Question about Avaya Corded Phone avaparp18d
My fourth line doesnt ring and doesnt show a dial tone....
    Master:
  • 473 Answers
Issue with your Line...Cherk wire phone line for bad connection from the wall to the unit .... Check for Power Corde .... try normal phome on avery single line check for tone ...If you do have tone reset your phone on default ...then re-program it Check also for backup Battery it a little rond Battery 3volts that preserve your memory in your phone ....
Posted on Sep 28, 2010
Phone doesnt have dialing tone, cant make a call also when we ring home its goes to engaged tone
This means that your phone line is short circuited somewhere.
The technical name for it is Partial line Lockout.
Try unplugging anything connected to the phone line, including modems, fax machines, house alarms etc (as faulty equipment can cause this), then try ringing home again. If it now rings, plug things in 1 at a time and ring each time to see what is causing it.
If it is still an engaged tone with everything unplugged, then the short circuit is on the phone line in the street and needs to be repaired by your telephone company.
Oct 11, 2014 | Lands Phones
No dial tone on line 2
CALL THE COMPANY OF THE PHONE OR CALL THE PHONE COMPANY THAT PROVIDES THE SERVCE OF YOUR PHONE
Feb 27, 2014 | Uniden DECT4086 Cordless Phone
Bell Studio 4500 DECT phone with answering machine: just out of warranty, this phone does everything properly up to entering a number, then dialling, BUT not producing a ringing-tone or getting through to...
I gather you have the setting for tone and pulse set to tone? Also are you aware the ringing tone is generated by the phone company? When you dial a number and it connects, the phone provider sends the ring signal to the dial phone and the ringing signal to the dialing phone. Do you get a dial tone before dialing?
Jul 26, 2017 | Lands Phones
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Feb 03, 2012 | AT&T E2116 2.4 GHz Cordless Phone
We have a 4-line system in our office, but it is not working properly. For instant, when line 4 rings...it only comes into one of the phones. All lines are working properly with dial tones. If we would...
Now here's a conflict. Does line 4 work on any other phone where it doesn't ring? You say all lines are working properly wiith dial tones, tnen you say you can't pick it up from another phone.
I don't think these phones have "private lines", but the dial tone comes from the 2nd RJ-14 jack on the wall. On every phone, you could swap the plugs so that line 1 comes into line 3 and line 3 comes into line 1 (you'll lose the intercom) and see if you get dial tone on line 2 which will be the phone that works line 4. The point being to determine if you have a wiring issue or a programming problem.
Carl
Mar 21, 2011 | RCA 25423RE1 Phone
Cannot get the pulse tone off the line and that prevents from voicemail access and call forwarding HELP!
In guessing that since your lines have defaulted to pulse dialing that you have an older Nortel system such as an 8x24 or a 6x16 system. That being said you'll need to program touch tone dialing on each line.
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
the display says A. Configuration
4 top line/feature keys are now used for programming
Press the show key (top right arrow)
the display will say1. trunk/line data
Press the show key (top right arrow) .
the display will say line 001.
the display trunk data
press the show key (top right arrow) Press the next key 7 times(bottom right arrow) .
The display should say Dial mode: pulse.
Press the Change soft key (below the display).
the display should now say tone. press the heading key (top left arrow) to get back to "trunk/line data" repeat the steps for the remainder of your active lines
press Rls when finished
Nov 04, 2010 | NorStar M7208 Corded Phone
I pick the phone up, no dial tone. Display says
We called the phone company.....There was a problem up on the telephone pole. They fixed it, no charge.
Jan 21, 2010 | Vtech Cordless 6041 Phone
How do you forward a phone call from this phone to a cell phone?
to forward calls...go to your phone service providers website and help section for complete instructions...
with most companies simply pick up the phone... wait for dial tone... press *72 wait for 2 beeps and enter the number (area code first) that you would like it to forward to...once you enter the number wait for the line to ring... once it rings and is answered you are all set!
if it doesnt ring or is in use.. try again within two minutes...you should hear two short rings if it is activated...
to deactivate call forwarding...
pick up the phone (in the office)
wait for dial tone and dial *73 or #73
you will hear two short beeps... it is then off..
Apr 10, 2009 | Panasonic KX-TS3282B Corded Phone
Cant get fax to send or receive
most likely you plug wrong jack on your machine, make sure have plug in jack which marked "line"
Dec 08, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Avaya Corded Phone avaparp18d Logo
94 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
