Question about RC Remote Control Helicopter Ready To Fly
Yiboo UJ4708 will not lift even after being fully charged. It will just hover an inch off the ground. It doesn't sound right to me either when its running.
I had the same problem.. one of the gears isn't fully engaged.. if you look at the internal mechanism, you'll see two small gears on opposite sides, each engages a larger gear... during impact, these gears can slide and become not fully engaged. That is the strange sound you are hearing. this also prevents the propellers from spinning up fast enough to get fully off the ground. I used a small jewelers screwdriver to reach in and push the problem gear back into place.
Posted on Dec 27, 2010
  • 1 more comment
  • mcphee7163 Jan 18, 2011
    I can see the two gears you are talking about, but they seem fully engaged. I cant see that there is anything else to do. Any other suggestions?
  • asarogers Apr 23, 2011
    I just bought one last night and the top blades were not spinning correctly and it sounded weird. The gear on the motor shaft on the aft end was below the large bottom drive gear. The gear easily slide up and down the motor shaft. I used a small screw driver and put it back in place, but it slide back down. I think mcphee7163's problem was that the gear was twisting around the motor shaft instead and couldn't turn the drive gear.
  • Donald Dec 26, 2012
    My Aero star instructions are lacking explanation of the USB cable and how long I need to keep it in the PC usb port and the A B C slide switch whats that for???
How do i know when its fully charged
You should have an icon in lower right corner of the taskbar for your battery. "Hover" over it with your mouse. When it shows 100%, it is fully charged.
Mar 02, 2015 | Computers & Internet
Will not fly lift . Seem to run well but will not lift off the ground
The batteries on the Helicopter need to be fully charged to take off.
And important: to recharge the helicopter fully it needs really good base unit batteries.
I find all this a waste so - I used a wall power supply to supply suitable power to the charging bases of these helicopters give more consistant results than using batteries.. Just make sure you are using a 9V DC wall transformer (6 1.5v batteries = 9v) and that the polarity is correct.
manual is here
http://www.brookstone.com/webassets/pdf/651307p_manual.pdf
Dec 18, 2013 | Brookstone uControl Cloud Force RC...
We have lost our instruction manuals for our rc heicopters. is the small tail propellar supposed to spin? we can't get them to liftoff the main propellars seem to be working fine.
Sadly, Bob is incorrect here. In a coaxial helicopter, the main rotors spin in opposite directions, equalizing the centrifugal force and allowing the craft to hover without spinning, fine-tuned by the adjustment of the trim control. The counter-rotating main blades and internal gyroscopes provide a stable hover, while the tail rotor serves only to push the rear of the chopper up or down, providing the forward/backward thrust. If you are not moving the right joystick, you tail rotor should be stationary, or perhaps moving lazily from the wash of the main rotors. Sounds like a charging issue. What type of charger are you using? Also, Li/Po batteries are not meant to be fully discharged. Fully draining a Li/Po too many times, ESPECIALLY when they are new, will ruin them. Luckily the batteries on an 032 are easily replaceable. Available on Amazon and many other online retailers, and replaced in about 1 minute with only a small screwdriver. With a new Li/Po, charge them FULLY with the correct charger, and always stop the flight as soon as you are having to give it full power to maintain altitude. Also CRUCIAL is you MUST MUST MUST let the battery rest and cool for after a flight, wait a good 10 minutes BEFORE you connect the heli to the charger, and another 10 minute cool down after charging before you fly.
Hope this helps
r
Aug 19, 2011 | SYMA Toys industrial Syma S032 Ready to...
New SKILSAW 5995 used once to cut 1/4 inch plywood, no problem. Several months pass and I went to cut a pine board, the blade touched the wood and stopped. I recharged the batteries and tried again, two...
Did you fully charge both batteries before using them the first time? If not then they may not be able to hold a charge. It sounds to me like the batteries are either dead or defective as obviously the saw now doesn't have the juice to cut the board. If it's still under warranty take it back and get a replacement. Also, how powerful are the batteries? Even an 18V saw will struggle sometimes cutting a 2x4, they just don't have that much power. The plywood is easier to cut obviously.
Aug 12, 2011 | Skil Saws
Have a UJ4708 helicopter and it won't lift off the ground
We are having the same problem, would really like to know what to do to fix.
Dec 28, 2010 | RC Remote Control Helicopter Ready To Fly
Me and my dad have 2 yiboo Uj4708 helicopters. We need to know how to change the frequency on them so we can fly them simotaniously. We can change the frequncy on the remotes, but don't know how on the...
Turn both helicopters and remotes off. Then switch the remote to another channel, either a,b, or c, turn on HELICOPTER FIRST, turn on REMOTE second. Move throttle up and down, helicopter should start responding.
Dec 26, 2010 | Toys
Hi...I bought a syma s018 rc mini helicopter a week ago and it was working great but now, when i fully charge it, it doesn't have enough power to lift off the ground. Is my battery defective? It seems to...
I believe the Syma S018 is the same as my Yiboo UJ417.
Mine never got off the ground out after charging for an hour.
It just skitters along the ground. Must be a bad battery. Returning it if I can.
Nov 13, 2010 | SYMA Toys industrial Syma S018 Air Wolf...
RC Remote Control Helicopter Ready To Fly Logo
1,997 people viewed this question
Top RC Toys Experts
Tom Chichester
Kevin K.
Brett Duxbury
Brett Duxbury
Are you a RC Toy Expert? Answer questions, earn points and help others
