Question about Acer Aspire 5315 Notebook
Blank screen and continuous beep sound when booting
2 Suggested Answers
parrotheadpc
  • 2600 Answers
SOURCE: blank screen
Windows Start-up Errors
Note: This troubleshooting step is usually used for the specific issue indicated above but it may also work for BSOD issues which recently occurred and you're unable to boot to either safe mode or normal mode.
First, The basics. You will need a Windows XP CD. If you only have a recovery disk set like the ones from a HP or Compaq, they will not do what you want. You can normally use a Dell disk, also retail box disks (XP Purchased from the store), or some OEM versions of XP will work (most of these will have the Microsoft hologram on them). You can also download a boot up Floppy disk set from Microsoft here: http://support.microsoft.com/kb/310994 There are a few other places with bootable CDs on the net, but the easiest thing to do if you don't have an XP CD is to borrow a Dell or Retail box disk and get right to work. If your computer already starts at the CD rom first, or you know how to make it go there skip to part C:
After you know that the computer will boot to the correct drive, insert your disk into the appropriate drive. If you have more than one cd rom or floppy drive you may find that your system only checks one drive before going to the hard drive for boot up. If this happens you can just move the disk to the other drive and restart your computer.
When you get the system started and it finds your startup disk you will see a screen that says Press any Key to boot from CD. I normally use the space bar as my any key and then you should see a blue screen that says Windows setup in the left hand corner. Wait until you see the welcome to setup screen and then click the "R" key to get to the Recovery Console How long it takes to get to each of these depends on the speed of your system, but I will tell you that it will take a few minutes to finally get to the Console.
Once you are at the Recovery Console you will be given at least one choice of Windows installations. Normally the choice you want is the number 1 choice. Click the number 1 key at the "top" of the keyboard and click enter.
You will be given a message asking for the administrator password. Unless someone or something has messed with your computer there is no password so you just click the enter key.
This will bring you to a prompt that says:
C:\WINDOWS>
Type: cd \ and then click enter
( Note: between "cd" and "\" there should be a "blank space" otherwise the command won't work. If you find that a command hasn't worked make sure you typed it correctly. These are similar to old DOS commands where spaces had to go between each command so DOS knew where one command stopped and another started.)
You are now at the ROOT of the drive where it all begins. The Prompt should now say C:\>
Now type: CHKDSK /R and click enter.
The chkdsk / r command also includes the P command and will also look for lost recoverable information in bad sectors.
Now after the chkdsk has run type: FIXBOOT then click enter.
It may prompt you with a warning but continue through it and once fixboot has finished type: EXIT and click enter.
Your system should reboot and when it does click the F8 button to get a windows start menu. Use the up or down arrow to highlight the LAST KNOWN GOOD CONFIGURATION and click enter. If it was a simple drive error this should have fixed it.
Posted on Oct 12, 2009
Hear beeping sound..
Go to
http://support.lenovo.com/en_US/diagnose-and-fix/detail.page?DocID=HT035729
it explains each beeping sound secuence, what it means, etc. Hope helps
Apr 05, 2014 | Lenovo Computers & Internet
Continuous beeping when tower is booted
Most BIOS manufacturers list continuous short beeps as most likely a power supply failure.
Jan 14, 2012 | HP Pavilion a1720n PC Desktop
My Screen is blank and fan continuously runs.
your computer is not posting that is why you do not hear a beep. This can happen for 1 of 10000000 reasons but I would start with checking the RAM then all the other hardware to find a loose connection/dead hardware.
May 28, 2009 | Compaq (203966-001) Motherboard
Latitude D600 beeps twice
that may be because of a bad connection with the harddrive thats easy to fix you just take the harddrive out and blow the connecting surface clean then it should behave normaly agian:)
Jan 04, 2009 | Dell Latitude D600 Notebook
Desktop doesnt boot.
If you have a windows XP recovery CD, try running that at boot.
also, try pressing the f8 key to boot windows in safe mode.
it sounds like a corrupted OS install: if you can't recover, you may have to reformat your hard drive and reinstall windows.
Mar 29, 2008 | Microsoft Windows XP Professional With...
Warning beep no boot
Re-seat the video card and memory first,
if it continues to beep count the beeps 3 long ,3 short .etc
they mean a code.
if you have 2 sticks of memory try using one.
Feb 14, 2008 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Beeping noise and blank screen
The beeps are part of the POST (Power On Self-Test). Here's a link to the Lenovo site that might help you interpret the beeps you're hearing:
http://www-307.ibm.com/pc/support/site.wss/MIGR-46018.html
Good luck.
Nov 19, 2007 | IBM ThinkPad T30 2366 Notebook
Acer Aspire 5315 Notebook Logo
254 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
