Question about Sta Rite Sr333lp - Max E Therm - Pool & Spa Heater - Dual Electronic Iginition Lo - Nox - 333,000 Btu - Propane Gas
Were to buy the led and circuit board for a sr333lp
    Novelist:
  • 116 Answers
Best bet is to call Pentair and ask for a dealer that carries the part. Then call the dealer and ask if they have it, can get, what it'll cost etc. Often times local part suppliers won't keep the circuit boards in stock if carried at all. So best to call first. Pentair's number is: (800) 831-7133, andf their website contact info is: http://www.pentairpool.com/pool-owner/contact-us/index.htm
Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave good feedback if you found this helpful. Thanks, and good Luck!
Posted on Sep 29, 2010
SR333LP pool heater continuously cycles ON/OFF, the fan stays on
The age and over all condition of the heater would help. Try removing the Thermal Reg and see if it smooths out. If the heater responds, replace the Thermal Reg with a new one.
Jun 11, 2017 | Sta Rite Sta-Rite Max-E-Therm High...
I have LG 42LN5300 which is reading 230VDC at led + plug and no back lights. All other voltages going to main board are OK, I changed main board because of flickering on and off screen, so is it MB
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 20, 2017 | LG Televison & Video
I have a Vizio 70" led model E701i-A3E it started getting white spots then it just went black has sound but no picture. What parts do I need to buy to replace to fix this do I buy all three boards
Jul 10, 2016 | Vizio Televison & Video
There is sound but no picture. No backlights but can see a picture in dark with flashlight test. LED panel # is D460D3-6Y43-COX. What part would I need to purchase? T
You have check the power supply first .To know how to check the power supply watch the following video. Normally led tvs power supply contains the led drive circuit too. Bot are integrated in the same board. The led drives circuit should have between 30 to 120 volts from the power section depending up on the brand and model number of the TV. If the the voltage is ok then you have problem with the Led driver section section. Either you can try to repair it or can buy a new power board.
www.electro-medical.blogspot.com
Testing LCD TV Power Supply BoardsSTEP BY STEP
Oct 31, 2015 | SEIKI Digital SE46FY10 46" LED TV...
Is there such a thing as buying infrared Sensors for a TV having problems trying to buy one
Most likely the problem is with the remote. The infrared LED transmitter in the remote could be weak. If the remote only works when it is close to the TV then it is faulty.
Try replacing the batteries first, the maybe flat.
When you replace them and you still have trouble operating the TV and it only works at close range then you can purchase an infrared LED transmitter form an electronics parts store and replace the this LED in the remote.
NOTE the LED is a polarised device and only work if inserted correctly.
The LED will have a small flat surface on the rim of the LED next to the shorter leg wire is the K (cathode) - lead, the longer leg wire is the A (anode) + lead. Make sure it is fitted to the circuit board the right way around before you solder the LED to the circuit board.
Apr 03, 2012 | Televison & Video
Led light not working in refrigerator
I have the exact same problem. I saw that I can buy a new LED light fixture for about $115 online. I removed my LED fixture and got no DC voltage difference on the wires when the doors were open or closed. This leads me to believe that the main circuit board is the problem. I also saw the main circuit board for about $125. I'd hate to buy the board and it not be the problem. Have you solved this yet?
Nov 15, 2011 | GE Profile PGSS5PJXSS Stainless Steel...
I have a hitachi 60sbx72b tv doesn't display anything
Tries unplug for awhile replug see if it reset itself?Don't work or only for awhile happen again.The main video board must changed.
Jul 11, 2009 | Hitachi 65SWX20B 65" Rear Projection...
I have a SR333LP poolheater will not turn on
Those are not service codes. Turn top over and look at the circuit board to see what light is lit
May 17, 2009 | Pentair MAXITHERM 333K BTU PROPANE GAS...
Sta Rite Sr333lp - Max E Therm - Pool & Spa Heater - Dual Electronic Iginition Lo - Nox - 333,000 Btu - Propane Gas Logo
96 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
