Question about GE Kitchen Ranges
G.E.profile stove converted to propane. Burner flame is now too high. Is there any way to adjust it downward?
  • GE Master
  • 43,501 Answers
You problem could be or probably is with the regulator...too much gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 29, 2010
I've just converted my stove from natural gas to propane and the oven and broiler flame are both to high, how can I lower them?
When converting from natural gas to propane you have to switch the regulator to propane. then on most modern stoves you have to turn the orifice hoods down to adjust for the higher pressure of propane. there are some stoves that you have to purchase a propane conversion kit with different orifices for the burners and oven burners.
Oct 01, 2015 | Kitchen Ranges
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
OVEN FLAME TOO HIGH ON A A GE CONVERTED TO LP
You should have a pressure regulator between your stove and your propane bottle. It's probably delivering too much propane at too high of a pressure to the stove.. If you don't have a regulator, THAT would be your problem. A regulator set to too high a pressure makes flame too high and flame may even try to blow itself out. I've remedied this by taking a small cover off the center of the regulator and adjusting a screw.. (Not all regulators can be adjusted.) If adjusting isn't possible, I'd suggest a new pressure regulator (for LPG). Note: A regulator for LPG is NOT set up the same as a regulator for natural gas.
Oct 28, 2013 | GE Profile JGSP44 Dual Fuel (Electric and...
Recently purchased a whirlpool gas range from Lowes "return,discounted aisle" I asked had it been converted to propane and they said yes it had. Wife is overly concerned how do you know they can...
Their is no marking or anything easy to determine that.....however natural gas is lower pressure that propane so if you were using propane and it was set to natural ALL the flames would be huge since it would be operating on the higher pressure while it was set for the lower pressure which would result in a flame thrower from each burner and soot so if the flames are pretty normal size despite the small adjustment for the simmer i believe its set to propane.
GENE
Sep 08, 2011 | Whirlpool SF310PEK Gas Kitchen Range
GE profile Oven converted from natural gas to propane. The tech changed the orifices and now the flame is to high. Any quick solutions.
The regulator needs to be adjusted, but if you do not have the proper equipment you should not try to make that adjustment...to bad the tech. did not do a good check before leaving...I ALWAYS fire every burner and check out everything before leaving, it is just too dangerous not too...
heatman101
Sep 13, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
BO696 problems-burners too high on lowest position
Remove knob, with flashlight look down top of shaft see a slotted screw that screw is flame adjustment.
To adjust, light burner, turn flame to low, with screwdriver turn screw rite till flame is at desired hight (aprox 2mm). now turn up to high check that high is satisfactory if high is to low then adjust screw. check low again. adjust till both setings are acceptible.
do for all burners
As for holding the knobs that is common with this stove, you could check to see if flame is hitting sensor the burner hole that lines up the sensor may be dirty.
Feb 28, 2009 | Explorer Appliances BO696 Gas Kitchen...
Flame way too high and yellow-Frigidaire Model #FGF328GM
call an approved frigidaire gas technician as it is possible that the jets in use are not for the propane gas
they are probably natural gas jets which have a larger jet size
the air shrouds around the jets have to also be adjusted to get the blue flame
you may be able to have it checked out under warranty as it is new
if you touch it your self , the warranty will be void
Mar 11, 2017 | Kitchen Ranges
Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
184 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
