, perhaps the bulb needs to be tightened.
get a different fridge!
Sep 19, 2009 | Refrigerators
My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Sep 11, 2008 | Frigidaire Freezer Refrigeration White...
Water for some reason is coming out of the bottom we just happen to find it. also It is drippinging and freezing in the bottom of the freezer we clean it out and it comes back, but the water on the floor...
Sounds like you have a side-by-side...
The defrost drain is probably clogged or frozen. When the fridge runs a defrost cycle the melted water cannot reach the evaporator pan underneath the refrigerator. Some water makes its way out onto the floor to wet your socks, and some re-freezes inside the bottom of the freezer compartment creating a layer of ice.
Jul 25, 2008 | Frigidaire Refrigerators
Have a hotpoint rsf60 fridge/freezer,noticed over temp red light on, defrosted as ice buid up on top shelf of freezer.light still on red temp set at 3/4 ?
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Jul 01, 2008 | Hotpoint Refrigerators
Hotpoint HSS25GFP Side by Side Refrigerator Logo
65 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
