Question about Video Cameras
My cam is GR-D93 the error is E03 ( unit in safeguard mode eject and reinsert tape) i do it but it still the same error written on the screen?? what i can do??
  • hamsa186 Sep 30, 2010
    thankssssssssss
    i see
    its true i can't found the pinch roller for the left one
    it is lost
    where i can found one??
    or i can repair it??
  • 10,594 Answers
E03 error shows problem with tape loading mechanism, eject the tape and look for pinch roller is in its place or not. Usually pinch roller came off from its position and tape can not be drive.
Pinch roller is small round part, made of black rubber that helps the capstan motor to drive tape in forward or reverse order.
Thanks.
Posted on Sep 28, 2010
  • Shahid Electronics
    Shahid Electronics Sep 30, 2010
    Local camera repair shop will help you to provide pinch roller from any damaged MiniDV mechanism as its size is standard and can be used in other MiniDV mechanism.
    Next option is to buy new complete mechanism and replace it, it is of course costly fix.
    Oh yes, if you can do that easily then take apart camcorder carefully as lost pinch roller would be inside somewhere in camcorder, I found many times its inside in camcorders.
MY CAMERA SHOW E03 ;unit in safeguard mode ;EJECT AND REINSERT TAPE WHT SHOULD I DO............
JVCGR-D270.Digital Camcorder. When we put the tape in the cam it chews the tape whiles loading and says that it's in 03 safe guard mode. Please help.
Jan 24, 2011 | JVC GR-D73AG Mini DV Digital Camcorder
GR-DVL320 keep getting E03 error indication. Ejecting and reinsertion of the tape does not seem to be fixing the problem, also says unit in safeguard mode. What do I do to remedy this?
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the normal
Sep 02, 2009 | JVC GR-DVL320 Mini DV Digital Camcorder
Keep getting E03 error indication. Ejecting and reinsertion of the tape does not seem to be fixing the problem, also says unit in safeguard mode. What do I do to remedy this?
where your battery goes in,on the side , theres a little hole should say reset,get a niddle and push it and after you reset it ,it should work,make sure its on when you do it .if my info is of any help to you please leave me a comment ,thankyou.
Sep 02, 2009 | JVC Cybercam GR-DVL520 Mini DV Digital...
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
Unit stuck in safeguard mode
I can't find e setup for sony
camcorder
Dec 30, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Frustrated
E03            TU & SUP REEL FG
In the case no REEL FG is produced for 4 seconds
or more in the capstan rotation mode after
loading was complete, the mechanism mode
is shifted to STOP with the pinch roller set off.
This error is defined as [E03].
However, no REEL EMG is detected in the
SLOW/STILL mode.
to the mechanism.
Dec 09, 2006 | JVC GR-D290 Mini DV Digital Camcorder
Video Cameras Logo
301 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
