Question about Makita 3612C Router
I need a new base plate for router 3612c and I don't know where to get one
How to attach to my craftsmen router? I've inherited my Dads router, router table,and router guide. I have no idea how to use them. Will you please help me?
I have a craftsman router and table. On mine you remove all the screws from the base plate, set the base plate aside and use same screws to mount the router to the underside of the table.
May 08, 2017 | Saws
My makita 3612c router sounds bad and don't function well ,as can be heard in the video, I can see sparks coming from the brushes!!! Any idea about how to fix? What is the cause of such a problem
You probably have no brushes left running on the armature hence the big sparks and noise. The armature will be beyond repair Take to an appliance repair shop but I fear that it will be cheaper to junk it and get a new one.. My experience with Makita is that the brand is selective in the quality.
Apr 04, 2013 | Tools & Hardware - Others
Mounting the router under the table - what is the procedure and how does it work for a different brand of router i.e. Portercable?
Your insert plate should have holes to screw the base plate of your router to it. Do you have an insert plate? It's a must. The plate also has leveling screws at the corner so you can have it completely flush with your table top. Most plates fit the most popular routers, like Porter Cable. If your's does not fit, You can drill new holes into it without compromising its integrity.
Most woodworking sites carry different kinds of insert plates. You might also consider a router lift. I have one and consider it indispensable.
Hope this helps, if it does, please place a vote for me. Thanks,
Handie Andie
Mar 27, 2011 | Garden
I need the plastic plate for a Rockwell 4601 router. The part that rides on the wood. pdecara@aol.com 703-635-5602
the original sub base for this tool is obsolete no replacement. My suggestion is to buy another MFR sub base the same size, (most are they used this plate on B&D, Porter Cable and others) and if the holes don't line up exactly you would need to drill and counter sink them. With a little effort on your part you can get this router running again. I checked 4 sites for this part and came up with the same on all about the obs no replacement. Let me know if you need more assistance. Thanks
Mar 10, 2011 | Porter Cable Tools & Hardware - Others
I need a base plate for a Freud FT1702VCEK to make a router table will a FT1700 work.
I don't think I understand, because all routers come with a base plate, and to make a router table, you would want to remove the base plate from the router, and use the holes underneath that.
But there was a whole lot of discussion about the very same subject on a router forum, so maybe you will find the answer you need there?
http://www.routerforums.com/guide-bushings-templates/12216-freud-ft-1702-vcek-combo-router.html
Oct 13, 2010 | Freud FT1702VCEK 2 1/4 Hp Router With 2...
I have a brocken swich on my router internally do u know were i will find a new one??
what is the brand and model number and give me the city and zip if in the US and I will try and find one locally for you.
Jan 18, 2010 | Makita 3612C Router
My router RE180PL came without the insert for the base plate which prevents me from using the guides required for my dove tail jig. Where can I obtain the insert? Don Coats at doncoat@aol.com Thanks
go to ryobitools.com and type in your model number for a parts schematic and owners manual for this tool and you can order replacement parts. Good luck
Sep 18, 2009 | Ryobi Tools & Hardware - Others
Can a Model 3612C be connected to a router table
It looks like it can BUT before trying where are you located and I will try and find a Makita Factory Branch in your area that can make that decision or if you want I have Makita Headquarters phone number also. Let me know. Dave
Oct 27, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Porter cable router
you proably need a router table to use a1 1/4 bit safely
Jul 26, 2008 | Electrical Supplies
Makita 3612C Router Logo
50 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
