Question about RCA Televison & Video
The channels won't pop up what cord do I need
    Master:
  • 473 Answers
Check if your cable are plug on TV cable in... and check for Power On little green light on the side ...then press menu for selection on our manette for programming
Posted on Sep 28, 2010
I have a ivew 760tpc and its not charging.. i have yo leave Tue charger on it .. also it has the android guy in the.middle of the screen . It won't go to.home screen at all , and when i hit press the...
You could post to the Tablet category and get a solution from a Tablet expert. If it's under warranty return it. Has the Cord/charger been damaged due to pulling on the cord while plugged in causing a short or loose connection? If the "pop" is followed by a electrical burning smell, return or have a Qualified Tech take a look at it, it COULD be a fire issue if left unattended and plugged in.
Apr 26, 2013 | Computers & Internet
I have a casio privia px-130, and I'm trying to use it as a MIDI on FL Studio, but it won't show up in FL Studio. Is there a driver that I have to download?
Check the midi channel. It needs to sync to FL Studio. Channel settings you'll need to look up in the privia manual...can be laborious - but worth it in the end :)
Apr 19, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
When I hook up my cobra 20 plus it won't change off channel 9 . Why not?
it may have a channel nine switch or button on the front that locks it there.
Dec 14, 2012 | Cobra 20plus Cb Radio W/ Microphone Power...
Why is the electrical wire so short
Don't add an extention cord to an extention cord! Buy a 100' 14/4 extension cord and tie the end to the fence so it won't come un plugged.
If the plug keeps popping out of the short cord at the blower,wrap the cord around the handle to prevent disconnection.
Nov 18, 2012 | Ryobi 200mph Leaf Blower & Vacuum Mulcher...
My Fender Hot Rod deluxe makes a popping noise when switching back to the clean channel.
This is because your clean channel only runs through the pre-amp section, requiring an increased volume level to match that of the volume of the drive section which is overdriven by the pre-amp circuit. my suggestion is to use lower volume level on the clean channel of the amp. To get any volume boost you may need to match the two channels you could use a signal/volume booster or overdrive pedal between your guitar and amp input, switching it off and back on when you switch back and forth between channels.
Jul 15, 2012 | Fender Hot Rod Deluxe Guitar Combo...
SUDDENLY THE SOUND QUIT (HEART A POP SOUND LIKE A BULB POP) PICTURE STILL WORKS BUT NO SOUND- WHAT CAN I DO?
First, you need to find out, if this is a problem from your audio (sound) cord or from the unit or from sound settings.
Connect the player/recorder with another audio cord to the TV. Use a RCA (red and black wire). If sound still doesn't come out,check sound settings.
Go to menu, settings, sound, check all settings under sound. This should me done when playing a moved. If problem still persists after check sound settings and changing cord, then it means the sound card/board of your player/recorder is defective and that's why it won't bring out sound.
At this point, I would suggest you take the player/recorder to a repairman to fix for you because this is not a DIY thing. You need a professional to help you out.
Let me know if you need further assistance, please let me know.
Regards.
Aug 08, 2011 | Toshiba D-R5 DVD Recorder
When i play dvd i hear background music really clearly and voices are hardly audible - this happens on channel 5.1. if i swap to channel 2. i hear the filmmaker commentary! dvd was working fine until...
sounds like the speakers are out of order and/or maybe 1 or 2 not connected. use a AA battery and "pop" each speaker wire. it's low voltage and amperage so it won't damage your speakers. but the pop will allow you to know exactly what speaker you have and if it's connected. now make sure to put it in the correct spot. i would start with the center channel. sounds like this one's not connected.
please rate if this was helpful!
Apr 12, 2011 | Televison & Video
No light oh headphones i have 2 batteries in emitter do 2 go in the head set?
pop the side off headset and insert two battires then turn it on ....pop bottom off emitter insert two battries flip swith up one notch to turn it on........the headphones are just an fm radio...push middle button to scan channels and bottom button to change bands...........the emitter sends on an fm signal which the headphones will pick up when you pickup the right channel signal........turn the headset on and off with the volume knob.........if you leave either one on 24 hrs the battries will die since there is no usb power cord as promised in the manuel so be sure to turn both off when not in use
Jan 22, 2011 | Logitech MH2001 5in1 HiFi SXBS Wireless...
Speakers popping
Call LG if they are in warranty, should be after 4 months. Try reseating all connections including power, or changing cables. If it shows on all of your speakers, If it doesn't move with one or more speakers, you probably have a leaky capacitor in your reciever and will need to return it for repair or replacement. Hopefully its not just the receiver choosing to spike an amp channel at will. Could possibly be an electrical appliance in your home causing the noise by switching on and/or off. Have somebody walk around your home turning things on and off to see if your receiver is affected. If nothing pops, it very well could be your receiver. An experiment to try is using a different power outlet. Use a long heavy duty extension cord if needed. You want to get power from a different circuit. If that doesn't fix it, try a UPS device (like those used on computers). This will isolate you from the power line, and hopefully from the pops.
Jan 29, 2006 | LGDVT418 System
Televison & Video Logo
37 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
