Question about IBM Wheelwriter 30 Typewriter
Label stuck behind platen. How do I get it apart to get it out.
  • IBM Master
  • 3,594 Answers
On both ends of thplaten are black plastic latches. Squeeze them together and lift out the platen. When reinserting be sure they are lined up with the side frames an push down firmly it should snap into place.
DickyO
Posted on Sep 28, 2010
Gx 6750 carriage daisy brogham
If you can remove the platen, roller, you may find a label stuck on the deflector. Remove the label from the deflector. Make sure the deflector is installed properly.
Nov 05, 2013 | Brother ML-100 Typewriter
I have a label stuck under platen of a Swintec 8016 typewriter. How do I get the platen off to get label out.
I believe the 7040 is identical to the Nakajima AE-740 If so there is a black lever at the L. end of the platen, push it down to release the platen. You can get a manual @ NADIST.COM click on current models.
DickyO
Sep 16, 2011 | Swintec 7040 Typewriter
I have a TA Adler-Royal 315. It operates beautifully, and hopefully will continue to do so (fingers crossed). Someone used it recently when I was away from the office and managed to get a label stuck to...
Try this thke a piece of heavy stock, like a file folder and force it thru the paper path while turning the platen. This may push the label thru or at least flatten it out.
DickyO
Mar 09, 2011 | Royal Office Equipment & Supplies
How do I take apart my Brother typewriter to remove a label stuck to the metal bar where the paper feeds in?
I wish I had one in front of me, but I don't. Brother used two ways of holding the Platen (big black roller in place. Open the top cover and look at the frame where the platen is held. You will likely see plastic clips holding the axial that runs through the platen (85% of brother machines have clips), or you will see that the axial runs directly through the frame. If you see clips just squeeze the tabs and lift up. Note which side has the gear, so that it is reinstalled the same way. If you don't have clips you will need to loosen the Allen screws holding the knob to the platen roller, and the roller will lift right out. If the label left any of the rollers sticky they must be completely cleaned before reassembly, Goo-Gone is a good product to remove gummy labels.
Best of luck, Ron
Jan 06, 2011 | Brother ML-100 Typewriter
A mailing label is stuck to the paten. How can I get it off? It's stuck behind the ribbon. I've been using tweezers to get it off, but just comes off in little pieces. I can't turn it on because it...
On both ends of the platen are black latches squeeze them together and pull the platen out. Now you can clean the debris out of that area. If you remove the silver paper tray note how it is installed for replacement. Re-insert the platen be sure to line up the latches with the side frames and push down firmly to snap into place.
DickyO
Feb 09, 2010 | IBM Wheelwriter 30 Typewriter
Need to remove the Platen to remove paper.
On each end of the platen there is a black plastic retainer squeeze them together and lift the platen out.
DickyO
Jun 30, 2009 | Lexmark Wheelwriter 3 Typewriter
Remove a label stuck to the metal floater behind the pleten myself
Take a quarter piece of typing paper. Soak it in paint thinner. Roll this down where the label is stuck. The paint thinner will dissolve the adhesive on the label but will not harm anything in the typewriter.
Apr 24, 2009 | Brother ML-100 Typewriter
Need to clean the platen
IF you can't get the platen roller out, then what you can do is get a cleaner called " GOO GONE". Take a rag or paper towel, and pour some of the goo gone on the rag where the labels are located. IMPORTANT PART: You want enough Goo Gone on the rag so you can saturate the label. I have even CAREFULLY poured some Goo Gone right from the container onto the label.
Just don't go crazy with the Goo Gone.... You do not want to pour sooooo much onto the platen roller where it drips down it the frame of the machine and possibly onto the main board.
REMEMBER.... Just enough to saturate the label.
After the label is saturated.... WAIT AT LEAST 3 minutes. I usually wait closer to 5 minutes, and then you will notice that the label can be easily pulled away from the platen.
After all of the labels are removed, go over the entire platen with the Rag with Goo gone, and then go over it again with a clean dry rag.
I hope this works for you as well as it has worked for my customers.
Good luck.
Mac =)
Mar 26, 2008 | Brother ML-100 Typewriter
IBM Wheelwriter 30 Typewriter Logo
51 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
