Question about Hobart Welders 500433 Champion? 10,000 All-in-One 10,000-Watt Generator
Champion 10000 welder keeps blowinb fuse on control panel wont weld runs fine fuse is labeled f1
4 Suggested Answers
  • 225 Answers
SOURCE: Welding breaker keeps popping on my Hobart Champion 10,000.
look for short inside unit,start at breaker and work your way back.
Posted on Jul 05, 2009
stunt driver
  • 5 Answers
SOURCE: I have a Hobart Champion 10,000 welder generator.
measure ouput on ALL available sockets - anything?
Take cover off electric motor-generator, visually inspect windings.
Measure continuity of all stator windings (2 or 3 points usually)
Measure continuity of stator thru brushset.
If all measures ok - has to be AVR module.
There is no mistery in generator - just stator to induce and rotor to obtain voltage.
Posted on Jan 13, 2010
cautionflag1
  • 116 Answers
SOURCE: I have welder Hobart Champion 10,000. I need an
It looks like Hobart made 3 different versions of the 10,000. If you go to their website and enter the model # (and serial #), you can download the exact owners manual with complete parts listing (according to their site). The website is: http://www.hobartwelders.com/service/owners-manuals
The part should be available from them..or with the part number, you can google it and see what is out there in the secondary market.
Hope this helps
Posted on Jul 24, 2010
I have a champion 10000 watt gen welder won't bur
Make sure the switch for remote power or control at machine is on the right setting. It will arc but very faint if this switch is not on the right setting.
Mar 17, 2012 | Hobart Welding Tools
Why is my bobcat 225 not welding hot enough?
Not knowing the full story, i would suggest, as a start, to set the WFS to No5 then set the Volts to No4. try this setting, Test the welding if still to low increase the voltage to No 5, check if it makes a difference, make voltage to No6, by turning up the voltage, you should see weld becoming hotter. let me know how you get on please
Nov 28, 2011 | Bobcat Miller 225 Welder Generator 907209...
I have a miller trailblazer 301g. It worked fine yesterday and now only the 120/240 volt outlets will work. No weld output and also the idle will not kick down. when I opened the unit the only visable...
Hi:
Probably your machines just overloaded; the engine will run and produce voltage but no weld output.
Check your fuses F1 and F2, if they are open replace them.
Both fuses are located at left hand side of machine, open it and you will find them on the bracket.
Good Luck.
If this was useful please vote, thanks.
Apr 28, 2011 | Miller Trailblazer 302 Welder Generator...
I have a hobart champion 16 and it will barely arc it will not make a weld it went from welding fine to doing this.
Could be something as simple as worn brushes, dirty slip rings, or a bad bridge rectifier. If you know how to check them, these are all something you could fix. If it's anything beyond those, you're best bet would be take it to a repair facility. I repaired welders for 18+ years. (just an FYI)
Jan 04, 2011 | Hobart Welders 500545 Champion Elite 11000...
Looking for manual on an old Burket Manufactured Champion Twin
call Dixie sales at 1-800-753-4943 thy are our champion suppler- hope this helps
Oct 15, 2009 | Welding Tools
May 24, 2009 | Hobart Welders Champion 500433A Factory...
My kohler driven hobart champ 10000 runs but only provides power
replace your berrings in the drive its probly as the rpms rise the centrifical force pushes the brushes against the wall causing it to short
May 19, 2009 | Hobart Welders 500433 Champion? 10,000...
Hobart Welders 500433 Champion? 10,000 All-in-One 10,000-Watt Generator Logo
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Troy
Troy
Level 1 Expert
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
