Question about Garmin nuvi 200W GPS Receiver
NUVI 250w Show Black Screen with ICON of Computer and NUVI
When i plug my nuvi in to charge or thru usb the nuvi changes to a black screen with the Garmin logo and icon of computer plugged into a nuvi in the bottom center of the screen.
I tried a reset and that did not fix the problem. (turn nuvi off then on with your thumb pressing the lower right corner.
  • vvvasea May 26, 2008
    When i plug my nuvi ( garmin 660 TFm) in to usb the nuvi changes to a black screen with the Garmin logo and icon of computer plugged into a nuvi in the bottom center of the screen. Then i can't do map updating, and garmin software don't recognize my gps. Help me pls!!!
  • Anonymous Oct 27, 2008
    I have the same problem. We've always used different leads (cell phone usb connection) to connect to the car and have never had a problem until now. Doesn't seem to be holding a charge either.
I had this problem. I discovered that I was using the wrong lead in the car. The problem resolved itself when I used the lead that came with it.
Posted on Jun 10, 2008
My unit 200w was working yesterday now the unit will notturn on
i am a truck driver and i need my unit
Posted on Jul 06, 2008
Thats normal, its charging mode... what do u need to put it in usb anyway? updating maps? you need to have unlock maps first, + mapsource. try visit garmin for more info...
Posted on Jun 13, 2008
Garmin nuvi 40 goes into usb mass storage mode when pluged to charge
I updated my Nuvi 40 with the latest software and it will not reboot into GPS mode with the usb cable connected. It used to work. I have figured out how to get it to charge with a standard USB cable:
1) Power it on.2) Press the battery icon for 8 seconds - it will enter TEST mode.3) Plug in your USB cable from the PC to the Nuvi - the screen will change to say charging.4) Press the power button 3 times rapidly - it will say Charging across the screen and it will go dim and then dark.5) To wake it up and use GPS mode while charging simply press the power button 3 times rapidly, again.
Works Great!
Nov 15, 2011 | GPS
My garmin nuvi 200w keeps going into mass storage mode when plugged in to charge.as soon as it is plugged in to charge the screen appears that shows the garmin plugged in the computer. and the map...
1) Disconnecting the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi should now reboot, but remain in GPS mode!
Aug 06, 2011 | Garmin nuvi 200W GPS
Can you charge a nuvi 1300 with usb with computer and how long does the charging take??
I have just got a Nuvi 1300 and have plugged into my computer with the Nuvi switched off. A little icon (showing GPS unit and computer) shows on GBS screen and unit starts to charge. I reckon about 3 hours to fully charge. You have to unplug GPS though to see battery status.
Martin. U.K.
Oct 07, 2010 | Garmin nuvi 1300 Car GPS Receiver
Will not stay on when not plugged into the car outlet?
first make sure that the device is indicating that the battery is being charged or that the battery is fully charged. this is indicated on the menu screen by the battery icon as being 4 bars of full green color.
if the unit will not charge in your vehicle, you might need to replace the fuse that is located at the tip of the vehicle adapter.
1. to change the fuse unscrew the black, round end piece on the vehicle power adapter and remove it. inspect the fuse to see if it is blown. If not end here.
2. if determined the fuse is blown remove the fuse (glass and silver cylinder), and replace it with a 1A fast blow fuse.
3.ensure that the silver tip is placed in the black end piece. screw on the black end piece
if the fuse isn't blown and the unit still wont charge you may have received a usb cable with your Garmin Nuvi. If you didnt recieve one any mini usb cable should do. On this model you can connect the Nuvi to a computer using a usb cable. And see if you can charge your unit through this method. *Note* that the computer must be on for the unit to be able to be charged.
If you can charge your Nuvi unit on the computer then you may have something wrong with your cars adapter. I doubt this is the problem however if the unit is able to be turned on.
If you cannot charge the unit via a car adapter (with working fuse) or a USB cable. The most likely problem is the battery is no longer accepting a charge. On the listed unit a Garmin Nuvi 265 the battery is not user replaceable. So you would have to contact Garmin to get the battery changed or see if there is a local battery store that is able to change a battery on this model unit.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please rate the comment. thanks and have a great day.
Aug 20, 2010 | Garmin nuvi 265 Car GPS Receiver
My Garmin nuvi 250W GPS is NOT powering on.
try connecting it to your computer via the usb cable. that may reset it. outdated maps will not cause this problem.
Feb 21, 2010 | Garmin nuvi 250W GPS Receiver
Can not turn on! my garmin nuvi 200w I think it is locked,
if ther battery went totally flat place it on charge for an hour or so to revive it. Max battery life in storage is 4 days with a good battery.
Charging it even tho the charge light may not show should build up enough charge to eventually show the light and allow you to turn it on. It should remain on charge for 5hrs.
Other possibility is a collapsed cell in battery, replace the battery
Jul 24, 2009 | Garmin nuvi 250 GPS Receiver
I have a nuvi 660 that just comes up woth black screen
hey i have nuvie same problems plus keyboard fubby numbers all i did was plug usb into it and computer done virus check on nuvi folder in my computer unplugged it brand new back to normal hope helps
Jun 15, 2009 | Garmin Nuvi 660 GPS Receiver
My new nuvi 255w will not start displaying info
When using a usb from your computer it is only a trickle
charge to the garmin. Will take a day or two to fully charge. If you use a the cigarette lighter plug that came WITH the garmin, it will fully charge in 4 hours. Stick with garmin approved plugs and all will go smooth. I know, I made the same error.
May 15, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
How do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Nov 09, 2008 | Garmin nuvi 250 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
2,461 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
