Question about Canon imageCLASS D480 Black and White Copier
Canon D480 document feeder doesn't always feed documents
  • Canon Contributor
  • 185 Answers
First, try changing some Document Feed Rollers etc.
FC8-9251-000 is the pickup roller
FL3-1023-000 is the separation pad
FM3-8679-000 is the feed roller
That would fix 80% of the problems you may encounter
Whit
Item, Inc.
Posted on Sep 30, 2010
  • 2 more comments
  • mail24719 Mar 31, 2011
    Of the 3 Document Feed Rollers, is there one more likely to replace than the others?
  • Whit
    Whit Apr 01, 2011
    Each roller has a unique function, so it depends on what symptoms you encounter.
    The pick roller grabs the paper, so replacing that is usually the most important. The feed roller advances it. The separation roller prevents 'multi-picks."
    That being said, most people change them all together, since they were at a similar rate.
  • mail24719 Apr 04, 2011
    Hi Wrinaldo - By chance, can you give a brief description of how to change the rollers. I can't find images anywhere on the web which show how to access the rollers. Again - appreciate your help and knowledge very much.
  • mail24719 Apr 06, 2011
    Can anyone provide guidance on how to replace the pick-up roller on a Canon D480 printer? I purchased the parts but I can't figure out how to replace. Appreciate the help.
Auto doc feed does not activate
two possible problems :
- check the connection of the document feeder
- check the sensor on the document feeder that triggers the pickup
- check the clutch of pickup roller
Jul 27, 2012 | Canon PC-795 Copier
What does document in ADF mean
Hello, Thanks for using Fixya today.
ADF is auto document feeder, used to feed a document into a scanner or printer. The error is associated when there is a document or paper jam at the document feeder, or paper trail.
This would happen mostly on scanners and all in one printers after witch a document is left in the feeder or there was a paper jam occurrence. We hope this answers your questions today?
Please contact us again if you still have a issue, or need help with anything else.
Thanks for using Fixya.com
Best regards,
Rulds2008
Jun 14, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
My fax is having a problem feeding pages through the document feeder, it doesn't always grad the page, and if it doesn't get it, it acts like it has a paper jam, what is causing this?
Open the document feeder. Inside you will find a grey feed roller. Cleaning this roller with a cloth dampened with water will help with these paper jams in the document feeder.
Sep 29, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Document feeder does not feed documents separately. The documents stick together when trying to feed them to print.
hi u have problem with sepration roller just replace it or try to clean sepratin roller to solve problem
thanks
May 10, 2010 | Canon PC1061 Copier
Canon 1023if auto feeder not working. Says check
The document feeder has multiple sensors in it. sometimes they hang up and stay stuck out of place. Other sensors might get paper dust on the face of the sensor. If you can open the document cover, locate the sensors and see if any are ajar or the sensor flag fell out of place. Also look to see if a paper is stuck in any of the paper path areas. Not seeing the machine it is hard to say if it fed paper and says check document, if it did, clean the feed wheels with a wet paper towel.
Oct 15, 2009 | Canon imageRUNNER 1023iF Black and White...
Copy of documents misaligned vertically on Canon Imagerunner 3045
Hello sir; When you feed originals in portrait, the paper tray have to set by portrait direction too.
Mar 30, 2009 | Canon Office Equipment & Supplies
Document feeder does not work
cleaned some sensors under the feeder, if possible, clean it with blower to solve the problem.
Aug 04, 2008 | Canon NP 6050 Copier
Auto Document Feeder
has the feeder attempted to feed in the document ? Check to see if there is already a document on the copyboard platen
Apr 27, 2007 | Canon PC-980 Color Copier
Canon imageCLASS D480 Black and White Copier Logo
405 people viewed this question
old marine
old marine
