Hi i have a samsung p1453 front loader washing machine that will not go through its spin cycle every time, it gets to 9 mins remaining and tends to jump upto 10 mins remaining occassionally it will do the spin as it should ? the pump is clear and working fine and the pcb is not blown from what i can see grateful for any help thanks
  • 2,272 Answers
The fault can be related to faulty drain pump or timer control board.As you mentioned in your question that pump is clear then this problem is related to timer control. If the washing machine is filling properly and doing the wash cycle then not going to spin cycle check the door switch and door.The spin cycle will not start if door switch is weak or faulty. If door switch is checked ok then its timer related problem.Remove the timer control out and check its connection to the main control board.Wiggle the connections a bit then reconnect and check.If still the same problem then its timer. You can get required parts from sears part direct site.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 28, 2010
My Whirpool Duet front loader will begin a wash cycle, but stops when cycle switches to rinse with water in the drum. Door remains locked & light by the 'wash' flashes 9 times...
when the machine is stopped can you empty the residue water that remains by the programme selector? if not check for blockage in the pump(coin), the hose internal blockage ,or at the outlet under sink. I hope this help
Jan 15, 2015 | Whirlpool duet Washing Machines
My washing machine top loader once reaches the spin cycle, with 21minutes time remaining, it goes back to rinse and repeats the cycle. What is the problem of my washer and how do I fix it? Thanks
If the washing is not distributed evenly by the time it reaches the rinse/spin cycle, it goes back to rinse cycle. Be present at the machine when it reaches the spin cycle. observe the drum to see if it is of balance and swaying to the sides, if so distribute washing evenly. Usually happens if there is a big garment or more with smaller items,
Regards
Phillip
Oct 06, 2014 | Samsung SW62ASP Top Load Washer
Front loader machine stuck before spin cycle
This is an issue with the pressure switch, it is having issues detecting the water level.
Mar 11, 2012 | LG Washing Machines
My frigidaire fron loader will not spin during wash cycle but will spin when placed on spin
If the drain pump is working correctly and you can get it to spin manually, then the board is faulty. Had the exact same problem with an Lg front loader 40 min. ago.(have to replace the board.)
Jun 14, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have just purchased an 8KG Siemens front loader
Time to call the selling dealer for warranty service.
Aug 01, 2009 | Dryers
I have an LG front loader, gets stuck on spin cycle at 9 min
The timer is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | LG Washing Machines
Can't get rid of E1 error on a Samsung front loader washing mach.
E1 : washing machine has exceeded a check time for fill, heat or empty.
Common causes for this are fill and empty problems, heater fault (or the wiring
to it broken), water pump open circuit (although that would stop the water draining too) Pressure chamber blocked or pressure tubing pipe looped below the pressure bottle, or a sticking eco ball in the sump hose (sludge and grease build up)
This error code is generic and vey common.Since you have tried the remedies.Try getting checked the internal wiring damage by professionals.I hope certainly hope the problem lies there.
Dec 09, 2008 | Washing Machines
Frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
Dec 05, 2008 | Frigidaire ATF6000ES Front Load Washer
I have a samsung P1453 washing machine and it refuses to spin, I have checked the obvious like filter and discharge hose,. Is there some sort of sensor to check for load in-balance
hi i also have a samsung p1453 that will not spin when the digital counter gets to 9 mins remaining it jumps back to 10 mins and wont go through the spin cycle the pump is working fine and emptying as it should cann ot see anything blown on the pcb
any advise woulkd be appreciated
May 14, 2008 | Washing Machines
Washing Machines Logo
146 people viewed this question
Top Washing Machines Experts
