Need assistance with config in door buzzer. Need to verify the unlock code. Currently the door buzzer rings but when dialing the unlock code ** from the phone it will not unlock door.
    Master:
  • 473 Answers
Go on the Net Type the Brand and Model off your Barcode Scanner and type exemple (Tandy TS20 manual & Spec utility) and follow the manual and garanty you will get what you need
Posted on Sep 28, 2010
Buzzer rings intermittently. Anytime
We would need the full model number with any suffix in order to provide you with free assistance.
It is usually found on a tag located inside the cooking cavity or around the door frame or controller frame.
Since FixYa is still not notifying us when you respond to clarification requests, you will have to post a new help request with your model number and symptoms / questions.
Or feel free to contact us directly here for free help.
Sep 17, 2011 | Microwave Ovens
My mobile is conutry locked
Hi there!
To unlock your Nokia 5230,you will need to do the following. Contact your phone carrier or service provider and ask them for the unlock code for your phone. They will then ask you for your IMEI number. This is how you get your IMEI number: Dial the following code on your phone: *#06#
Follow the easy steps after completing the above:
1. Power on your Nokia cell phone with an unaccepted SIM card in (or sometimes no SIM card at all works).
2. Type #PW+Unlock Code+1 (Where Unlock Code is your 8-digit Nokia unlock code)
3. Now verify your Nokia unlock code was typed correctly
4. Finish by typing #
5. If worked phone should say "SIM Restriction Off"
Note: In order to enter letters on your Nokia dial pad you will need to press the asterisk (*) key several times.
This link will be of great help:
http://hyfeno.com/nokia-5230-unlocked-unlock-code/
Hope this will help you
Kind regards
Martin
Feb 09, 2011 | Nokia 5230 Cell Phone
I for get the phone unlock code Lg verizon wireless celphone
Security unlock codes are provided by your cellular carrier. Call them and request Tech Support assistance. Once they verify that you are the owner of your account, they can provide you with a Master Code and assist you with any other programming tasks that may be needed.
We cannot provide security codes on FixYa as we are unavailable to verify ownership of your phone..
Jan 26, 2011 | Cell Phones
I have a Maytag dryer (Model MDE2600)and the buzzer will not go off unless the door is opened. Buzzer begins when door is closed.
Hi
Buzzer comes on because the control senses that the door is not closed and won't start the cycle. This issue is caused by door switch-latch assembly (part#6 and part#9 in this diagram) that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jan 17, 2011 | Maytag Dryers
My Motorola V360 phone will not ring. Speaker works, ring tone demos can be heard but phone will not ring. Currently set on vibe & ring. Please help.
Check that these people who are calling, in your phonebook, do not have a picture or are edited. Delete them from your phonebook and then add them again. I had this problem today and solved it using this method :)
Hope this helps
Dec 22, 2010 | Motorola Mobility V360 Cellular Phone
How do you re-program the security code on a 2007
FORD KEY PADS
  • Enter permanent factory code
  • Press the 1/2 button within 5 seconds to enter programming mode
  • Within 5 seconds enter new code, doors will lock, unlock to verify code, this erases previous codes remotes will also need to be programmed. (MAYBE)
KEY PADS/REMOTES
  • Insert key, turn ignition off-to- on eight times in succession, ending with key in on position doors will lock, unlock to verify in programming mode
  • Press any button on new remote, doors will lock, unlock to verify
  • Do the previous step with the second remote, doors will lock unlock to verify.
  • Turn ignition off. Doors will again lock, unlock to verify.
NOTE-Some vehicles use 5 turns of the key instead of 8
Jun 05, 2010 | 2007 Ford Explorer Eddie Bauer
How can i program my door lock code or find out what it is. on my 2000 limited edition explorer
FORD KEY PADS
FORD KEY PADS/REMOTES
NOTE-I found that some Explorer/Mountaineers enter program mode after 5 times-not 8.
Here is the link for further info.
http://www.2carpros.com/how_to/how_to_reprogram_key_remote_fob.htm
Your factory code is on a card in the owners manual. If that is lost, access the control module in the cargo area behind the left cover panel.
You MIGHT be able to see the code printed on it, or you might need to pull it out in order to see it.
May 27, 2010 | 2002 Ford Explorer
How can i unlock my childs lg vx5500 lockcode?
dial *22898 and it will set it as the last 4 digits of the phone number
Jan 26, 2010 | LG VX5500 Cell Phone
Need Caller ID displayed on Nortel StarTalk Flash/M7310
A question: -> does your phone ring? -> what software are you running on the system? If you know this will help a little in giving you more information. There is a Feature that you can dial if your phone rings... when there is a call coming in, dial FEATURE 8 1 1 You can even make this a button rather than dialing this feature code everytime: -> Feature * 3 -> press the button that you want to program -> dial Feature 8 1 1
Jul 16, 2009 | Nortel T7316E 2-Line Corded Phone
Can not hear the telephone ring on one of the main phones upstair
You will need to know which line(s), and on which station(s) (extensions) you want each line to ring.
Programming is accomplished as follows:
Default Installer Password = INTERCOM *746
You can enable different ringing assignments for individual lines and stations.
You must program ringing assignments on a per station/per line basis. You can control ringing for every line that has appearance at a station assigning immediate, or direct, ringing to some lines and delayed ringing to others. NOTE: Do not program direct ringing for lines that you assign to the direct department calling feature.
To Program: 1. Dial 54. “STA/LINE CONFIG.”
2. Dial 1 “DIRECT RING”
—OR—
Dial 2. “DELAY RING”
NOTE: For no station ringing, skip step 3 and make no line selection.
3. Select line ports for ringing (LED On = Selected Ports).
—Line port 1–14 = Dial 01–14 or press A1–A14
—Line port 15, 16 = Dial 15, 16 or press B1, B2
—Line port 17–24 = Dial 17–24 or press HOLD then press A1–A8.
4. Dial # when all line ports are selected.
5. Select station ports (LED On = Feature Assigned)
—Station 10–57: Dial 10–57 or press C10–C57.
6. Dial * when all station ports are selected
—OR—
dial ** for next station/line ringing assignment
—OR—
dial ***for configuration mode.
To clear current setting, repeat procedure.
Use an LCD speakerphone and a DSS/BLF console at station port 11 or 13 to see which features are assigned to individual stations. While you can install any non-LCD digital telephone and use it for programming, visual feedback of the programming operations will not be available. You must always keep the handset of the LCD speakerphone on-hook while you use this telephone to program the system.
Mar 26, 2009 | Comdial Impact 8024S Corded Phone
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
